Hi, I installed Manjaro KDE and whenever I try to run app/game in Wine it appears as a process but nothing else happens. I tried running the command and it gave the following output:
Something must have went wrong when you tried setting up a program and it messed the .wine config folder somehow. Try installing the Worms 2 game again. Winehq has some instructions depending on if you have a cdrom version or the gog (not known to run). If you have the GOG version you might want to install lutris, a wine front end, it has a way to install the GOG version.
I have a gog version, Lutris worked until some point, It is “frozen” but it is running, the “gear” spinning animation is playing but I cant click any buttons or really do anything.
basically this is the window:
Installing worms2
Installing game data
(gear spinning animation)
(something ending with "process exited:", I cant scroll to read it)
Initial process has exited(return code: 256)
All processes have quit
Exit with return code 256
do I just force quit it or is there a solution?
(If you don’t reply today, I will just “sleep” the system)
Hi, try to install it again with Lutris. Therefor, click left top side on that plus sign, then “search on Lutris Webpage for a script”. It should find Worms2.
If it still doesnt work well afterwards, after it did install, you can rightclick on the game, configure, then tab options, and deactivate either DXVK or VKD3D, or toggle between them.
That is the only issue what i have with Lutris most time. But with Wine i got a lot more trouble all time.
Even i did run most things before with PlayOnLinux, not Wine alone. There are simple to much possibilities, to make something wrong or not right.
You also can start before a terminal, then type there “Lutris”, and you have your log again, or twice.
