Will not launch Eve Online via Wine / Lutris
I updated my system a couple of weeks ago when this came out. I had an issue with a game that was running Wine through Lutris. Wasn’t really sure where the issue was, if it was Wine, Lutris or the System Update.
I see here in this post that Wine was updated and not sure if I should try to revert to a previous version? I had tried removing Lutris and Wine and reinstalling but I’m not having any luck. Any suggestions on how I should proceed? Should my focus be on Wine? Lutris? Or something else? Once I have an idea where to start, I can share more details on system and errors.
I was so impressed when I first installed it how everything worked perfectly. I really wasn’t expecting that and it’s run fine for several months until the update.
Your post has been moved to a dedicated topic. Feel free to change the title to better describe your actual issue.
Without more information it’s difficult for anyone to point you in the right direction. You might, for example, tell us which game you’re having difficulty with; place it in the title so that others who may be experiencing the same can immediately find it.
Actual problem details will be preferable to simply indicating that you have an issue.
Please also provide system information as described (below), and any other information that will demonstrate the problem you’re facing.
I’m sure someone will help when they are able.
Asking for help with running Games
Before asking for help about running Games on Manjaro, we usually ask members to see the pinned topic in the Gaming category:
As the article suggests:
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes more indepth information is usually needed;
It’s best to ask your system directly. :eyes:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
It’s the other way around :man_shrugging:
Once you share more details, people can start having a go at whatever your issue is.
Hello @artwheat,
you should focus on Lutris. Lutris normally brings his own wine-versions. You can set another wine-version in the configuration of every game/application.
Also you can use the “Show Protocol”-option in the “right-click”-menu to see whats going on.
:grinning:
Thank you. I’m sorry the post was vague. I’ll update this post with the details about the game asked for and then I’ll read the posts linked in everyone’s replies. Grateful for everyone’s help and I apologies for doing things backward and out of order.
I’m running Manjaro on a System 76 Pangolin (pang11) with 64GB of RAM.
The game is Eve Online. I did grab the last error log after attempting to install:
Started initial process 29629 from /home/artwheat/.local/share/lutris/runtime/winetricks/winetricks -q msdelta
Start monitoring process.
Executing cd /home/artwheat/.local/share/lutris/runtime/winetricks
warning: You are using a 64-bit WINEPREFIX. Note that many verbs only install 32-bit versions of packages. If you encounter problems, please retest in a clean 32-bit WINEPREFIX before reporting a bug.
Using winetricks 20250102-next - sha256sum: d00f5634463f5ed00e3af93160e827cb99ab8c647fe7b31848fed806dac50eb5 with wine-8.0-3001-g39021e609a2 (Staging) and WINEARCH=win64
Executing w_do_call msdelta
Executing load_msdelta
grep: warning: stray \ before /
Executing cabextract -q -d /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_msdelta -L -F x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_0b66cb34258c936f/msdelta.dll /home/artwheat/.cache/winetricks/win7sp1/windows6.1-KB976932-X86.exe
Executing cp -f /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_msdelta/x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_0b66cb34258c936f/msdelta.dll /home/artwheat/Games/eve-online/dosdevices/c:/windows/syswow64/msdelta.dll
Executing cabextract -q -d /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_msdelta -L -F amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_678566b7ddea04a5/msdelta.dll /home/artwheat/.cache/winetricks/win7sp1/windows6.1-KB976932-X64.exe
Executing cp -f /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_msdelta/amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.17514_none_678566b7ddea04a5/msdelta.dll /home/artwheat/Games/eve-online/dosdevices/c:/windows/system32/msdelta.dll
Using native,builtin override for following DLLs: msdelta
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine C:\windows\syswow64\regedit.exe /S C:\windows\Temp\_msdelta\override-dll.reg
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine64 C:\windows\regedit.exe /S C:\windows\Temp\_msdelta\override-dll.reg
Monitored process exited.
Initial process has exited (return code: 0)
Exit with return code 0
Started initial process 30471 from /home/artwheat/.local/share/lutris/runtime/winetricks/winetricks -q arial
Executing w_do_call arial
Executing load_arial
Executing cabextract -q -d /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial /home/artwheat/.cache/winetricks/corefonts/arial32.exe
warning: Running /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wineserver -w. This will hang until all wine processes in prefix=/home/artwheat/Games/eve-online terminate
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine C:\windows\syswow64\regedit.exe /S C:\windows\Temp\_arial\_register-font.reg
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine64 C:\windows\regedit.exe /S C:\windows\Temp\_arial\_register-font.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_304f5183_30471.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_964415d4_30471.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_1f616c49_30471.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_16f0ad00_30471.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_afb17c0c_30471.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_4cd1fddd_30471.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_dae52f18_30471.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_f89c822c_30471.reg
Executing cabextract -q -d /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial /home/artwheat/.cache/winetricks/corefonts/arialb32.exe
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_66d0267b_30471.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_arial/_register-font.reg /tmp/winetricks.hlkYxQnG/_reg_8067e78b_30471.reg
Started initial process 31648 from /home/artwheat/.local/share/lutris/runtime/winetricks/winetricks -q tahoma
Executing w_do_call tahoma
Executing load_tahoma
Executing cabextract -q -d /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_tahoma /home/artwheat/.cache/winetricks/tahoma/IELPKTH.CAB
/home/artwheat/.cache/winetricks/tahoma/IELPKTH.CAB: WARNING; possible 5592 extra bytes at end of file.
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine C:\windows\syswow64\regedit.exe /S C:\windows\Temp\_tahoma\_register-font.reg
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine64 C:\windows\regedit.exe /S C:\windows\Temp\_tahoma\_register-font.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_tahoma/_register-font.reg /tmp/winetricks.GJAlxL14/_reg_a6378261_31648.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_tahoma/_register-font.reg /tmp/winetricks.GJAlxL14/_reg_2381d506_31648.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_tahoma/_register-font.reg /tmp/winetricks.GJAlxL14/_reg_21e53125_31648.reg
Executing cp /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_tahoma/_register-font.reg /tmp/winetricks.GJAlxL14/_reg_4779f8a8_31648.reg
Started initial process 32577 from /home/artwheat/.local/share/lutris/runtime/winetricks/winetricks -q vcrun2022
Executing w_do_call vcrun2022
Executing load_vcrun2022
Using native,builtin override for following DLLs: concrt140 msvcp140 msvcp140_1 msvcp140_2 msvcp140_atomic_wait msvcp140_codecvt_ids vcamp140 vccorlib140 vcomp140 vcruntime140
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine C:\windows\syswow64\regedit.exe /S C:\windows\Temp\_vcrun2022\override-dll.reg
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine64 C:\windows\regedit.exe /S C:\windows\Temp\_vcrun2022\override-dll.reg
warning: Checksum for /home/artwheat/.cache/winetricks/vcrun2022/vc_redist.x86.exe did not match, but --force was used, so ignoring and trying anyway.
Executing cabextract -q --directory=/home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_vcrun2022/win32 /home/artwheat/.cache/winetricks/vcrun2022/vc_redist.x86.exe -F a10
Executing cabextract -q --directory=/home/artwheat/Games/eve-online/dosdevices/c:/windows/syswow64 /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_vcrun2022/win32/a10 -F msvcp140.dll
/home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_vcrun2022/win32/a10: WARNING; possible 10344 extra bytes at end of file.
Executing cd /home/artwheat/.cache/winetricks/vcrun2022
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine vc_redist.x86.exe /q
Using native,builtin override for following DLLs: vcruntime140_1
warning: Checksum for /home/artwheat/.cache/winetricks/vcrun2022/vc_redist.x64.exe did not match, but --force was used, so ignoring and trying anyway.
Executing cabextract -q --directory=/home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_vcrun2022/win64 /home/artwheat/.cache/winetricks/vcrun2022/vc_redist.x64.exe -F a11
Executing cabextract -q --directory=/home/artwheat/Games/eve-online/dosdevices/c:/windows/system32 /home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_vcrun2022/win64/a11 -F msvcp140.dll
/home/artwheat/Games/eve-online/dosdevices/c:/windows/temp/_vcrun2022/win64/a11: WARNING; possible 10328 extra bytes at end of file.
Executing /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine vc_redist.x64.exe /q
Started initial process 33797 from /home/artwheat/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine /home/artwheat/.cache/lutris/installer/eve-online/setup/eve-online-latest+Setup.exe
https://www.reddit.com/r/Eve/comments/1hqjm4a/linux_lutris_eve_online_eveo_preview/
I wanted to share my inxi results:
  Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 14.2.1 clocksource: hpet avail: acpi_pm
    root=UUID=375b46aa-dcab-4ba8-a8be-2c8d4f96d00e rw quiet
    apparmor=1 security=apparmor
    resume=UUID=98ea8ab1-10a8-4d8b-a3f1-af58e6587c0f
    udev.log_priority=3
  Desktop: i3 v: 4.24 with: i3bar tools: xautolock avail: i3lock
    dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: System76 product: Pangolin v: pang11
    serial: N/A
  Mobo: System76 model: Pangolin v: pang11 serial: N/A
    uuid: f0960000-0000-1000-b60c-80fa5b9dbe43 UEFI: INSYDE
    v: 1.07.13_S3 date: 06/28/2022
  ID-1: BAT0 charge: 33.7 Wh (100.0%) condition: 33.7/49.4 Wh (68.2%)
    volts: 16.2 min: 15.2 model: Notebook BAT type: Li-ion
    serial: <filter> status: full
  System RAM: total: 64 GiB available: 62.14 GiB used: 4.04 GiB (6.5%)
  Device-1: Channel-A DIMM 0 type: DDR4 detail: synchronous
    unbuffered (unregistered) size: 32 GiB speed: 3200 MT/s volts:
    curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64 total: 64
    manufacturer: Crucial part-no: CT32G4SFD832A.C16FE
    serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR4 detail: synchronous
    serial: <filter>
  Slot: 1 type: PCIe status: available info: J10 length: short
    volts: 3.3 bus-ID: 0200:00:01.1
  Slot: 2 type: PCIe status: available info: J79 length: short
    volts: 3.3 bus-ID: 0200:00:01.6
  Slot: N/A type: N/A status: available info: M.2, J92 length: short
    volts: 3.3 bus-ID: 0200:00:01.2
  Slot: N/A type: N/A status: available info: M.2, J90 length: short
    volts: 3.3 bus-ID: 0200:00:01.4
  Slot: N/A type: N/A status: available info: M.2, J19 length: short
    volts: 3.3 bus-ID: 0200:00:01.7
  Slot: 6 type: PCIe status: available length: short volts: 3.3
    bus-ID: 0200:00:01.5
  Info: model: AMD Ryzen 7 5700U with Radeon Graphics socket: FP6
    bits: 64 type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check
    built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x68 (104) stepping: 1 microcode: 0x8608108
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB
    L2: 4 MiB desc: 8x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 400 min/max: 400/4372 boost: enabled
    base/boost: 1800/4350 scaling: driver: amd-pstate-epp
    governor: powersave volts: 1.2 V ext-clock: 100 MHz cores: 1: 400
    2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400
    11: 400 12: 400 13: 400 14: 400 15: 400 16: 400 bogomips: 57505
  Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx
    avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
    cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists extapic extd_apicid f16c flushbyasid fma fpu
    fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
    lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae
    pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc
    perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
    svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1
    xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled
    with STIBP protection
  Type: spec_store_bypass mitigation: Speculative Store Bypass
    disabled via prctl
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user
    pointer sanitization
  Type: spectre_v2 mitigation: Retpolines; IBPB: conditional;
    STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI:
    Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Lucienne
    vendor: CLEVO/KAPOK driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,DP-2 bus-ID: 05:00.0 chip-ID: 1002:164c class-ID: 0300
    temp: 39.0 C
  Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3
    chip-ID: 5986:9102 class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.16 compositor: Picom v: 12.5
    driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1502
    built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142
    gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
    blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown flag 2
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0
    drv: radeonsi device: 1 drv: swrast gbm: drv: radeonsi surfaceless:
    drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa
    v: 25.0.3-arch1.1 glx-v: 1.4 direct-render: yes renderer: AMD
    Radeon Graphics (radeonsi renoir ACO DRM 3.61 6.12.21-4-MANJARO)
    device-ID: 1002:164c memory: 500 MiB unified: no
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High
    Definition Audio vendor: CLEVO/KAPOK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio
    Coprocessor vendor: CLEVO/KAPOK driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
    chip-ID: 1022:15e2 class-ID: 0480
    vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.4.1 status: n/a (root, process) with:
    3: pipewire-alsa type: plugin 4: pw-jack type: plugin
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit
    Ethernet vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
  Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer
    driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:4
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter>
    bt-v: 5.2 lmp-v: 11 status: discoverable: yes pairing: yes
    class-ID: 6c010c
  Local Storage: total: 465.76 GiB used: 130.77 GiB (28.1%)
  SMART Message: Required tool smartctl not installed. Check
    --recommends
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: 2B2QEXM7 temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 228.12 GiB size: 223.48 GiB (97.97%)
    used: 130.77 GiB (58.5%) fs: ext4 block-size: 4096 B
    dev: /dev/nvme0n1p4 maj-min: 259:4 label: manjaroPartition
    uuid: 375b46aa-dcab-4ba8-a8be-2c8d4f96d00e
    used: 316 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
    maj-min: 259:3 label: LINUXBOOT uuid: 4D0C-504E
    zswap: no
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5 label: linuxSwap
    uuid: 98ea8ab1-10a8-4d8b-a3f1-af58e6587c0f
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat
    label: N/A uuid: 1E3A-0019
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 232.85 GiB fs: ntfs
    label: win10 uuid: 1581B0F249DCF361
  Device-1: 1-1:2 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1
  Device-1: 3-3:4 info: Intel AX200 Bluetooth type: bluetooth
    driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-2: 3-4:3 info: Bison BisonCam NB Pro type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 5986:9102 class-ID: 0e02
  System Temperatures: cpu: 49.1 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1445 libs: 433 tools: pamac,yay
    1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    4: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    5: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    6: https://mirrors2.manjaro.org/stable/$repo/$arch
    7: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    8: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    10: https://mirror.init7.net/manjaro/stable/$repo/$arch
    11: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    12: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    13: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    14: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    15: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    18: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    19: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    20: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    21: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    22: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    23: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    25: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    26: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    28: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    29: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    31: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    32: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    33: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    34: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    36: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    37: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    38: https://manjaro.kurdy.org/stable/$repo/$arch
    39: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    40: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    41: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    42: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    44: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    45: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    46: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    47: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    48: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    49: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    50: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    51: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    52: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    53: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    54: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    55: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    56: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    57: https://manjaro.ynh.ovh/stable/$repo/$arch
    58: https://mirror.23m.com/manjaro/stable/$repo/$arch
    59: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    60: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    61: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    62: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    63: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 382
  1: cpu: 100% command: ps pid: 3912 mem: 3.84 MiB (0.0%)
  2: cpu: 11.0% command: soffice.bin pid: 3852 mem: 293.9 MiB (0.4%)
  3: cpu: 3.4% command: brave pid: 1460 mem: 507.7 MiB (0.7%)
  4: cpu: 3.1% command: sudo pid: 3895 mem: 9.12 MiB (0.0%)
  5: cpu: 1.9% command: Xorg pid: 946 mem: 103.9 MiB (0.1%)
  Memory top: 5 of 382
  1: mem: 507.7 MiB (0.7%) command: brave pid: 1460 cpu: 3.4%
  2: mem: 315.7 MiB (0.4%) command: brave pid: 1582 cpu: 1.3%
  3: mem: 293.9 MiB (0.4%) command: soffice.bin pid: 3852 cpu: 11.0%
  4: mem: 290.7 MiB (0.4%) command: brave pid: 1729 cpu: 1.4%
  5: mem: 255.6 MiB (0.4%) command: brave pid: 1583 cpu: 0.8%
  Processes: 382 Power: uptime: 20m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 24.84 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 257
  Compilers: gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: alacritty inxi: 3.3.38
where is the vulkan API ???
I think you need that
I looked at the last error Lutris gave me and found a config file setting I could modify and it worked. Here is what an AI search suggested:
To address this issue, you can modify the RLIMIT_NICE limit for your user. One method involves editing the /etc/security/limits.conf file to increase the RLIMIT_NICE limit for your user.
 Alternatively, you can use a script or configuration change to allow Wine to bypass this limitation, such as setting up a group with elevated privileges as described in the NixOS Discourse thread.
Here is an example of how to modify the /etc/security/limits.conf file:
username hard rtprio 98
username hard memlock unlimited
username hard nice -11
Replace username with your actual username. This configuration allows the user to set a higher nice value, potentially resolving the issue with setpriority.
I made a backup of the config file and tried it, though I believe copying things off the internet to try without knowing what you’re doing is a bit risky. For example, I don’t know if these settings opened up a security vulnerability in any way. I need to go back and learn what each of these commands do.
The Wine settings for this game were: GE-Proton with Esync and Fsync disabled. I don’t know anything about the missing Vulkan API. Would that make things run better? BTW: Running this game in Manjaro seems to use fewer resources than running it in Windows.
Something else I need to keep an eye on the cache files that get produced. They filled up my drive but that is a separate issue for a separate forum post.
I feel I know just enough to be dangerous. I didn’t want to corrupt my system (though everything is backed up). Thanks for pointing me to address the issue in Lutris. I really didn’t know if it was a Wine, Lutris or system issue. I need to be more patient and less lazy in the future. I am grateful for everyone in the communities help.
I’m going to mark this as solved unless someone else has any concerns about my fix or anything else they want to share.
