Wine: could not load kernel32.dll, status c0000135
I just installed wine, wine gecko and wine mono along with winetricks from pamac but when I try to run winetricks or winecfg I get a message:
wine: could not load kernel32.dll, status c0000135
When I search for kernel32.dll I found it in
/usr/lib/wine/x86_64-windows
Here is my system info from inxi --full --verbosity=7 --filter --no-host if needed.
inxi --full --verbosity=7 --filter --no-host                     ✔
  Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
  Type: Laptop System: HP product: HP ENVY m7 Notebook
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: HP model: 81D4 v: KBC Version 87.21 serial: <filter> UEFI: Insyde
  v: F.56 date: 06/12/2018
  ID-1: BAT0 charge: 16.6 Wh (64.6%) condition: 25.7/25.7 Wh (100.0%)
  volts: 11.8 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
  serial: <filter> status: Charging
  RAM: total: 15.52 GiB used: 2.23 GiB (14.3%)
  RAM Report:
  Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
  arch: Amber/Kaby Lake note: check rev: 9 cache: L2: 4 MiB bogomips: 23209
  Speed: 600 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 600 2: 600
  3: 600 4: 600
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
  art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
  lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
  pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
  pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
  xsaves xtopology xtpr
  Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
  driver: nvidia v: 465.31 bus-ID: 04:00.0 chip-ID: 10de:134d class-ID: 0302
  Device-3: Chicony HP IR Camera type: USB driver: uvcvideo bus-ID: 1-5:2
  chip-ID: 04f2:b591 class-ID: 0e02 serial: <filter>
  Device-4: Chicony HP TrueVision HD type: USB driver: uvcvideo
  bus-ID: 1-6:3 chip-ID: 04f2:b592 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
  loaded: modesetting unloaded: intel,nouveau failed: nvidia
  alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.2
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
  class-ID: 0403
  Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.28 running: no
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 5040
  bus-ID: 01:00.0 chip-ID: 8086:095a class-ID: 0280
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
  v: 0.8 bus-ID: 1-8:4 chip-ID: 8087:0a2a class-ID: e001
  Local Storage: total: 931.51 GiB used: 19.6 GiB (2.1%)
  ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-22JC3T0
  size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
  rev: 1A01 scheme: GPT
  Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH61
  dev-links: cdrom
  ID-1: / size: 58 GiB used: 19.52 GiB (33.7%) fs: ext4 dev: /dev/sda6
  label: N/A uuid: a4e2f38e-334f-4d53-ac0a-91f6acb1ef43
  ID-2: /boot/efi size: 96 MiB used: 74.2 MiB (77.3%) fs: vfat
  dev: /dev/sda1 label: N/A uuid: DA46-5664
  ID-1: /dev/sda2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
  ID-2: /dev/sda3 size: 124.4 GiB fs: ntfs label: Local Disk
  uuid: 582C5A902C5A68D0
  ID-3: /dev/sda4 size: 499 MiB fs: ntfs label: N/A uuid: B4B873F8B873B786
  ID-4: /dev/sda5 size: 624.37 GiB fs: ntfs label: DATA
  uuid: 0C323A19323A086A
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-2:5 info: Lenovo Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  power: 100mA chip-ID: 17ef:608d class-ID: 0301
  Device-2: 1-5:2 info: Chicony HP IR Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b591
  Device-3: 1-6:3 info: Chicony HP TrueVision HD type: Video
  Device-4: 1-8:4 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0
  speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  System Temperatures: cpu: 42.0 C mobo: 0.0 C
  Processes: 210 Uptime: 1h 36m wakeups: 5 Init: systemd v: 247 Compilers:
  gcc: 11.1.0 Packages: pacman: 1360 Shell: Zsh v: 5.8
  running-in: gnome-terminal inxi: 3.3.04
Hello @ClassicNoob :wink:
That has to do with your wine prefix. Delete the standard prefix (~/.wine) or create a new custom one with:
mkdir -p ~/myapp/prefix
export WINEPREFIX=$HOME/myapp/prefix
export WINEARCH=win32
export WINEPATH=$HOME/myapp
wineboot --init
winetricks
Thanks I deleted ~/.wine and ran winecfg and it reconfigured itself and its working now!
I thought I had done this already but I must not have done it fearing what it would mess up :smiley:
