Win11双系统安装,分区报错,why
联想天启,硬盘是MBR分区,C盘直接装win11,再空出来80G,未格式化,留待manjaro安装时使用。
但安装过程中,无论是选择第二项(取代一个分区),还是第四项(手动),在分区步骤时就报错!
Job:Create new partition on device ‘/dev/sda’
Command:sfdisk --force --append /dev/sda
Failed to add partition ‘New Partition’ to device ‘/dev/sda’.
Why?
How?
同样的情况,用其它linux版本曾经安装成功过!
I unchecked “Plasma settings → Removable Storage → Removable Devices → On Login and On Attach”.
The problem is still the same!
Both single and dual system installations,the error was reported at the partition step!
I suspect the error was related with lenovo computer BIOS !
My PC is lenovo TianQi.
It is possible the installer cannot see your system storage device.
If your device uses NVMe - then your USB will be sda - and creating a partition in the empty space of the USB will fail because Manjaro uses ISO9660 - a readonly - filesystem.
This can be caused by Intel RST (vmd), firmware raid or device not connected using AHCI.
Thanks for your help!
