Wine not working following 2025-06-23 update
I would like to chime in here as I am facing the same issue. In my case this is a clean Manjaro installation (in which I completely broke the Windows dualboot but that is another problem).
After I installed Manjaro, I also installed Wine and winetricks. Running winecfg from the command line results in the same you posted.
wine: created the configuration directory '/home/user/.wine'
002c:err:seh:NtRaiseException Unhandled exception code c0000005 flags 0 addr 0x6fffffc0daff
wine: could not load kernel32.dll, status c0000135
I have tried different prefixes but to no avail. The only thing that triggered me in this post is that you said you have an old CPU. That is the same in my case although it was running Windows 10 Home just fine.
Here is the output of inxi.
inxi -Fazy
  Kernel: 6.12.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=3a3fbacc-6cc7-49d0-9e22-75e8582812ef rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.15.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: H81M-S2PH v: x.x
    serial: <superuser required> uuid: <superuser required>
    BIOS: American Megatrends v: F2 date: 08/05/2013
  Info: model: Intel Pentium G3420 bits: 64 type: MCP arch: Haswell level: v2
    built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
    microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 smt: <unsupported> cache:
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2822 min/max: 800/3200 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2822 2: 2822 bogomips: 12774
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    vendor: Gigabyte driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
    built: 2013 ports: active: HDMI-A-1 empty: VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0402 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: Philips PHL 499P9 serial: <filter> built: 2020
    res: 3840x1080 dpi: 82 gamma: 1.2 size: 1193x336mm (46.97x13.23")
    diag: 1239mm (48.8") modes: max: 3840x1080 min: 720x400
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics (HSW GT1)
    device-ID: 8086:0402 memory: 1.46 GiB unified: yes
  API: Vulkan v: 1.4.313 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics (HSW GT1) driver: mesa intel v: 25.1.4-arch1.1
    device-ID: 8086:0402 surfaces: N/A
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
    class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  API: ALSA v: k6.12.34-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
    lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.36 TiB used: 33.7 GiB (2.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08M2NA0
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
  ID-1: / raw-size: 313.58 GiB size: 307.59 GiB (98.09%) used: 33.7 GiB (11.0%)
    fs: ext4 dev: /dev/sdb3 maj-min: 8:19
  System Temperatures: cpu: 66.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB available: 7.65 GiB used: 5.93 GiB (77.6%)
  Processes: 185 Power: uptime: 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1356 libs: 399 tools: pamac pm: flatpak pkgs: 0
    Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.38
Is Wine not usable on this system perhaps?
Post found about that error message:
https://www.reddit.com/r/wine_gaming/comments/zacbyr/wine_completely_broken_wine_could_not_load/
https://medium.com/@rupesharma203/wine-could-not-load-kernel32-dll-status-c0000135-fc3c11ffa216
https://bbs.archlinux.org/viewtopic.php?id=299491
https://forum.winehq.org/viewtopic.php?t=36856
Hi Phil,
Thank you for your reply. I should have included those links in my post as I have seen and tried them all. None of them helped, as whenever I get to the point to run wine, it instantly returns the kernel32.dll error.
Well, some apps might not work with WOW64, as I mentioned earlier: Wine not working following 2025-06-23 update - #19 by philm More info here: WOW64 mode does not seem to work on anything - WineHQ Forums
Good idea, I tried it with another account that I use as a guest account and where there was no .wine folder, and the behavior is exactly the same.
For the record, on another machine with an I3, the new version of wine works perfectly…
I am also running an E5800 processor and having the identical problem you have. I followed your suggestion to downgrade wine to 10.7.1 which temporarily resolves the issue.
