Wifi stopped working overnight Mediatek MT7922
As the title says, the wifi stopped working on my computer overnight. It was working before for the lifespan of the computer, but stopped pretty suddenly.
The main oddity of how I shut it off last night is that booting down was taking longer than usual, so I pressed the power button.
Currently, the network panel shows “no connections available” if I open it without tunneling through my phone. Bluetooth still works, at least for my mouse.
Under Manjaro Settings Manager > Hardware Configuration > Show all devices > Network Controller, I see “RTL8125 2.5GbE Controller (Realtek Semiconductor Co., Ltd.)” and “Unknown device name (MEDIATEK Corp.)”.
I’ve tried following a couple threads to fix this, but nothing has done the job.
Could you show us which threads, please? Also a bit more system info: inxi -zv8 :wink:
Welcome at the forum @shane1 :tada:
To better understand your issue, please provide some more information about your system, a start could be to post output of
inxi -Fza
dmesg | grep firmware
Also, please tell us if you have only Manjaro installed or other OS in parallel.
You said you tried already a couple of things: Please tell us what exactly, ideally in combination with the commands and messages.
Last but not least, it’s worth to study the wiki in parallel:
Have you tried what is described here already:
https://unix.stackexchange.com/questions/723828/mt7921e-00000900-0-hardware-init-failed
Thanks for the help.
I’ll try to list what I’ve tried out, it may be difficult since I’ve been at this for a while.
I have no other operating systems installed.
inxi -zv8 Output
  Kernel: 6.6.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=f19a1c89-b519-4767-be3c-b2205c64cdef rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
  Type: Desktop System: Micro-Star product: MS-7D73 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MPG B650I EDGE WIFI (MS-7D73) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.00 date: 10/08/2022
  Device-1: hidpp_battery_0 model: Logitech MX Master 3S serial: <filter>
    charge: 45% rechargeable: yes status: discharging
  System RAM: total: 32 GiB available: 30.51 GiB used: 11.89 GiB (39.0%)
  Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 4800 MT/s actual: 6000 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: N/A part-no: F5-6000J3636F16G serial: N/A
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2051 high: 4732 min/max: 400/5573 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3426 2: 4732 3: 3330
    4: 400 5: 400 6: 400 7: 3434 8: 400 9: 400 10: 400 11: 3954 12: 4022
    13: 3501 14: 400 15: 3227 16: 400 bogomips: 144060
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
    avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes
    vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: eVga.com. driver: nvidia
    v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
    (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
    chip-ID: 10de:2484 class-ID: 0300
  Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
    arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1, DP-2,
    DP-3, HDMI-A-1 bus-ID: 11:00.0 chip-ID: 1002:164e class-ID: 0300
    temp: 55.0 C
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
    compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting,nouveau,nvidia
    alternate: fbdev,nv,vesa dri: radeonsi gpu: nvidia,amdgpu display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3000x1920 s-dpi: 91 s-size: 836x535mm (32.91x21.06")
    s-diag: 993mm (39.08")
  Monitor-1: DP-0 pos: primary,bottom-l res: 1920x1080 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: DP-2 pos: top-right res: 1080x1920 dpi: 93
    size: 296x527mm (11.65x20.75") diag: 604mm (23.8") modes: N/A
  Monitor-3: None-2-1 size-res: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
    drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.107.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3070 driver: nvidia v: 550.107.02
    device-ID: 10de:2484 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
    v: 24.1.5-manjaro1.1 device-ID: 1002:164e surfaces: xcb,xlib
  Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
    bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:4
    chip-ID: 0db0:36e7 class-ID: 0300
  API: ALSA v: k6.6.44-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.2 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
  IF: enp12s0 state: down mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: N/A modules: mt7921e pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
  Device-3: TP-Link 802.11ac WLAN Adapter driver: N/A type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 2357:0141
    class-ID: 0000 serial: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: enp17s0f4u2 state: up speed: 425 Mbps duplex: half mac: <filter>
  IF-ID-3: virbr0 state: down mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:5 chip-ID: 0e8d:0616
  Local Storage: total: 960.38 GiB used: 773.16 GiB (80.5%)
    model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 731100WD temp: 42.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: DataTraveler 3.0
    size: 28.87 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 0000 scheme: MBR
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 773.16 GiB (84.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: f19a1c89-b519-4767-be3c-b2205c64cdef
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 12EA-8869
  ID-1: /dev/sda1 maj-min: 8:1 size: 2.71 GiB fs: iso9660
  ID-2: /dev/sda2 maj-min: 8:2 size: 5 MiB fs: vfat label: N/A
    uuid: 669D-0308
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Keychron K2 Pro type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0223 class-ID: 0300
  Device-2: 1-6:3 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d73 class-ID: 0300
    serial: <filter>
  Device-3: 1-10:4 info: Micro Star USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
  Device-4: 1-12:5 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Device-1: 2-2:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 144mA
    chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
  Device-1: 3-1:2 info: TP-Link 802.11ac WLAN Adapter type: WiFi driver: N/A
    power: 500mA chip-ID: 2357:0141 class-ID: 0000 serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 5-1:2 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
    serial: <filter>
  Device-2: 5-2:6 info: Google Pixel 6a type: communication,CDC-data
    driver: cdc_ncm interfaces: 2 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 18d1:4eeb class-ID: 0a00 serial: <filter>
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 64.9 C mobo: N/A gpu: amdgpu temp: 55.0 C
  Fan Speeds (rpm): N/A
  Packages: 2051 pm: pacman pkgs: 2000 libs: 469 tools: pamac,yay pm: rpm
    pkgs: 0 pm: flatpak pkgs: 51
    1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    5: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    6: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    7: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    8: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 470
  1: cpu: 13.3% command: firefox pid: 2723 mem: 1329.1 MiB (4.2%)
  2: cpu: 3.0% command: firefox pid: 7744 mem: 422.5 MiB (1.3%)
  3: cpu: 2.1% command: kwin_x11 pid: 1382 mem: 242.7 MiB (0.7%)
  4: cpu: 2.0% command: firefox pid: 2939 mem: 47.4 MiB (0.1%)
  5: cpu: 1.8% command: firefox pid: 3844 mem: 55.9 MiB (0.1%)
  Memory top: 5 of 470
  1: mem: 1329.1 MiB (4.2%) command: firefox pid: 2723 cpu: 13.3%
  2: mem: 785.7 MiB (2.5%) command: plasmashell pid: 1395 cpu: 0.4%
  3: mem: 592.2 MiB (1.8%) command: firefox pid: 8054 cpu: 1.0%
  4: mem: 581.9 MiB (1.8%) command: brave pid: 2231 cpu: 1.4%
  5: mem: 470.2 MiB (1.5%) command: firefox pid: 4027 cpu: 0.4%
  Processes: 470 Power: uptime: 1h 55m states: freeze,mem,disk suspend: s2idle
    image: 12.19 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 256
  Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.35
inxi -Fza output
    udev.log_priority=3
  Speed (MHz): avg: 2723 high: 5403 min/max: 400/5573 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 4233 2: 400 3: 400
    4: 4990 5: 4883 6: 4505 7: 400 8: 4947 9: 3428 10: 4052 11: 400 12: 5403
    13: 4332 14: 400 15: 400 16: 400 bogomips: 144060
    BHI: Not affected
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2484 class-ID: 0300
    temp: 55.0 C
    screens: 1
    memory: 7.81 GiB
    class-ID: 0403
    tools: pw-cli,wpctl
  System Temperatures: cpu: 65.9 C mobo: N/A gpu: amdgpu temp: 55.0 C
  Memory: total: 32 GiB note: est. available: 30.51 GiB
    used: 12.03 GiB (39.4%)
  Processes: 473 Power: uptime: 1h 56m states: freeze,mem,disk
    suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.19 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
    pkgs: 0 pm: flatpak pkgs: 51 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh
    v: 5.9 default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.35
[    2.944262] [drm] Loading DMUB firmware via PSP: version=0x05001900
[    2.944656] [drm] Found VCN firmware Version ENC: 1.31 DEC: 3 VEP: 0 Revision: 2
[    2.944661] amdgpu 0000:11:00.0: amdgpu: Will use PSP to load VCN firmware
[    3.891176] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    4.814796] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    4.994156] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
Seems no driver is installed…
Yeah, that’s part of the issue, and seems odd to me since it was working fine yesterday. I think I tried reinstalling them when following one of the threads I saw, but there is a chance I messed up somewhere.
here’s what an ls at /lib/firmware/mediatek looks like
BT_RAM_CODE_MT7922_1_1_hdr.bin  mt7663pr2h_rebb.bin            mt7986_rom_patch.bin
BT_RAM_CODE_MT7961_1_2_hdr.bin  mt7668pr2h.bin                 mt7986_rom_patch_mt7975.bin
mt7601u.bin                     mt7915_eeprom.bin              mt7986_wa.bin
mt7610e.bin                     mt7915_eeprom_dbdc.bin         mt7986_wm.bin
mt7610u.bin                     mt7915_rom_patch.bin           mt7986_wm_mt7975.bin
mt7615_cr4.bin                  mt7915_wa.bin                  mt7986_wo_0.bin
mt7615_n9.bin                   mt7915_wm.bin                  mt7986_wo_1.bin
mt7615_rom_patch.bin            mt7916_eeprom.bin              mt7988
mt7622_n9.bin                   mt7916_rom_patch.bin           mt7996
mt7622pr2h.bin                  mt7916_wa.bin                  mt8173
mt7622_rom_patch.bin            mt7916_wm.bin                  mt8183
mt7650.bin                      mt7925                         mt8186
mt7650e.bin                     mt7981_rom_patch.bin           mt8192
mt7662.bin                      mt7981_wa.bin                  mt8195
mt7662_rom_patch.bin            mt7981_wm.bin                  sof
mt7662u.bin                     mt7981_wo.bin                  sof-tplg
mt7662u_rom_patch.bin           mt7986_eeprom_mt7975_dual.bin  WIFI_MT7922_patch_mcu_1_1_hdr.bin
mt7663_n9_rebb.bin              mt7986_eeprom_mt7976.bin       WIFI_MT7961_patch_mcu_1_2_hdr.bin
mt7663_n9_v3.bin                mt7986_eeprom_mt7976_dbdc.bin  WIFI_RAM_CODE_MT7922_1.bin
mt7663pr2h.bin                  mt7986_eeprom_mt7976_dual.bin  WIFI_RAM_CODE_MT7961_1.bin
Have you tried newer kernels such as 6.10? Could be that they contain the needed firmware.
Here is another possible approach:
That stackexchange solution seems like such an absurd fix to the problem, especially since it worked. I now have wifi again. How did you find that thread?
That “how to install firmware for mediatek usb wifi adapters” guide is one of the things I followed, but the forum wasn’t letting me post links. I assume that’s because my account is brand new?
For the kernel route, I updated my kernel to 6.6 while I was dealing with this, since that was the newest one manjaro lists with the LTS tag. Should I just update to 6.10?
Thanks again for helping me fix this.
I just noticed the TP-Link part of this, just to clear that up. I bought that today to serve as a placeholder for my wifi. I didn’t get that to work before the main issue was solved, so I’ll be returning it tomorrow.
I might look for a usb wifi dongle as a backup that specifically works for Linux machines, since all the ones in the store were iffy.
If your issue is solved, there might be no need to change to kernel 6.10 for the moment, on the other hand you always could try it, it’s easy to change kernels on Manjaro. You could have also more than one kernel installed, only be aware that in this case by standard the newest kernel will be booted.
Is there any reason to hold onto the older kernels?
I switched from 6.1 to 6.6 while trying to solve the issue. It’s not like I have a use for multiple kernels at the same time.
Thanks again for the help, I don’t think I would’ve figured out the unplugged button mashing solution on my own.
Glad I could help.
For rather modern hardware I would recommend the newer kernels. So, in your case I would give 6.10 a try, if there are any issues linked to the currently used kernel.
I’m replying to this only to ask if this is a (relatively) recent change, since I remember it being a pleasant surprise when first installing Manjaro (many moons ago) not having to fiddle with /etc/default/grub to un-hide the menu, etc. . I seem to recall it using the same kernel unless you changed it in GRUB? At least within series.
Maybe because I’d installed another kernel straight away?
