Wifi stops working after few seconds
I bought the card: TP LINK TL-WN781ND Ver:3.20 Wifi card to give an upgrade to my old desktop computer.
But the problem I am facing is that the WiFi stops working after few seconds after booting. I had the same problem in ubuntu. But the card works fine in Windows 10.
The card uses RTL8188ee driver.
my kernel version is 5.6.19 and I am running Manjaro-20
Sometimes (rarely) for some reasons the WiFi card starts to work without any problem. I was able to recreate this situation by restarting my computer LOT of times (when I was still using ubuntu). Haven’t tried it on Manjaro yet.
Output of nmcli c up PopsHops --ask
Error: Connection activation failed: The Wi-Fi network could not be found
Hint: use 'journalctl -xe NM_CONNECTION=dc06dad8-9759-4cd9-8afe-130918649e0d + NM_DEVICE=wlp1s0' to get more details.
Output of journalctl -xe NM_CONNECTION=dc06dad8-9759-4cd9-8afe-130918649e0d + NM_DEVICE=wlp1s0
Jul 30 21:25:43 infimoto NetworkManager[500]: <info>  [1596124543.2650] dhcp4 (wlp1s0): canceled DHCP transaction
Jul 30 21:25:43 infimoto NetworkManager[500]: <info>  [1596124543.2651] dhcp4 (wlp1s0): state changed bound -> done
Jul 30 21:25:51 infimoto NetworkManager[500]: <info>  [1596124551.9840] device (wlp1s0): state change: disconnected -> unavailable (reason 'none', sys-iface-state: 'managed')
Jul 30 21:25:54 infimoto NetworkManager[500]: <info>  [1596124554.0462] device (wlp1s0): supplicant interface state: internal-starting -> disconnected
Jul 30 21:25:54 infimoto NetworkManager[500]: <info>  [1596124554.0501] device (wlp1s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Jul 30 21:25:54 infimoto NetworkManager[500]: <warn>  [1596124554.0579] sup-iface[a9e32d79d0469d71,1,wlp1s0]: call-p2p-cancel: failed with P2P cancel failed
Jul 30 21:40:43 infimoto NetworkManager[500]: <info>  [1596125443.1219] device (wlp1s0): Activation: starting connection 'PopsHops' (dc06dad8-9759-4cd9-8afe-130918649e0d)
Jul 30 21:40:43 infimoto NetworkManager[500]: <info>  [1596125443.1241] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 30 21:40:43 infimoto NetworkManager[500]: <info>  [1596125443.1445] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 30 21:40:43 infimoto NetworkManager[500]: <info>  [1596125443.1501] device (wlp1s0): Activation: (wifi) access point 'PopsHops' has security, but secrets are required.
Jul 30 21:40:43 infimoto NetworkManager[500]: <info>  [1596125443.1501] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jul 30 21:40:43 infimoto NetworkManager[500]: <info>  [1596125443.1760] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 30 21:40:43 infimoto NetworkManager[500]: <info>  [1596125443.1857] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 30 21:40:43 infimoto NetworkManager[500]: <info>  [1596125443.1935] device (wlp1s0): Activation: (wifi) connection 'PopsHops' has security, and secrets exist.  No new secrets needed.
Jul 30 21:40:43 infimoto NetworkManager[500]: <info>  [1596125443.6593] device (wlp1s0): supplicant interface state: disconnected -> scanning
Jul 30 21:41:08 infimoto NetworkManager[500]: <warn>  [1596125468.8094] device (wlp1s0): Activation: (wifi) association took too long, failing activation
Jul 30 21:41:08 infimoto NetworkManager[500]: <info>  [1596125468.8094] device (wlp1s0): state change: config -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Jul 30 21:41:08 infimoto NetworkManager[500]: <warn>  [1596125468.8134] device (wlp1s0): Activation: failed for connection 'PopsHops'
Jul 30 21:41:08 infimoto NetworkManager[500]: <info>  [1596125468.8139] device (wlp1s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 30 21:41:08 infimoto NetworkManager[500]: <info>  [1596125468.8184] device (wlp1s0): supplicant interface state: scanning -> disconnected
output of lspci | grep Network
01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8188EE Wireless Network Adapter (rev 01)
output for ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: ens32: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
    link/ether 00:e0:4c:be:20:05 brd ff:ff:ff:ff:ff:ff
    altname enp2s0
3: wlp1s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether d0:37:45:15:e0:df brd ff:ff:ff:ff:ff:ff
4: enp0s29f7u3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
    link/ether 5e:92:a1:fc:e8:de brd ff:ff:ff:ff:ff:ff
    inet 192.168.42.9/24 brd 192.168.42.255 scope global dynamic noprefixroute enp0s29f7u3
       valid_lft 2112sec preferred_lft 2112sec
    inet6 fe80::7c1a:5318:df38:1a22/64 scope link noprefixroute
Output for hwinfo --wlan
08: PCI 100.0: 0282 WLAN controller
  [Created at pci.386]
  Unique ID: yWPJ.37KpXZS+T6B
  Parent ID: vSkL.iscUv9+lfHB
  SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
  SysFS BusID: 0000:01:00.0
  Hardware Class: network
  Model: "Realtek RTL8188EE Wireless Network Adapter"
  Vendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
  Device: pci 0x8179 "RTL8188EE Wireless Network Adapter"
  SubVendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
  SubDevice: pci 0x8197
  Revision: 0x01
  Driver: "rtl8188ee"
  Driver Modules: "rtl8188ee"
  Device File: wlp1s0
  Features: WLAN
  I/O Ports: 0xd800-0xd8ff (rw)
  Memory Range: 0xfebfc000-0xfebfffff (rw,non-prefetchable)
  IRQ: 28 (no events)
  HW Address: d0:37:45:15:e0:df
  Permanent HW Address: d0:37:45:15:e0:df
  Link detected: no
  WLAN channels: 1 2 3 4 5 6 7 8 9 10 11 12 13
  WLAN frequencies: 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472
  WLAN encryption modes: WEP40 WEP104 TKIP CCMP
  WLAN authentication modes: open sharedkey wpa-psk wpa-eap
  Module Alias: "pci:v000010ECd00008179sv000010ECsd00008197bc02sc80i00"
  Driver Info #0:
    Driver Status: rtl8188ee is active
    Driver Activation Cmd: "modprobe rtl8188ee"
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #6 (PCI bridge)
Output for inxi -Fxz
System:    Host: infimoto Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: Xfce 4.14.2
           Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: N/A model: N/A serial: <filter> BIOS: American Megatrends v: 080015 date: 11/07/2013
CPU:       Topology: Dual Core model: Intel Pentium Dual E2180 bits: 64 type: MCP arch: Core Merom rev: D L2 cache: 1024 KiB
           flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 7980
           Speed: 1805 MHz min/max: N/A Core speeds (MHz): 1: 1805 2: 1695
Graphics:  Device-1: Intel 82945G/GZ Integrated Graphics driver: i915 v: kernel bus ID: 00:02.0
           Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting resolution: 1440x900~60Hz
           OpenGL: renderer: Mesa DRI Intel 945G v: 1.4 Mesa 20.1.3 direct render: Yes
Audio:     Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel v: kernel bus ID: 00:1b.0
           Sound Server: ALSA v: k5.6.19-2-MANJARO
Network:   Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee v: kernel port: d800 bus ID: 01:00.0
           IF: wlp1s0 state: down mac: <filter>
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel port: e800 bus ID: 02:00.0
           IF: ens32 state: down mac: <filter>
           Device-3: Samsung GT-I9070 (network tethering USB debugging enabled) type: USB driver: rndis_host bus ID: 1-3:5
           IF: enp0s29f7u3 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives:    Local Storage: total: 260.84 GiB used: 31.85 GiB (12.2%)
           ID-1: /dev/sda vendor: Seagate model: ST3160215AS size: 149.05 GiB
           ID-2: /dev/sdb vendor: Gigabyte model: GP-GSTFS31120GNTD size: 111.79 GiB
Partition: ID-1: / size: 29.21 GiB used: 8.37 GiB (28.7%) fs: ext4 dev: /dev/sdb1
           ID-2: /home size: 72.83 GiB used: 23.48 GiB (32.2%) fs: ext4 dev: /dev/sdb5
Sensors:   System Temperatures: cpu: 58.0 C mobo: N/A
Info:      Processes: 155 Uptime: 44m Memory: 3.41 GiB used: 1.90 GiB (55.8%) Init: systemd Compilers: gcc: 10.1.0 Shell: bash
           v: 5.0.18 inxi: 3.0.37
I also tried resetting the BIOS and reinserting the CMOS battery after reading about it in a post in this forum, it didn’t work.
I have tried kernel 4.19, 4.14, 5.8, 5.7 none of them fixed the problem.
How can I fix it?
Please provide output of
systool -vm rtl8188ee
Module = “rtl8188ee”
Attributes:
coresize = “122880”
initsize = “0”
initstate = “live”
refcnt = “0”
srcversion = “37C15302EBF6285818BD145”
taint = “”
uevent =
Parameters:
aspm = “1”
debug_level = “0”
debug_mask = “0”
disable_watchdog = “N”
fwlps = “N”
ips = “N”
msi = “Y”
swenc = “N”
swlps = “N”
Sections:
OK, what’s output of
sudo lspci -v -s 02:00.0
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 05)
	Subsystem: Realtek Semiconductor Co., Ltd. Device 0123
	Flags: bus master, fast devsel, latency 0, IRQ 16
	I/O ports at e800 [size=256]
	Memory at fdfff000 (64-bit, prefetchable) [size=4K]
	Memory at fdff8000 (64-bit, prefetchable) [size=16K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 01
	Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
	Capabilities: [d0] Vital Product Data
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [140] Virtual Channel
	Capabilities: [160] Device Serial Number ae-03-00-00-36-4c-e0-00
	Kernel driver in use: r8169
	Kernel modules: r8169
For some reasons the output is linked to your LAN and not to your WLAN, please enter
sudo lspci -v
and only copy the paragraph linked to your Realtek RTL8188EE Wireless Network Adapter.
	Subsystem: Realtek Semiconductor Co., Ltd. Device 8197
	Flags: bus master, fast devsel, latency 0, IRQ 28
	I/O ports at d800 [size=256]
	Memory at febfc000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 00
	Capabilities: [140] Device Serial Number 00-e0-4c-ff-fe-81-91-01
	Capabilities: [150] Latency Tolerance Reporting
	Kernel driver in use: rtl8188ee
	Kernel modules: rtl8188ee
OK, let’s start trying to switch off aspm by
echo 'options rtl8188ee aspm=0' | sudo tee /etc/modprobe.d/rtl8188ee.conf
Afterwards run
sudo modprobe rtl8188ee
Maybe you need to reboot afterwards.
In addition check output of
rfkill list
A further option I see if this does not solve your issue is to replace the Network manager, here is an excellent tutorial (from famous @tbg in the old forum):
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
did not fix the problem
is connman better than the default network manager?
The standard Network manager is known to make problems for some hardware/drivers, it’s worth to try it.
ConnMan didn’t work either :frowning:
Then let’s hope that some more experienced forum members join this thread. :man_shrugging:
I think its a driver issue. Is there any way to get the attention of the developers on this issue? Where can I report these problems directly to the developers?
SOURCE: Realtek RTL8188EE wireless stopped working reliably - Linux Mint Forums
Follow and create config magic file:
echo "options rtl8188ee swenc=Y ips=N" | sudo tee /etc/modprobe.d/rtl8188ee.conf
Reboot.
This is common issue with this sh*tty chipsets.
doesn’t fix the problem :frowning:
Seems to be UPSTREAM kernel driver issue. Reported here >> https://bugzilla.kernel.org/show_bug.cgi?id=206513
Repo in lastest post is dead. But lwfinger / Repositories · GitHub
I have tried that repo. Someone else has uploaded it in github. But installing the new driver didn’t fix the problem and the make command doesn’t run without error in kernel >5 so I tried kernel 4.14 to compile the driver. But the problem didn’t get solved.
Please help. :sob:
