Will changing ulimit cause any problems?
When i execute the command ulimit, the output is unlimited. This is the default value.
I have been following this issue and i was wondering, if i set ulimit to a lower number like 4096, will that cause any problems in other parts of the system ?
System info
  Kernel: 6.10.6-10-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=d37c6e4a-949c-4370-8055-0f9e011a3409 rw quiet
    cryptdevice=UUID=99cf4234-a381-4eff-9a33-abb366e019d2:luks-99cf4234-a381-4eff-9a33-abb366e019d2
    root=/dev/mapper/luks-99cf4234-a381-4eff-9a33-abb366e019d2 splash
    resume=/dev/mapper/luks-97e9302e-784a-4db6-a839-80af7dbb8188
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_x11 with: krunner
    dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK MAX WIFI (MS-7C91)
    v: 1.0 serial: <filter> uuid: be5679e8-c7c8-c813-a8b1-047c16beaab1
    UEFI: American Megatrends LLC. v: 2.60 date: 10/10/2023
  Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP
    arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
    smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
    desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2200 min/max: 2200/5083 boost: enabled
    base/boost: 3400/5050 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2200
    5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
    21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200 28: 2200
    29: 2200 30: 2200 31: 2200 32: 2200 bogomips: 217717
    affected
  Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: Micro-Star MSI
    driver: nvidia v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none off: DP-2 empty: DP-1,DP-3,HDMI-A-1
    bus-ID: 2b:00.0 chip-ID: 10de:2487 class-ID: 0300
  Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x333mm (23.70x13.11")
    s-diag: 688mm (27.09") monitors: <missing: xrandr>
  Monitor-1: DP-2 model: MSI G274QPF serial: <filter> built: 2023
    res: 2560x1440 dpi: 108 gamma: 1.2 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 640x480
  Monitor-2: Unknown-1 size-res: N/A modes: 1024x768
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: gbm,wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.107.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    memory: 11.72 GiB
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.107.02
    device-ID: 10de:2487 surfaces: xcb,xlib
  Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 2b:00.1 chip-ID: 10de:228b class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.10.6-10-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: n/a (root, process) with:
  Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 14c3:0608
    class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
  IF: enp42s0 state: down mac: <filter>
  IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:6 chip-ID: 0e8d:0608
  Local Storage: total: 1.82 TiB used: 212.5 GiB (11.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: MSI model: M480 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM80.0 temp: 41.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 113d 5h cycles: 291
    read-units: 10,311,063 [5.27 TB] written-units: 22,824,898 [11.6 TB]
  ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 212.5 GiB (11.8%)
    fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-99cf4234-a381-4eff-9a33-abb366e019d2
    used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-97e9302e-784a-4db6-a839-80af7dbb8188
  System Temperatures: cpu: 49.5 C mobo: 48.0 C gpu: nvidia temp: 54 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Memory: total: 32 GiB available: 31.26 GiB used: 11 GiB (35.2%)
  Processes: 658 Power: uptime: 7h 40m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 1585 pm: pacman pkgs: 1532 libs: 400 tools: pamac pm: appimage
    pkgs: 0 pm: flatpak pkgs: 53 Compilers: clang: 18.1.8 gcc: 14.2.1
    Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.32 running-in: konsole
    inxi: 3.3.36
It will for many things that needs a bigger value, like games on Steam/Proton.
Output of ulimit -n and ulimit -Hn?
You forgot to read the last comment there.
Type ulimit -n and see what you actual limit is. I bet it’s 1024.
You probably don’t want to set it even lower, but higher instead.
ulimit -n → 1024
ulimit -Hn → 524288
yea true, instead of ulimit -n i typed ulimit
So here are your soft and hard limits. You can change the soft limit up to the hard limit value, if your application requires it. Actually from the look of it you would need to increase it from your default soft limit regarding the issue you linked.
So i increase it like to how much ?
I don’t know you’re the one willing to modify that setting :slight_smile:
Read the link you posted people replied there regarding your issue.
