Window decoration size change when switch to tablet mode
Hi
I use a Lenovo x390 yoga. When I flip over the screen, the window decoration gets bigger. Likewise if I rotate the screen. Is there a way/setting to keep windows decorations same size? I use “Breeze” as decoration.
Many thanks!
t
  Kernel: 6.12.39-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
    root=UUID=f9b1e170-4180-422d-9fde-3ed1dc55e2b1 rw quiet
    cryptdevice=UUID=a621da8d-7e97-4684-a588-eeb873d7b749:luks-a621da8d-7e97-4684-a588-eeb873d7b749
    root=/dev/mapper/luks-a621da8d-7e97-4684-a588-eeb873d7b749 splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
  Type: Convertible System: LENOVO product: 20NQS0W600 v: ThinkPad X390 Yoga
    serial: <superuser required> Chassis: type: 31 serial: <superuser required>
  Mobo: LENOVO model: 20NQS0W600 v: SDK0J40697 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20NQ_BU_Think_FM_ThinkPad
    X390 Yoga uuid: <superuser required> UEFI: LENOVO v: N2LET74W (1.74 )
    date: 03/24/2020
  ID-1: BAT0 charge: 44.1 Wh (85.6%) condition: 51.5/50.5 Wh (101.9%)
    power: 5.6 W volts: 12.0 min: 11.6 model: LGC 5B10W13927 type: Li-poly
    serial: <filter> status: discharging cycles: 328
  System RAM: total: 8 GiB available: 7.42 GiB used: 3.63 GiB (49.0%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 4 GiB speed:
    spec: 2667 MT/s actual: 2400 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: Micron part-no: 4ATF51264HZ-2G6E1 serial: N/A
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 4 GiB speed:
  Info: model: Intel Core i5-8365U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 400 min/max: 400/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 30409
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt
    invpcid lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep sgx smap
    smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
    tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt
    xsaves xtopology xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: retbleed mitigation: Enhanced IBRS
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
    ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b67c
    compositor: kwin_wayland driver: X: loaded: intel dri: i965 gpu: i915
    display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1387 built: 2018 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 166 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
    ratio: 16:9 modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL
    GT2) device-ID: 8086:3ea0 memory: 7.24 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: N/A device: 0 type: integrated-gpu
    name: Intel UHD Graphics 620 (WHL GT2) driver: mesa intel v: 25.1.6-arch1.1
    device-ID: 8086:3ea0 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.12.39-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bd class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5
  Device-1: luks-a621da8d-7e97-4684-a588-eeb873d7b749 maj-min: 254:0
    type: LUKS dm: dm-0 size: 62.5 GiB
  Components:
  p-1: nvme0n1p7 maj-min: 259:7 size: 62.5 GiB
  Local Storage: total: 238.47 GiB used: 12.27 GiB (5.1%)
    model: MZVLB256HBHQ-000L7 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: 4M2QEXH7 temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 62.5 GiB size: 61.22 GiB (97.95%) used: 12.08 GiB (19.7%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-a621da8d-7e97-4684-a588-eeb873d7b749 label: linux root
    uuid: f9b1e170-4180-422d-9fde-3ed1dc55e2b1
  ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
    used: 201.4 MiB (20.7%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: linux boot uuid: 3396fedb-3bda-431a-a439-80438fb6d4bb
  ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
    label: efi system uuid: 0164-1470
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 200 MiB fs: vfat label: ESP
    uuid: B618-C398
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 1.95 GiB fs: ntfs
    label: Recovery uuid: 7638193C3818FD35
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 31.25 GiB fs: ntfs label: SYSTEM
    uuid: 6EEA1B5BEA1B1F41
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Wacom Pen and multitouch sensor type: HID
    driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 056a:51b2 class-ID: 0300
  Device-2: 1-8:3 info: Chicony Integrated Camera type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b67c class-ID: 0e02
    serial: <filter>
  Device-3: 1-9:14 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-4: 1-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 44.0 C pch: 45.0 C mobo: 35.0 C
  Fan Speeds (rpm): cpu: 1927
  Packages: pm: pacman pkgs: 1182 libs: 316 tools: pamac
Processes:
  CPU top: 5 of 255
  1: cpu: 200% command: ps pid: 33747 mem: 3.93 MiB (0.0%)
  2: cpu: 21.2% command: firefox pid: 32829 mem: 448.8 MiB (5.9%)
  3: cpu: 11.9% command: zsh pid: 33658 mem: 8.79 MiB (0.1%)
  4: cpu: 10.8% command: firefox pid: 33056 mem: 294.4 MiB (3.8%)
  5: cpu: 8.8% command: thunderbird pid: 33313 mem: 399.8 MiB (5.2%)
  Memory top: 5 of 255
  1: mem: 448.8 MiB (5.9%) command: firefox pid: 32829 cpu: 21.2%
  2: mem: 407.8 MiB (5.3%) command: plasmashell pid: 1111 cpu: 0.2%
  3: mem: 399.8 MiB (5.2%) command: thunderbird pid: 33313 cpu: 8.8%
  4: mem: 294.4 MiB (3.8%) command: firefox pid: 33056 cpu: 10.8%
  5: mem: 230.2 MiB (3.0%) command: firefox pid: 32925 cpu: 7.1%
  Processes: 255 Power: uptime: 1d 2h 24m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 8 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 2.95 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.38
Perhaps in System Settings → Touchscreen - I cannot verify as I don’t have a tablet system with Manjaro.
As far as I am aware, that is correct functionality. various control areas become larger to support derfingerpoken… to make it easier to use touch screen actions.
Hi thanks for answering. I was coming to the same conclusion
r
No worries, that’s what this forum is for, and why we are here.
