Hi,
My Wifi on my XPS 13 (9310, AX500 chipset) suddenly cut out this morning and would not come back on. The wifi works on Windows but does not in Manjaro. Issues persist through kernel change reboots, complete shutdowns, etc. wifi-menu
gives me a “invalid interface specification,” and rfkill list all
gives this:
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s13f0u3u1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:05:1b:6a:22:fe brd ff:ff:ff:ff:ff:ff
inet 10.129.23.226/23 brd 10.129.23.255 scope global dynamic noprefixroute enp0s13f0u3u1
valid_lft 1580sec preferred_lft 1580sec
inet6 fe80::11e1:c0d6:efae:a24b/64 scope link noprefixroute
lspci -k
(the important part)
Subsystem: Rivet Networks Device a501
Kernel modules: ath11k_pci
^ no kernel driver in use, but i’m not sure what to do about that
And finally general information:
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=73f64c48-669c-441a-a105-5fdb4b98758c rw quiet apparmor=1
Desktop: i3 4.19.1 info: i3bar vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: XPS 13 9310 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0DMPXV v: A00 serial: <filter> UEFI: Dell v: 3.0.4
date: 07/16/2021
ID-1: BAT0 charge: 39.0 Wh (86.1%) condition: 45.3/51.0 Wh (88.9%)
volts: 8.5 min: 7.6 model: BYD DELL FP86V0A type: Li-poly serial: <filter>
status: Charging
RAM: total: 31.08 GiB used: 2.74 GiB (8.8%)
Info: Quad Core model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 88
cache: L2: 12 MiB bogomips: 47936
Speed: 1247 MHz min/max: 400/4800 MHz Core speeds (MHz): 1: 1247 2: 1259
3: 1052 4: 1347 5: 1134 6: 1238 7: 1014 8: 942
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: USB C USB C Video Adaptor type: USB driver: N/A bus-ID: 3-4.4:8
chip-ID: 25a4:9311 class-ID: 1100 serial: <filter>
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 0c45:672a class-ID: 0e02
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1014x317mm (39.9x12.5")
s-diag: 1062mm (41.8")
Monitor-1: eDP-1 res: 1920x1200 hz: 60 dpi: 169 size: 288x180mm (11.3x7.1")
diag: 340mm (13.4")
Monitor-2: DP-1-3 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Qualcomm QCA6390 Wireless Network Adapter [AX500-DBS ]
vendor: Rivet Networks driver: N/A modules: ath11k_pci bus-ID: 72:00.0
chip-ID: 17cb:1101 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-3.1:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s13f0u3u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 982.98 GiB used: 121.92 GiB (12.4%)
model: PC SN730 NVMe WDC 1024GB size: 953.87 GiB block-size: physical: 512 B
rev: 11150012 temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Glide
size: 29.11 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.27 scheme: MBR
ID-1: / raw-size: 390.62 GiB size: 383.43 GiB (98.16%)
used: 35.65 GiB (9.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: 73f64c48-669c-441a-a105-5fdb4b98758c
ID-2: /boot/efi raw-size: 190 MiB size: 186 MiB (97.89%)
used: 105.4 MiB (56.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: FE71-E7E0
ID-3: /mnt/OS raw-size: 544.93 GiB size: 544.93 GiB (100.00%)
used: 86.16 GiB (15.8%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: OS uuid: 56D87038D8701907
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: 920EF7E40EF7BEF3
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 15.66 GiB fs: ntfs label: Image
uuid: 60DEF82ADEF7F65E
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 1.37 GiB fs: ntfs
label: DELLSUPPORT uuid: C05E64EA5E64DAA4
ID-5: /dev/sda1 maj-min: 8:1 size: 29.11 GiB fs: vfat label: UBUNTU 20_0
uuid: 06BF-64E6
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-3: 2-3:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 2-3.1:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:533c class-ID: ff00
Hub-5: 3-4:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 3-4.2:6 info: SanDisk Cruzer Glide type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5575 class-ID: 0806 serial: <filter>
Device-2: 3-4.4:8 info: USB C USB C Video Adaptor type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 25a4:9311
Device-3: 3-6:4 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-6: 3-8:5 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0801 class-ID: 0900
Device-1: 3-8.1:7 info: VIA Labs USB 2.0 BILLBOARD type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 2109:0103
Device-2: 3-8.2:9 info: Razer USA RZ01-0325 Gaming Mouse [Viper Mini]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:008a class-ID: 0300
Device-3: 3-8.3:10 info: Wacom CTL-472 [One by Wacom (S)] type: Mouse,HID
power: 498mA chip-ID: 056a:037a class-ID: 0300 serial: <filter>
Device-4: 3-8.4:11 info: Kingston HyperX Alloy Origins Core
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 0951:16e6 class-ID: 0300
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (RPM): cpu: 4681 fan-2: 4418
Processes: 250 Uptime: 12m wakeups: 25 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1381 pacman: 1374 lib: 400
flatpak: 0 snap: 7 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.08
