Wifi verbinding weg na slaapmodus
Hallo,
Ik heb recent Manjaro geinstalleerd op twee laptops, een Asus VivoBook en een Lenovo Legion. Op de Lenovo raak ik de wifi verbinding kwijt als het systeem in slaapmodus is geweest. D.w.z. als hij wakker wordt is de verbinding weg en komt ook niet terug.
Ik zie dit als melding:
journalctl --boot 0 --unit NetworkManager.service --follow --no-hostname
jan 31 12:00:05 NetworkManager[610]: <info>  [1769857205.3286] device (p2p-dev-wlp4s0): state change: unavaila
ble -> unmanaged (reason 'unmanaged-link-not-init', managed-type: 'removed')
jan 31 12:00:05 NetworkManager[610]: <info>  [1769857205.3698] radio killswitch /sys/devices/pci0000:00/0000:0
0:02.2/0000:04:00.0/ieee80211/phy0/rfkill3 disappeared
jan 31 12:00:06 NetworkManager[610]: <info>  [1769857206.2661] device (wlan0): driver supports Access Point (A
P) mode
jan 31 12:00:06 NetworkManager[610]: <info>  [1769857206.2669] manager: (wlan0): new 802.11 Wi-Fi device (/org
/freedesktop/NetworkManager/Devices/5)
jan 31 12:00:06 NetworkManager[610]: <info>  [1769857206.2711] rfkill5: found Wi-Fi radio killswitch (at /sys/
devices/pci0000:00/0000:00:02.2/0000:04:00.0/ieee80211/phy1/rfkill5) (driver iwlwifi)
jan 31 12:00:06 NetworkManager[610]: <info>  [1769857206.2757] device (wlan0): interface index 4 renamed iface
from 'wlan0' to 'wlp4s0'
jan 31 12:00:06 NetworkManager[610]: <info>  [1769857206.2890] device (wlp4s0): state change: unmanaged -> una
vailable (reason 'managed', managed-type: 'external')
jan 31 12:00:14 NetworkManager[610]: <warn>  [1769857214.2859] platform-linux: do-change-link[4]: failure 5 (I
nvoer-/uitvoerfout)
jan 31 12:00:14 NetworkManager[610]: <info>  [1769857214.2866] device (wlp4s0): set-hw-addr: set MAC address t
o DE:F8:1B:CB:37:CB (scanning)
jan 31 12:00:20 NetworkManager[610]: <warn>  [1769857220.7611] platform-linux: do-change-link[4]: failure 110
(Verbinding is verlopen)
jan 31 12:00:25 NetworkManager[610]: <error> [1769857225.7637] device (wlp4s0): Couldn't initialize supplicant
interface: Tijd is verlopen
jan 31 12:00:35 NetworkManager[610]: <warn>  [1769857235.9687] device (wlp4s0): re-acquiring supplicant interface (#1).
Ik heb gezocht naar soortgelijke topics, maar daar kom ik niet echt verder mee. Iemand een idee hoe dit op te lossen?
Bij voorbaat dank.
[MiniHowTo] Present code or command output
What is a Quark?
Neem me niet kwalijk voor mijn slordige post en bedankt voor de aanpassing. Ik zal er een volgende keer aan denken.
Graag gedaan. Hopelijk kan iemand je snel helpen met je probleem. :wink:
