WiFi is toggled whenever I’m opening the lid of my laptop. Setting “Do Nothing” in the Energy Saving settings doesn’t help.It’s happening on both AC power and battery. Bluetooth is unaffected. I had previously posted about it in this thread but what seemed like a solution stopped working after a few reboots.
systemd-inhibit --list
WHO UID USER PID COMM WHAT WHY MODE
ModemManager 0 root 527 ModemManager sleep ModemManager needs to reset devices delay
NetworkManager 0 root 474 NetworkManager sleep NetworkManager needs to turn off networks delay
UPower 0 root 875 upowerd sleep Pause device polling delay
Discord 1000 sintan 3413 Discord sleep Application cleanup before suspend delay
PowerDevil 1000 sintan 1140 org_kde_powerde handle-power-key:handle-suspend-key:handle-hibernate-key:handle-lid-switch KDE handles power events block
Screen Locker 1000 sintan 1083 ksmserver sleep Ensuring that the screen gets locked before going to sleep delay
6 inhibitors listed.
My systemd version is 247.2-1.
inxi -Fazy
Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=fe64fafd-1c2a-4b55-846f-c264196ff166 rw nomce "acpi_osi=Windows
2018" quiet resume=UUID=4517ac81-4ac6-42a0-8e7a-a5870b5f98df
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: GDM 3.38.2.1, SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Laptop 14-bf1xx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 83CE v: 59.38 serial: <filter> UEFI: Insyde v: F.31
date: 10/30/2017
ID-1: BAT1 charge: 35.3 Wh condition: 42.3/42.3 Wh (100%) volts: 13.1/11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: Charging
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 L2 cache: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 32012
Speed: 700 MHz min/max: 400/1800 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 700 5: 700 6: 700 7: 700 8: 700
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
driver: nvidia v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:134d
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 1-5:4 chip ID: 04f2:b5d6
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 115 s-size: 424x238mm (16.7x9.4")
s-diag: 486mm (19.1")
Monitor-1: eDP-1 res: 1920x1080 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.10.7-3-MANJARO
vendor: Hewlett-Packard driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 3000 bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3000
bus ID: 03:00.0 chip ID: 8086:095a
Local Storage: total: 1.03 TiB used: 558.98 GiB (53.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: RSM7
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SD8SN8U-128G-1006
size: 119.24 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0006
ID-1: / raw size: 50 GiB size: 48.72 GiB (97.43%) used: 38.9 GiB (79.8%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21
ID-2: /boot/efi raw size: 277 MiB size: 276.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw size: 60.87 GiB size: 59.67 GiB (98.02%)
used: 32.17 GiB (53.9%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
Kernel: swappiness: 5 (default 60) cache pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 8.1 GiB used: 3.33 GiB (41.1%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 37.5 C mobo: 29.8 C
Processes: 327 Uptime: 1d 21h 20m wakeups: 13 Memory: 7.69 GiB
used: 4.69 GiB (61.0%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1983 pacman: 1976 lib: 457 flatpak: 1 snap: 6 Shell: fish v: 3.1.2
running in: server inxi: 3.2.02
