Wifi speed slow on Manjaro vs Windows
Hey guys, I just recently installed Manjaro and I’m quite satisfied with it. But the problem I am having is that my Wifi speed are much slower than on Windows. I should be hitting close to 200 mbps on wifi but on Manjaro I only get 40-50 mbps. Besides I only get 1 bar on 5ghz on Manjaro vs on Windows I get full signal, on 2.4ghz in Manjaro I get full signal but the speed is 25% of what I should be expecting.
I use a Asus AC-56 PCI Wifi network card.
  Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter vendor: ASUSTeK
  driver: wl v: kernel modules: bcma bus-ID: 04:00.0 chip-ID: 14e4:43b1
  class-ID: 0280
  vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 2a:00.0
  Device-3: Microsoft Wireless XBox Controller Dongle type: USB
  driver: mt76x2u bus-ID: 1-5:4 chip-ID: 045e:02e6 class-ID: 0000
  serial: <filter>
 οŒ’ ξ‚°  ~ ξ‚° neofetch        ξ‚² 127 ✘ ξ‚² 10s ο‰’
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   nasira@nasir-ms7c56
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   -------------------
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   OS: Manjaro Linux x86_64
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Host: MS-7C56 1.0
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ            β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Kernel: 5.10.68-1-MANJARO
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Uptime: 13 mins
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Packages: 1264 (pacman), 7 (snap)
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Shell: bash 5.1.8
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Resolution: 1920x1080, 1920x1080
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   DE: Plasma 5.22.5
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   WM: KWin
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Theme: Aritim-Dark [Plasma], Breeze [GTK2/3]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Icons: breeze-dark [Plasma], breeze-dark [GTK2/3]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Terminal: konsole
                               CPU: AMD Ryzen 7 5800X (16) @ 3.800GHz
                               GPU: NVIDIA GeForce GTX 1080 Ti
                               Memory: 2284MiB / 15990MiB
Not sure about that specific chipset (BCM4352), but what if you try with the open source bcm43 driver instead of wl?
From what I can gather, it’s only supported by the proprietary wl driver, but perhaps things have changed in recent years?
EDIT: Not looking good. Seems to be a particular chipset that doesn’t work well under Linux and you’re stuck with the closed-source wl driver.
The Linux driver hasn’t been updated in six years! :roll_eyes:
My opinion, I would go with another card if it’s feasible for you, depending on cost and long-term usage (in Linux).
I got tired of trying to get my intel card to work right. I disassembled my laptop, unplugged the card and use a usb WiFi connection now. My speed went up to what it should be and have no problems even streaming HD video.
