My Device Properties
Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
root=UUID=aa9cc6f8-1276-4378-ba63-b37524bc0e66 quiet splash
udev.log_priority=3 kernel.sysrq=1
rootflags=defaults,discard=async,ssd,subvol=timeshift-btrfs/snapshots/2023-08-19_09-09-43/@
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Portable System: Dell product: Inspiron N4050 v: N/A
serial: <superuser required> Chassis: type: 8 serial: <superuser required>
Mobo: Dell model: 0J6GG1 v: A08 serial: <superuser required> BIOS: Dell
v: A08 date: 08/03/2012
ID-1: BAT0 charge: 7.9 Wh (100.0%) condition: 7.9/48.8 Wh (16.2%)
volts: 12.5 min: 11.1 model: SMP DELL 8NH5525 type: Li-ion serial: <filter>
status: full
Info: model: Intel Celeron B815 bits: 64 type: MCP arch: Sandy Bridge
level: v2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 1596 min/max: 800/1600 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1596 2: 1596 bogomips: 6387
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0106
class-ID: 0300
Device-2: Microdia Laptop_Integrated_Webcam_1.3M driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:4
chip-ID: 0c45:643e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: LG Display 0x02e9 built: 2010 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 3.3 Mesa 23.1.5 renderer: Mesa Intel HD Graphics 2000 (SNB
GT1) direct-render: Yes
vendor: Dell 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter
vendor: Quanta Microsystems driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 168c:002e class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 536.57 GiB used: 121.63 GiB (22.7%)
ID-1: /dev/sda maj-min: 8:0 model: VENTUZ SATA SSD 256GB size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 9B0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST320LT020-9YG142
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: DEM1 scheme: GPT
ID-1: / raw-size: 52.43 GiB size: 52.43 GiB (100.00%)
used: 35.86 GiB (68.4%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /boot raw-size: 4.19 GiB size: 4.19 GiB (100.00%)
used: 156 MiB (3.6%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 104.86 GiB size: 102.65 GiB (97.90%)
used: 85.62 GiB (83.4%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-4: /var/log raw-size: 52.43 GiB size: 52.43 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.83 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 2 dev: /dev/zram0
System Temperatures: cpu: 76.0 C mobo: N/A
Fan Speeds (rpm): cpu: 3988
Processes: 214 Uptime: 47m wakeups: 1 Memory: total: 8 GiB
available: 7.67 GiB used: 3.4 GiB (44.3%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1433 libs: 374 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.29
Hello, my name is Nauval. I’am new to Manjaro OS.
I cant connect to my University Wifi, its using WPA2 Enterprise. But my phone based on Android 13 has TOFU (Trust On First Use) which retrieve CA from wifi server first, so my phone could connect to it
But when on Manjaro or Arch Based linux, i cant connect to my University Wifi. Even with using Wifi dongle, It always wants me to enter password every time.
Configuration using PEAP-MSCHAPv2, No Certs.
Username and Password Only
Dmesg log using device wifi:
[ 3488.001192] wlp9s0: RX AssocResp from a0:3d:6f:89:1f:41 (capab=0x1431 status=0 aid=109)
[ 3488.001401] wlp9s0: associated
[ 3488.001523] ath: EEPROM regdomain: 0x8168
[ 3488.001527] ath: EEPROM indicates we should expect a country code
[ 3488.001528] ath: doing EEPROM country->regdmn map search
[ 3488.001530] ath: country maps to regdmn code: 0x3
[ 3488.001531] ath: Country alpha2 being used: ID
[ 3488.001533] ath: Regpair used: 0x3
[ 3488.001535] ath: regdomain 0x8168 dynamically updated by country element
[ 3488.057240] wlp9s0: Limiting TX power to 20 (20 - 0) dBm as advertised by a0:3d:6f:89:1f:41
[ 3491.124022] wlp9s0: deauthenticating from a0:3d:6f:89:1f:41 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3507.077805] wlp9s0: authenticate with a0:3d:6f:89:1f:41
[ 3507.077830] wlp9s0: 80 MHz not supported, disabling VHT
[ 3507.105152] wlp9s0: send auth to a0:3d:6f:89:1f:41 (try 1/3)
[ 3507.107179] wlp9s0: authenticated
[ 3507.109799] wlp9s0: associate with a0:3d:6f:89:1f:41 (try 1/3)
[ 3507.133527] wlp9s0: RX AssocResp from a0:3d:6f:89:1f:41 (capab=0x1431 status=0 aid=109)
[ 3507.133703] wlp9s0: associated
[ 3507.133832] ath: EEPROM regdomain: 0x8168
[ 3507.133836] ath: EEPROM indicates we should expect a country code
[ 3507.133838] ath: doing EEPROM country->regdmn map search
[ 3507.133839] ath: country maps to regdmn code: 0x3
[ 3507.133841] ath: Country alpha2 being used: ID
[ 3507.133842] ath: Regpair used: 0x3
[ 3507.133844] ath: regdomain 0x8168 dynamically updated by country element
[ 3507.201538] wlp9s0: Limiting TX power to 20 (20 - 0) dBm as advertised by a0:3d:6f:89:1f:41
[ 3510.236015] wlp9s0: deauthenticating from a0:3d:6f:89:1f:41 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3521.344236] wlp9s0: authenticate with a0:3d:6f:89:1f:41
[ 3521.344262] wlp9s0: 80 MHz not supported, disabling VHT
[ 3521.370546] wlp9s0: send auth to a0:3d:6f:89:1f:41 (try 1/3)
[ 3521.386156] wlp9s0: authenticated
[ 3521.389808] wlp9s0: associate with a0:3d:6f:89:1f:41 (try 1/3)
[ 3521.493139] wlp9s0: associate with a0:3d:6f:89:1f:41 (try 2/3)
[ 3521.606767] wlp9s0: associate with a0:3d:6f:89:1f:41 (try 3/3)
[ 3521.713135] wlp9s0: association with a0:3d:6f:89:1f:41 timed out
Using dongle :
[ 3748.877435] wlan0: authenticated
[ 3748.883066] wlan0: associate with a0:3d:6f:89:1f:42 (try 1/3)
[ 3748.886535] wlan0: RX AssocResp from a0:3d:6f:89:1f:42 (capab=0x1431 status=0 aid=137)
[ 3748.894633] wlan0: associated
[ 3748.894809] ath: EEPROM regdomain: 0x8168
[ 3748.894813] ath: EEPROM indicates we should expect a country code
[ 3748.894815] ath: doing EEPROM country->regdmn map search
[ 3748.894816] ath: country maps to regdmn code: 0x3
[ 3748.894818] ath: Country alpha2 being used: ID
[ 3748.894820] ath: Regpair used: 0x3
[ 3748.894822] ath: regdomain 0x8168 dynamically updated by country element
[ 3748.974467] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by a0:3d:6f:89:1f:42
[ 3751.903106] wlan0: deauthenticating from a0:3d:6f:89:1f:42 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3767.342044] wlan0: authenticate with a0:3d:6f:89:1f:42
[ 3767.375202] wlan0: send auth to a0:3d:6f:89:1f:42 (try 1/3)
[ 3767.378423] wlan0: authenticated
[ 3767.396416] wlan0: associate with a0:3d:6f:89:1f:42 (try 1/3)
[ 3767.402539] wlan0: RX AssocResp from a0:3d:6f:89:1f:42 (capab=0x1431 status=0 aid=137)
[ 3767.409512] wlan0: associated
[ 3767.409585] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by a0:3d:6f:89:1f:42
[ 3767.409686] ath: EEPROM regdomain: 0x8168
[ 3767.409690] ath: EEPROM indicates we should expect a country code
[ 3767.409691] ath: doing EEPROM country->regdmn map search
[ 3767.409693] ath: country maps to regdmn code: 0x3
[ 3767.409694] ath: Country alpha2 being used: ID
[ 3767.409696] ath: Regpair used: 0x3
[ 3767.409698] ath: regdomain 0x8168 dynamically updated by country element
[ 3770.439994] wlan0: deauthenticating from a0:3d:6f:89:1f:42 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3782.218623] wlan0: authenticate with a0:3d:6f:89:1f:42
[ 3782.251854] wlan0: send auth to a0:3d:6f:89:1f:42 (try 1/3)
[ 3782.253723] wlan0: authenticated
[ 3782.256414] wlan0: associate with a0:3d:6f:89:1f:42 (try 1/3)
[ 3782.359759] wlan0: associate with a0:3d:6f:89:1f:42 (try 2/3)
[ 3782.463382] wlan0: associate with a0:3d:6f:89:1f:42 (try 3/3)
[ 3782.569734] wlan0: association with a0:3d:6f:89:1f:42 timed out
