Yet another Wifi problem, i’m a bit lost.
On my older PC, Wifi stopped working with the March stable update, and the last update did not change anything. I simply can’t connect.
What i tried so far: different kernels, downgrade network manager and libnm to V. 1.32
Some info:
[hph@mini-me Schreibtisch]$ inxi -v2
Host: mini-me Kernel: 4.19.236-1-MANJARO arch: x86_64 bits: 64
Desktop: Xfce v: 4.16.0 Distro: Manjaro Linux
Type: Laptop System: Acer product: TravelMate B113 v: V1.05
serial: <superuser required>
Mobo: Acer model: BA10_HX v: Type2 - Board Version
serial: <superuser required> UEFI-[Legacy]: Acer v: 1.05 date: 07/19/2012
ID-1: BAT1 charge: 28.0 Wh (51.9%) condition: 53.9/55.5 Wh (97.2%)
volts: 11.2 min: 11.1
Info: dual core Intel Core i3-2377M [MT MCP] speed (MHz): avg: 798
min/max: 800/1500
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
driver: i915 v: kernel
Device-2: Suyin HD WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
gpu: i915 resolution: 1366x768~60Hz
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Centrino Advanced-N 6235 driver: iwlwifi
Device-2: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe driver: tg3
Local Storage: total: 223.58 GiB used: 28.08 GiB (12.6%)
Processes: 182 Uptime: 3m Memory: 3.69 GiB used: 796.6 MiB (21.1%)
Shell: Bash inxi: 3.3.15
and
[hph@mini-me Schreibtisch]$ sudo dmesg|grep iw
[ 5.457255] iwlwifi 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 5.556498] iwlwifi 0000:03:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
[ 5.897575] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUG enabled
[ 5.897580] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 5.897583] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[ 5.897587] iwlwifi 0000:03:00.0: Detected Intel(R) Centrino(R) Advanced-N 6235 AGN, REV=0xB0
[ 5.982433] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 6.001047] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 20.388759] iwlwifi 0000:03:00.0: Radio type=0x2-0x1-0x0
[ 20.724938] iwlwifi 0000:03:00.0: Radio type=0x2-0x1-0x0
[ 20.853168] iwlwifi 0000:03:00.0: Radio type=0x2-0x1-0x0
[ 21.165714] iwlwifi 0000:03:00.0: Radio type=0x2-0x1-0x0
[ 24.718049] iwlwifi 0000:03:00.0: Radio type=0x2-0x1-0x0
[ 25.036838] iwlwifi 0000:03:00.0: Radio type=0x2-0x1-0x0
[ 100.034970] iwlwifi 0000:03:00.0: Radio type=0x2-0x1-0x0
[ 100.353716] iwlwifi 0000:03:00.0: Radio type=0x2-0x1-0x0
Any hints? Which other logs could be helpful?
HP
