I have the same problem since a few months. But with Radeon…
$ inxi -GSa
Host: world Kernel: 5.19.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.1.1 parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=df22fa0d-f0f5-4d8a-b84f-38d158c1772e rw scsi_mod.use_blk_mq=1
sysrq_always_enabled=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8
ports: active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0
chip-ID: 1002:699f class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
s-diag: 1245mm (49.01")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: bottom-r model: HP ZR2440w
serial: CN42440WCS built: 2012 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,top-left
model: Dell U2717D serial: J0XYN6CEAGZS built: 2016 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
OpenGL: renderer: AMD Radeon RX 550 / 550 Series (polaris12 LLVM 14.0.6
DRM 3.47 5.19.1-3-MANJARO) v: 4.6 Mesa 22.1.6 direct render: Yes
Primary is Monitor-2 (HDMI) Windows from this screen are after wake up on Montor-1 (DVI)
Moderator note: moved to own topic, to not go against Forum Rules - Manjaro
