Hi, @haideralipunjabi,
I am on the same kernel and KDE stable and the same wine version.
This is the output of winecfg command from the terminal, and I could say that finally the winecfg window appeared.
00cc:err:setupapi:SetupDefaultQueueCallbackW copy error 1812 L"@mscms.dll,-1" -> L"C:\\windows\\system32\\spool\\drivers\\color\\srgb color space profile.icm"
0100:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0xfe306d, context 0x54769d0, init_notify 0, handle 0x5f6fa70): stub
00cc:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
014c:err:module:open_builtin_file failed to load .so lib "/usr/lib32/wine/l3codeca.acm.so"
014c:err:winediag:gnutls_initialize failed to load libgnutls, no support for encryption
014c:err:winediag:gnutls_initialize failed to load libgnutls, no support for pfx import/export
014c:err:module:open_builtin_file failed to load .so lib "/usr/lib32/wine/mp3dmod.dll.so"
014c:err:winediag:schan_imp_init Failed to load libgnutls, secure connections will not be available.
0154:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x10df537, context 0x4dd90c0, init_notify 0, handle 0x581fcc4): stub
014c:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
014c:err:module:open_builtin_file failed to load .so lib "/usr/lib32/wine/winegstreamer.dll.so"
wine: configuration in L"/home/jochoa/.wine" has been updated.
0024:err:module:open_builtin_file failed to load .so lib "/usr/lib32/wine/l3codeca.acm.so"
I am using wine. wine and wine-staging both are 5.22-1 for some reason. I am currently waiting for the process to complete, as suggested above. If it doesn’t work, I might downgrade to wine-stable in AUR which is 5.0.3-1 version.
You don’t have version 5.21 in the cache folder. Pacman stores downloaded packages in /var/cache/pacman/pkg/ and does not remove old or uninstalled versions automatically.
After waiting for an hour like @j8a suggested, nothing happened so I decided to terminate it. It gave the following errors after that.
^C0024:err:seh:NtRaiseException Unhandled exception code c000013a flags 0 addr 0xf7f8fb59
0050:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be
loaded.
0050:err:winediag:nodrv_CreateWindow Unknown error (998).
0050:err:ole:apartment_createwindowifneeded CreateWindow failed with error 0
0050:err:ole:apartment_createwindowifneeded CreateWindow failed with error 14007
0050:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x800736b7
0050:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-
00aa006009fa}, hr 0x800736b7
0050:err:ole:apartment_get_local_server_stream Failed: 0x800736b7
0050:err:ole:start_rpcss Failed to open RpcSs service
