Wifi/wlan prefer ipv4 and reconfigure connection without ipv6?
How can I make plasma network manager to use ipv4 primary?
I already have set ipv6 to ignore (DHCP auto) but ifconfig still shows the ipv6 connection.
How do I get this ipv6 address out and reconfigure it in plasma?
If IPv6 is available it will be always preferred. Even if you disable it NetworkManager, it might auto-configure it itself.
If you have problems with IPv6 you should disable it via a Kernel parameter. You need to reboot to see an affect. An alternativ is to disable it via sysctl. But the Kernel parameter should be preferred.
https://wiki.archlinux.org/title/IPv6#Disable_functionality
