Hello there i im new in linux world , i have an old imac 2009 8.1 and i want to experiment with linux . I have install manjaro xfce in my imac , but i have speed connection problem , i have fiber up to 100mbps in my house but in speed test through this machine gives me 19mdps . I dont know whats the problem . Can anyone help me ?
@demotapa
hello
please post the output of
first. please use the preformatted option and insert it there.
That would be for a wired (Ethernet) connection. Your wireless connection will vary depending upon factors such as the distance from the router, wifi channel, etc.
@demotapa first of all, welcome to the forum ![]()
That said before anyone can guess what the problem is, if there is any, you need to provide more info about your computer… ![]()
So please provide the info @Olli asked for before others can break their minds over your topic. ![]()
I get 13.81 Mbps on my 2009 mbp 15m from a fiber-connected router through a single plasterboard wall, seems decent for the hardware.
Kernel: 6.0.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=02cdfd9e-a859-4c19-a2d1-8f1806fa0ca2 rw quiet apparmor=1
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Apple product: iMac8,1 v: 1.0
serial: <superuser required> Chassis: type: 13 v: Mac-F226BEC8
Mobo: Apple model: Mac-F226BEC8 v: PVT serial: <superuser required>
UEFI: Apple v: IM81.88Z.00C1.B00.0802091538 date: 02/09/08
RAM: total: 5.79 GiB used: 1.51 GiB (26.2%)
Info: model: Intel Core2 Duo E8335 bits: 64 type: MCP arch: Penryn level: v1
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23) stepping: 6
microcode: 0x60F
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2650 high: 2651 min/max: 800/2667 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2651 2: 2649
bogomips: 10645
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 pti rep_good sep sse sse2 sse4_1 ssse3 syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD RV630/M76 [Mobility Radeon HD 2600 XT/2700]
vendor: Apple iMac 7 1 driver: radeon v: kernel alternate: amdgpu arch: R500
process: TSMC 90nm built: 2005-07 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
ports: active: LVDS-1 empty: DIN-1,DVI-I-1 bus-ID: 01:00.0
chip-ID: 1002:9583 class-ID: 0300 temp: 64.0 C
Device-2: Apple Built-in iSight type: USB driver: uvcvideo bus-ID: 2-4:2
chip-ID: 05ac:8502 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
gpu: radeon display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.48x10.91")
s-diag: 523mm (20.6")
Monitor-1: LVDS-1 mapped: LVDS model: Apple Color LCD serial: <filter>
built: 2006 res: 1680x1050 hz: 60 dpi: 99 gamma: 1.2
size: 433x270mm (17.05x10.63") diag: 510mm (20.1") ratio: 16:10 modes:
max: 1680x1050 min: 640x480
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 82801H HD Audio vendor: Apple driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:284b class-ID: 0403
Sound API: ALSA v: k6.0.8-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Broadcom BCM4321 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: b43-pci-bridge v: N/A modules: ssb pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 14e4:4328 class-ID: 0280
Device-2: Marvell 88E8058 PCI-E Gigabit Ethernet driver: sky2 v: 1.30 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 5000 bus-ID: 05:00.0 chip-ID: 11ab:436a
class-ID: 0200
IF: ens5 state: down mac: <filter>
IF-ID-1: wlan0 state: up mac: <filter>
Device-1: Apple Bluetooth HCI type: USB driver: btusb v: 0.8 bus-ID: 3-1.1:3
chip-ID: 05ac:820f class-ID: fe01 serial: <filter>
Local Storage: total: 111.79 GiB used: 18.72 GiB (16.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SHFS37A120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: BBF0 scheme: GPT
Optical-1: /dev/sr0 vendor: â– â– â– â– â– â– â– â– model: DVD-R UJ-875 rev: DB09
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 111.49 GiB size: 109.18 GiB (97.93%)
used: 18.72 GiB (17.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 02cdfd9e-a859-4c19-a2d1-8f1806fa0ca2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 5631-485B
Hub-1: 1-0:1 info: Full speed or root hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-2:3 info: Apple Hub in Aluminum Keyboard ports: 3 rev: 2.0
speed: 480 Mb/s power: 300mA chip-ID: 05ac:1006 class-ID: 0900
Device-1: 1-2.2:4 info: Apple Aluminum Keyboard (ISO) type: Keyboard,HID
driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s power: 20mA
chip-ID: 05ac:0221 class-ID: 0300
Device-2: 1-2.3:5 info: Maxxter Telink Wireless Receiver
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 50mA chip-ID: 248a:8367 class-ID: 0301
Hub-3: 2-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Device-1: 2-4:2 info: Apple Built-in iSight type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05ac:8502
Hub-4: 3-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 3-1:2 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:4500
Device-1: 3-1.1:3 info: Apple Bluetooth HCI type: Bluetooth driver: btusb
interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:820f class-ID: fe01
serial: <filter>
Hub-6: 4-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-9: 7-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 7-1:2 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 05ac:8242 class-ID: 0300
System Temperatures: cpu: 45.0 C mobo: N/A gpu: radeon temp: 63.0 C
Fan Speeds (RPM): cpu: 1197
Processes: 179 Uptime: 4h 45m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1171 pm: pacman pkgs: 1165 libs: 333 tools: pamac,yay pm: flatpak
pkgs: 0 pm: snap pkgs: 6 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.23
Mine is:
Device-1: Broadcom BCM4322 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl
There are 2 drivers for those cards, both work. Your b43 is included. You could try installing the broadcom-wl-dkms package but I’d only do this if you have problems connecting, the connection speed will not improve, you have currently 19Mps, I have 14Mps. Be warned that installing broadcom-wl-dkms will mean clunkier updates since any kernel update will take longer because of the required dkms install. Also keep in mind that going back may not be so easy since B43 may have been blacklisted.
Not related but I’d allocate some swap with only 5.79GB ram.
According to en:users:drivers:b43 [Linux Wireless] :
PCI-ID Supported? Chip ID Modes PHY version Alternative
14e4:4321 partially BCM4321 ? N (r2)
So i would also suggest you to try the broadcom-wl-dkms driver…
What does the output of the below command give you?
mhwd -l
Further info:
https://wiki.archlinux.org/title/Broadcom_wireless
0000:01:00.0 (0300:1002:9583) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:04:00.0 (0280:14e4:4328) Network controller Broadcom:
network-broadcom-wl 2018.10.07 false PCI
Good that shows you need to install the broadcom-wl proprietary drivers ![]()
Before we start to install any dkms package, we need to check if you have the needed header files for your kernel(s):
- pamac search -i linux kernel modules
linux60-headers 6.0.8-1 core Header files and scripts for building modules for Linux60 kernel linux60 6.0.8-1 core The Linux60 kernel and modules linux515-headers 5.15.78-1 core Header files and scripts for building modules for Linux515 kernel linux515 5.15.78-1 core The Linux515 kernel and modules
If you get the same as on my machine, except the headers:
Then you need to install the header packages also, else you can leave out the headers.
pamac install -d linux515-headers linux60-headers dkms broadcom-wl-dkms
This will perform a “dry-run” to show you what will be installed, when you remove the “-d” it will actually install them…
After you finish installing you should reboot.
I’d stay with the LTS kernels 5.10 or 5.15 on this 2009 machine.
Try paying attention to the conversations to understand why something is suggested ![]()
(Hint, check what he already runs)
I understand your suggestion but you should make that towards his post with kernel, not my reply ![]()
