Wifi suddenly not working with router using WPA3
Issue is way complicated, because I have reinstalled OS not so long time ago, I have reverted miopen-hip package to older version, until fix for that will be released. Everything worked well until yesterday, I was connecting to wpa3 supported router and after about half hour simply lost internet connection, even can’t ping locally available server. But strange part, I am able access PC from macbook on same network. Reboot not helping, tried every configuration in networks section, even changing to wpa2. Connection always are created but no internet or access to local resources. Also updated kernel to 6.14, hopefully maybe that fixes that issue. After that I started to gather log records and not a lot is there happening. I can see this line when I am connecting to working wifi, but for wpa3 this is missing from log:
[1749652665.2022] manager: NetworkManager state is now CONNECTED_GLOBAL
And every time after connecting I got this one, for working networks I don’t see that.
systemd	NetworkManager-dispatcher.service: Deactivated successfully.
The last thing what I tried was installing dhcpcd and things got really interesting. For working wifi nothing changed, but now I am able to keep connection with wpa3, still till getting randomly message about previous mentioned dispacher deactivation after 5 minutes, but restarting dhcpcd restores connectivity after that.
Here are log from systemctl status NetworkManager
NetworkManager.service - Network Manager
    Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
    Active: active (running) since Wed 2025-06-11 17:37:31 EEST; 10min ago
Invocation: 92587afbc6be40a3b04eed8284c6f895
      Docs: man:NetworkManager(8)
  Main PID: 1597 (NetworkManager)
     Tasks: 6 (limit: 76810)
    Memory: 15.7M (peak: 17.9M)
       CPU: 416ms
    CGroup: /system.slice/NetworkManager.service
            └─1597 /usr/bin/NetworkManager --no-daemon
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.0277] dhcp4 (wlp6s0): activation: beginning transaction (timeout
in 45 seconds)
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.0476] dhcp4 (wlp6s0): state changed new lease, address=192.168.88
.248, acd pending
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.2053] dhcp4 (wlp6s0): state changed new lease, address=192.168.88
.248
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.2066] policy: set 'MikroTik-DDDA78' (wlp6s0) as default for IPv4
routing and DNS
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.2113] device (wlp6s0): state change: ip-config -> ip-check (reaso
n 'none', managed>
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.2120] device (wlp6s0): state change: ip-check -> secondaries (rea
son 'none', manag>
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.2121] device (wlp6s0): state change: secondaries -> activated (re
ason 'none', mana>
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.2123] manager: NetworkManager state is now CONNECTED_SITE
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.2128] device (wlp6s0): Activation: successful, device activated.
Jun 11 17:46:38 NetworkManager[1597]: <info>  [1749653198.2447] audit: op="statistics" interface="wlp6s0" ifindex=3 args="2
000" pid=2005 uid>
And from resolvectl
Protocols: +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
   resolv.conf mode: stub
 Current DNS Server: 192.168.88.1
        DNS Servers: 192.168.88.1
Fallback DNS Servers: 1.1.1.1#cloudflare-dns.com 9.9.9.9#dns.quad9.net 8.8.8.8#dns.google 2606:4700:4700::1111#cloudflare-dns.com
                     2620:fe::9#dns.quad9.net 2001:4860:4860::8888#dns.google
Link 2 (enp7s0)
   Current Scopes: none
        Protocols: -DefaultRoute +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
    Default Route: no
Link 3 (wlp6s0)
   Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 mDNS/IPv4 mDNS/IPv6
        Protocols: +DefaultRoute +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
Current DNS Server: 192.168.1.1
      DNS Servers: 192.168.1.1
    Default Route: yes
ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   inet 127.0.0.1/8 scope host lo
      valid_lft forever preferred_lft forever
   inet6 ::1/128 scope host noprefixroute
2: enp7s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
   link/ether f0:2f:74:b2:0d:42 brd ff:ff:ff:ff:ff:ff
   altname enxf02f74b20d42
3: wlp6s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
   link/ether 64:bc:58:02:8f:f5 brd ff:ff:ff:ff:ff:ff
   altname wlx64bc58028ff5
   inet 192.168.1.202/24 brd 192.168.1.255 scope global noprefixroute wlp6s0
   inet6 fe80::19e3:1da2:8b72:a180/64 scope link noprefixroute
s
From resolv
# Generated by resolvconf
nameserver 192.168.88.1
From dhcp
|6/11/25 7:52 PM|systemd|Starting Network Manager Script Dispatcher Service...|
|6/11/25 7:52 PM|systemd|Started Network Manager Script Dispatcher Service.|
|6/11/25 7:52 PM|systemd-resolved|Using degraded feature set UDP instead of UDP+EDNS0 for DNS server 192.168.88.1.|
|6/11/25 7:52 PM|systemd|NetworkManager-dispatcher.service: Deactivated successfully.|
More info from inxi, but when on working wifi, because inxi hangs, not giving output when connected on wpa3
  Kernel: 6.14.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
    root=UUID=8cf533cc-b813-4638-9307-f4f25f8ea0b4 rw quiet splash
    resume=UUID=4f8f118f-af8b-4b38-a236-4dfc094143d7 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
  Mobo: ASUSTeK model: TUF GAMING B550M-PLUS (WI-FI) v: Rev X.0x
    UEFI: American Megatrends v: 3202 date: 06/15/2023
  System RAM: total: 64 GiB available: 62.7 GiB used: 8.75 GiB (14.0%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: G Skill Intl
    part-no: F4-4000C18-16GVK serial: N/A
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 1731 min/max: 550/4954 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1731 2: 1731 3: 1731
    4: 1731 5: 1731 6: 1731 7: 1731 8: 1731 9: 1731 10: 1731 11: 1731 12: 1731
    13: 1731 14: 1731 15: 1731 16: 1731 17: 1731 18: 1731 19: 1731 20: 1731
    21: 1731 22: 1731 23: 1731 24: 1731 bogomips: 177254
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon Pro W7800]
    driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
    built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-4
    empty: DP-1, DP-2, DP-3, Writeback-1 bus-ID: 05:00.0 chip-ID: 1002:745e
    class-ID: 0300
  Device-2: NVIDIA GA104GL [RTX A4000] driver: nvidia v: 570.144
    alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current (as of
    2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: none empty: DP-5, DP-6, DP-7, DP-8
    bus-ID: 08:00.0 chip-ID: 10de:24b0 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
    s-diag: 1165mm (45.88")
  Monitor-1: DP-4 mapped: DisplayPort-3 model: Samsung U32R59x
    serial: <filter> built: 2021 res: mode: 3840x2160 hz: 60 scale: 100% (1)
    dpi: 140 gamma: 1.2 chroma: red: x: 0.651 y: 0.341 green: x: 0.298 y: 0.624
    blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
    832x624, 800x600, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 95
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
    platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2
    drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia surfaceless:
    drv: nvidia x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Pro W7800 (radeonsi
    navi31 LLVM 19.1.7 DRM 3.61 6.14.6-2-MANJARO) device-ID: 1002:745e
    memory: 29.3 GiB unified: no
  API: Vulkan v: 1.4.313 layers: 5 device: 0 type: discrete-gpu name: AMD
    Radeon Pro W7800 (RADV NAVI31) driver: mesa radv v: 25.0.5-arch1.1
    device-ID: 1002:745e surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA RTX A4000 driver: nvidia v: 570.144 device-ID: 10de:24b0
    surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: nvidia-settings, nvidia-smi,
    radeontop wl: wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 05:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 08:00.1
    chip-ID: 10de:228b class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: BEHRINGER GmbH UMC202HD 192k driver: snd-usb-audio type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 1397:0507
    class-ID: fe01
  API: ALSA v: k6.14.6-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
  IF: enp7s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 2.79 TiB used: 282.16 GiB (9.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SKC6002048G
    size: 1.86 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0113 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SKC6001024G
    size: 953.87 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0105 scheme: GPT
  ID-1: / raw-size: 944.77 GiB size: 928.87 GiB (98.32%)
    used: 282.15 GiB (30.4%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 8cf533cc-b813-4638-9307-f4f25f8ea0b4
    used: 320 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: EF13-BD6B
  ID-1: swap-1 type: partition size: 8.8 GiB used: 7.6 MiB (0.1%)
    priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
    uuid: 4f8f118f-af8b-4b38-a236-4dfc094143d7
  ID-1: /dev/sda1 maj-min: 8:1 size: 1.86 TiB fs: ext4 label: Datnis
    uuid: bba2cc09-c838-481f-8822-442b004643bd
  Device-1: 1-5:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-8:5 info: Razer USA Naga Trinity type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0067 class-ID: 0300
    serial: <filter>
  Device-2: 1-9:6 info: SteelSeries ApS Apex Pro Mini type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1038:161e class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Areson Corp Elecom MR-K013 Multicard Reader
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 25a7:fa61 class-ID: 0301
  Device-2: 3-2:3 info: BEHRINGER GmbH UMC202HD 192k type: audio
    driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1397:0507 class-ID: fe01
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 43.8 C mobo: N/A gpu: amdgpu temp: 39.0 C
    mem: 48.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1019
  Packages: 1828 pm: pacman pkgs: 1822 libs: 498 tools: pamac pm: flatpak
    pkgs: 6
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 555
  1: cpu: 7.1% command: firefox pid: 13187 mem: 1009.8 MiB (1.5%)
  2: cpu: 3.9% command: Xorg pid: 1718 mem: 264.6 MiB (0.4%)
  3: cpu: 3.9% command: firefox pid: 24468 mem: 678.5 MiB (1.0%)
  4: cpu: 2.0% command: firefox pid: 23352 mem: 394.9 MiB (0.6%)
  5: cpu: 1.6% command: firefox pid: 21286 mem: 467.6 MiB (0.7%)
  Memory top: 5 of 555
  1: mem: 1009.8 MiB (1.5%) command: firefox pid: 13187 cpu: 7.1%
  2: mem: 678.5 MiB (1.0%) command: firefox pid: 24468 cpu: 3.9%
  3: mem: 677.9 MiB (1.0%) command: plasmashell pid: 2005 cpu: 0.3%
  4: mem: 467.6 MiB (0.7%) command: firefox pid: 21286 cpu: 1.6%
  5: mem: 447.5 MiB (0.6%) command: firefox pid: 13492 cpu: 0.4%
  Processes: 555 Power: uptime: 3h 55m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.04 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 15.1.1 alt: 14 Shell: Zsh v: 5.9
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
Then connection security - in this case wpa3 - has nothing to do with it.
It is more likely caused by using both IPv4 and IPv6.
In a SOHO (small office home office) scenario easiest solution is to disable IPv6.
//EDIT:
WPA3 is forcing PMF (Protected Management Frame) which may cause issues - if this is the case :man_shrugging:
From a quick search https://sx.nix.dk/search?q=AX200+and+WPA3 it appears that Intel AX200 may have issues with disconnects when using WPA3.
As I recall it, Intel is providing kernel drivers directly to the kernel source.
So I got fix. After 6.14 kernel was removed from manjaro, got large update to 6.15.3-1, after that wifi stopped working at all. iwlwifi drivers simply not starting anymore, with -110 error code. So I made downgrade to 6.12. After that I noticed, there are duplicate networks popping up with (wlp6s0) prefix, and connecting to them, WPA3 works as expected.
