What is the shortcut for switching the active window?? Is it present in kwin like everything else and can someone help me create a conky widget for displaying all the important shortcuts in the desktop please??
PS: I am using KDE Plasma
I can’t find anything in the kwin section
Hi @abhijiths1998,
I can’t remember if this is the deefault setting, I almost doubt it, but because of many years of using Windoze, mine is set to Alt+Tab.
But IIRC this can be customized:
- Open the launcher and go to Sysstem settings
- Go to Window maanagement → Task switcher.
On this screen, under the Shortcuts section, you can cus6tomize it.
When changing something, click Apply in the bottom-right to apply the changes. If you are satisfied with them close the window and enjoy Manjaro!
About conky: I’ve got no idea, since I don’t use it, sorry!
Hope this helps some!
