Hi,
When I am starting KDE, wifi needs minute or more to connect. It is really slow and unstable sometimes.
About bluetooth, it is also unstable. When I am connected to my bluetooth speaker or headphones, while listening music, sound lags behind, sometimes nothing can not hear but as I can see on Youtube ( seconds are going, so sound is there but not going via speaker )
> [marko@HPenvy ~]$ inxi --full --verbosity=7 --filter --no-host
> System:
> Kernel: 5.9.0-1-MANJARO x86_64 bits: 64 compiler: N/A
> Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
> Distro: Manjaro Linux
> Machine:
> Type: Convertible System: HP
> product: HP ENVY x360 Convertible 13-ar0xxx v: N/A serial: <filter>
> Chassis: type: 31 serial: <filter>
> Mobo: HP model: 85DE v: 41.36 serial: <filter> UEFI: AMI v: F.19
> date: 12/26/2019
> Battery:
> ID-1: BAT0 charge: 18.6 Wh condition: 52.9/52.9 Wh (100%)
> volts: 15.9/15.4 model: 333-2B-49-A KC04053XL type: Li-ion
> serial: <filter> status: Charging
> Device-1: hid-0018:04F3:23B9.0001-battery model: ELAN2514:00 04F3:23B9
> serial: N/A charge: N/A status: N/A
> Memory:
> RAM: total: 5.74 GiB used: 2.32 GiB (40.4%)
> RAM Report:
> permissions: Unable to run dmidecode. Root privileges required.
> CPU:
> Topology: Quad Core
> model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
> type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB bogomips: 33549
> Speed: 1284 MHz min/max: 1400/2100 MHz boost: enabled
> Core speeds (MHz): 1: 1284 2: 1283 3: 1274 4: 1278 5: 1272 6: 1355
> 7: 1363 8: 1362
> Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2
> bmi1 bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc
> cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid
> f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb
> irperf lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe
> msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov
> pae pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc
> perfctr_nb pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp
> rep_good sep sev sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
> sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc
> tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1
> xsave xsavec xsaveerptr xsaveopt xsaves
> Graphics:
> Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
> bus ID: 04:00.0 chip ID: 1002:15d8
> Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
> bus ID: 3-1:2 chip ID: 04ca:709d
> Display: x11 server: X. Org 1.20.9 compositor: kwin_x11 driver: amdgpu
> FAILED: ati unloaded: modesetting alternate: fbdev,vesa
> resolution: 1920x1080~60Hz s-dpi: 96
> OpenGL: renderer: AMD RAVEN (DRM 3.39.0 5.9.0-1-MANJARO LLVM 10.0.1)
> v: 4.6 Mesa 20.1.6 direct render: Yes
> Audio:
> Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
> vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
> bus ID: 04:00.1 chip ID: 1002:15de
> Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
> vendor: Hewlett-Packard driver: N/A bus ID: 04:00.5 chip ID: 1022:15e2
> Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
> driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
> Sound Server: ALSA v: k5.9.0-1-MANJARO
> Network:
> Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
> vendor: Hewlett-Packard driver: rtw_8822be v: N/A port: f000
> bus ID: 02:00.0 chip ID: 10ec:b822
> IF: wlo1 state: up mac: <filter>
> IP v4: <filter> type: dynamic noprefixroute scope: global
> broadcast: <filter>
> IP v6: <filter> type: noprefixroute scope: link
> WAN IP: <filter>
> Drives:
> Local Storage: total: 476.94 GiB used: 9.24 GiB (1.9%)
> ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H
> size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: HPS0
> scheme: GPT
> Message: No Optical or Floppy data was found.
> RAID:
> Message: No RAID data was found.
> Partition:
> ID-1: / size: 468.16 GiB used: 9.24 GiB (2.0%) fs: ext4
> dev: /dev/nvme0n1p2 label: N/A
> uuid: 6301f4ee-2f1b-4af9-8c13-522b784a1928
> ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
> dev: /dev/nvme0n1p1 label: N/A uuid: 2DE5-7276
> Swap:
> Alert: No Swap data was found.
> Unmounted:
> Message: No unmounted partitions found.
> USB:
> Hub: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
> speed: 480 Mb/s chip ID: 1d6b:0002
> Device-1: 1-3:2 info: Xenta 2.4GHz Receiver (Keyboard and Mouse)
> type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3
> rev: 1.1 speed: 1.5 Mb/s chip ID: 1d57:32da
> Device-2: 1-4:3 info: Synaptics type: <vendor specific> driver: N/A
> interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 06cb:00d2
> serial: <filter>
> Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
> speed: 10 Gb/s chip ID: 1d6b:0003
> Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
> Device-1: 3-1:2 info: Lite-On HP Wide Vision HD Camera type: Video
> driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
> chip ID: 04ca:709d
> Device-2: 3-2:3 info: Realtek Realtek Bluetooth 4.2 Adapter
> type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
> chip ID: 0bda:b00b serial: <filter>
> Hub: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1
> Sensors:
> System Temperatures: cpu: 50.2 C mobo: 37.0 C gpu: amdgpu temp: 50 C
> Fan Speeds (RPM): N/A
> Info:
> Processes: 249 Uptime: 4h 37m Init: systemd v: 246 Compilers: gcc: N/A
> Packages: pacman: 1191 Shell: Bash v: 5.0.18 running in: konsole
> inxi: 3.1.05
> [marko@HPenvy ~]$
[ 0.251178] smpboot: Total of 8 processors activated (33549.85 BogoMIPS)
[ 0.251834] devtmpfs: initialized
[ 0.251834] x86/mm: Memory block size: 128MB
[ 0.251834] PM: Registering ACPI NVS region [mem 0x04000000-0x0400afff] (45056 bytes)
[ 0.251834] PM: Registering ACPI NVS region [mem 0xd7d7e000-0xd82eefff] (5705728 bytes)
[ 0.251834] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.251834] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.251834] pinctrl core: initialized pinctrl subsystem
[ 0.251834] PM: RTC time: 15:09:20, date: 2020-09-04
[ 0.251834] NET: Registered protocol family 16
[ 0.251834] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.251834] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.251836] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.251850] audit: initializing netlink subsys (disabled)
[ 0.254469] audit: type=2000 audit(1599232159.019:1): state=initialized audit_enabled=0 res=1
[ 0.254563] thermal_sys: Registered thermal governor 'fair_share'
[ 0.254564] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.254565] thermal_sys: Registered thermal governor 'step_wise'
[ 0.254565] thermal_sys: Registered thermal governor 'user_space'
[ 0.254565] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.254576] cpuidle: using governor ladder
[ 0.254579] cpuidle: using governor menu
[ 0.254608] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.254608] ACPI: bus type PCI registered
[ 0.254608] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.254608] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.254608] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.254608] PCI: Using configuration type 1 for base access
[ 0.255852] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.255852] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.255852] fbcon: Taking over console
[ 0.257806] ACPI: Added _OSI(Module Device)
[ 0.257806] ACPI: Added _OSI(Processor Device)
[ 0.257806] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.257806] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.257826] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.257826] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.257826] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.257826] ACPI: Added _OSI(Linux)
[ 0.275220] ACPI: 16 ACPI AML tables successfully acquired and loaded
[ 0.276591] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query honored via cmdline
[ 0.281627] ACPI: EC: EC started
[ 0.281628] ACPI: EC: interrupt blocked
[ 0.371224] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.371228] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC used to handle transactions
[ 0.371228] ACPI: Interpreter enabled
[ 0.371250] ACPI: (supports S0)
[ 0.371251] ACPI: Using IOAPIC for interrupt routing
[ 0.371491] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.373307] ACPI: Power Resource [PWRE] (on)
[ 0.374253] ACPI: Power Resource [P0U0] (on)
[ 0.374378] ACPI: Power Resource [P3U0] (off)
[ 0.375265] ACPI: Power Resource [P0U1] (on)
[ 0.375391] ACPI: Power Resource [P3U1] (off)
[ 0.381929] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.381935] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.382152] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[ 0.382359] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.382361] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.382376] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.382780] PCI host bridge to bus 0000:00
[ 0.382782] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.382784] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.382785] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.382786] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.382787] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.382788] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.382789] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfebfffff window]
[ 0.382790] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[ 0.382791] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.382805] pci 0000:00:00.0: [1022:15d0] type 00 class 0x060000
[ 0.382935] pci 0000:00:00.2: [1022:15d1] type 00 class 0x080600
[ 0.383081] pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
[ 0.383179] pci 0000:00:01.4: [1022:15d3] type 01 class 0x060400
[ 0.383212] pci 0000:00:01.4: enabling Extended Tags
[ 0.383284] pci 0000:00:01.4: PME# supported from D0 D3hot D3cold
[ 0.383398] pci 0000:00:01.5: [1022:15d3] type 01 class 0x060400
[ 0.383430] pci 0000:00:01.5: enabling Extended Tags
[ 0.383480] pci 0000:00:01.5: PME# supported from D0 D3hot D3cold
[ 0.383598] pci 0000:00:01.7: [1022:15d3] type 01 class 0x060400
[ 0.383630] pci 0000:00:01.7: enabling Extended Tags
[ 0.383701] pci 0000:00:01.7: PME# supported from D0 D3hot D3cold
[ 0.383815] pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
[ 0.383908] pci 0000:00:08.1: [1022:15db] type 01 class 0x060400
[ 0.383941] pci 0000:00:08.1: enabling Extended Tags
[ 0.383983] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.384102] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.384250] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.384404] pci 0000:00:18.0: [1022:15e8] type 00 class 0x060000
[ 0.384476] pci 0000:00:18.1: [1022:15e9] type 00 class 0x060000
[ 0.384530] pci 0000:00:18.2: [1022:15ea] type 00 class 0x060000
[ 0.384590] pci 0000:00:18.3: [1022:15eb] type 00 class 0x060000
[ 0.384639] pci 0000:00:18.4: [1022:15ec] type 00 class 0x060000
[ 0.384687] pci 0000:00:18.5: [1022:15ed] type 00 class 0x060000
[ 0.384737] pci 0000:00:18.6: [1022:15ee] type 00 class 0x060000
[ 0.384785] pci 0000:00:18.7: [1022:15ef] type 00 class 0x060000
[ 0.384913] pci 0000:01:00.0: [10ec:522a] type 00 class 0xff0000
[ 0.384929] pci 0000:01:00.0: reg 0x10: [mem 0xfe700000-0xfe700fff]
[ 0.385044] pci 0000:01:00.0: supports D1 D2
[ 0.385045] pci 0000:01:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.385193] pci 0000:00:01.4: PCI bridge to [bus 01]
[ 0.385198] pci 0000:00:01.4: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.385270] pci 0000:02:00.0: [10ec:b822] type 00 class 0x028000
[ 0.385290] pci 0000:02:00.0: reg 0x10: [io 0xf000-0xf0ff]
[ 0.385316] pci 0000:02:00.0: reg 0x18: [mem 0xfe600000-0xfe60ffff 64bit]
[ 0.385436] pci 0000:02:00.0: supports D1 D2
[ 0.385437] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.385604] pci 0000:00:01.5: PCI bridge to [bus 02]
[ 0.385607] pci 0000:00:01.5: bridge window [io 0xf000-0xffff]
[ 0.385610] pci 0000:00:01.5: bridge window [mem 0xfe600000-0xfe6fffff]
[ 0.385783] pci 0000:03:00.0: [8086:f1a8] type 00 class 0x010802
[ 0.385804] pci 0000:03:00.0: reg 0x10: [mem 0xfe500000-0xfe503fff 64bit]
[ 0.386063] pci 0000:00:01.7: PCI bridge to [bus 03]
[ 0.386068] pci 0000:00:01.7: bridge window [mem 0xfe500000-0xfe5fffff]
[ 0.386175] pci 0000:04:00.0: [1002:15d8] type 00 class 0x030000
[ 0.386192] pci 0000:04:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.386204] pci 0000:04:00.0: reg 0x18: [mem 0xf0000000-0xf01fffff 64bit pref]
[ 0.386211] pci 0000:04:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.386218] pci 0000:04:00.0: reg 0x24: [mem 0xfe400000-0xfe47ffff]
[ 0.386231] pci 0000:04:00.0: enabling Extended Tags
[ 0.386242] pci 0000:04:00.0: BAR 0: assigned to efifb
[ 0.386304] pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.386424] pci 0000:04:00.1: [1002:15de] type 00 class 0x040300
[ 0.386435] pci 0000:04:00.1: reg 0x10: [mem 0xfe4c8000-0xfe4cbfff]
[ 0.386467] pci 0000:04:00.1: enabling Extended Tags
[ 0.386512] pci 0000:04:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.386588] pci 0000:04:00.2: [1022:15df] type 00 class 0x108000
[ 0.386607] pci 0000:04:00.2: reg 0x18: [mem 0xfe300000-0xfe3fffff]
[ 0.386622] pci 0000:04:00.2: reg 0x24: [mem 0xfe4ce000-0xfe4cffff]
[ 0.386632] pci 0000:04:00.2: enabling Extended Tags
[ 0.386759] pci 0000:04:00.3: [1022:15e0] type 00 class 0x0c0330
[ 0.386775] pci 0000:04:00.3: reg 0x10: [mem 0xfe200000-0xfe2fffff 64bit]
[ 0.387799] pci 0000:04:00.3: enabling Extended Tags
[ 0.387799] pci 0000:04:00.3: PME# supported from D0 D3hot D3cold
[ 0.387799] pci 0000:04:00.4: [1022:15e1] type 00 class 0x0c0330
[ 0.387799] pci 0000:04:00.4: reg 0x10: [mem 0xfe100000-0xfe1fffff 64bit]
[ 0.387799] pci 0000:04:00.4: enabling Extended Tags
[ 0.387799] pci 0000:04:00.4: PME# supported from D0 D3hot D3cold
[ 0.387799] pci 0000:04:00.5: [1022:15e2] type 00 class 0x048000
[ 0.387799] pci 0000:04:00.5: reg 0x10: [mem 0xfe480000-0xfe4bffff]
[ 0.387799] pci 0000:04:00.5: enabling Extended Tags
[ 0.387799] pci 0000:04:00.5: PME# supported from D0 D3hot D3cold
[ 0.387799] pci 0000:04:00.6: [1022:15e3] type 00 class 0x040300
[ 0.387799] pci 0000:04:00.6: reg 0x10: [mem 0xfe4c0000-0xfe4c7fff]
[ 0.387799] pci 0000:04:00.6: enabling Extended Tags
[ 0.387799] pci 0000:04:00.6: PME# supported from D0 D3hot D3cold
[ 0.387799] pci 0000:04:00.7: [1022:15e4] type 00 class 0x000000
[ 0.387799] pci 0000:04:00.7: reg 0x18: [mem 0xfe000000-0xfe0fffff]
[ 0.387799] pci 0000:04:00.7: reg 0x24: [mem 0xfe4cc000-0xfe4cdfff]
[ 0.387799] pci 0000:04:00.7: enabling Extended Tags
[ 0.387799] pci 0000:00:08.1: PCI bridge to [bus 04]
[ 0.387799] pci 0000:00:08.1: bridge window [io 0xe000-0xefff]
[ 0.387799] pci 0000:00:08.1: bridge window [mem 0xfe000000-0xfe4fffff]
[ 0.387799] pci 0000:00:08.1: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.388457] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 11 14 15) *0
[ 0.388512] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 11 14 15) *0
[ 0.388560] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 11 14 15) *0
[ 0.388619] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 10 11 14 15) *0
[ 0.388673] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[ 0.388716] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[ 0.388760] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[ 0.391129] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[ 0.391132] iommu: Default domain type: Translated
[ 0.391157] pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.391157] pci 0000:04:00.0: vgaarb: bridge control possible
[ 0.391157] pci 0000:04:00.0: vgaarb: setting as boot device
[ 0.391157] vgaarb: loaded
[ 0.391310] SCSI subsystem initialized
[ 0.391327] libata version 3.00 loaded.
[ 0.391327] ACPI: bus type USB registered
[ 0.391327] usbcore: registered new interface driver usbfs
[ 0.391327] usbcore: registered new interface driver hub
[ 0.391327] usbcore: registered new device driver usb
[ 0.395059] pps_core: LinuxPPS API ver. 1 registered
[ 0.395060] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.395062] PTP clock support registered
[ 0.395069] EDAC MC: Ver: 3.0.0
[ 0.397830] Registered efivars operations
[ 0.397901] NetLabel: Initializing
[ 0.397901] NetLabel: domain hash size = 128
[ 0.397902] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.397911] NetLabel: unlabeled traffic allowed by default
[ 0.397912] PCI: Using ACPI for IRQ routing
[ 0.399859] PCI: pci_cache_line_size set to 64 bytes
[ 0.399859] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.399859] e820: reserve RAM buffer [mem 0x09ed0000-0x0bffffff]
[ 0.399859] e820: reserve RAM buffer [mem 0xd4d49000-0xd7ffffff]
[ 0.399859] e820: reserve RAM buffer [mem 0xd6a90000-0xd7ffffff]
[ 0.399859] e820: reserve RAM buffer [mem 0xd7c0e000-0xd7ffffff]
[ 0.399859] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[ 0.399859] e820: reserve RAM buffer [mem 0x19f000000-0x19fffffff]
[ 0.399859] e820: reserve RAM buffer [mem 0x21f340000-0x21fffffff]
[ 0.401134] clocksource: Switched to clocksource tsc-early
[ 0.411519] VFS: Disk quotas dquot_6.6.0
[ 0.411535] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.411643] AppArmor: AppArmor Filesystem Enabled
[ 0.411679] pnp: PnP ACPI init
[ 0.411838] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.411844] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.411950] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.412038] pnp 00:02: Plug and Play ACPI device, IDs HPQ8001 PNP0303 (active)
[ 0.412265] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.412266] system 00:03: [io 0x040b] has been reserved
[ 0.412267] system 00:03: [io 0x04d6] has been reserved
[ 0.412268] system 00:03: [io 0x0c00-0x0c01] has been reserved
[ 0.412269] system 00:03: [io 0x0c14] has been reserved
[ 0.412270] system 00:03: [io 0x0c50-0x0c51] has been reserved
[ 0.412271] system 00:03: [io 0x0c52] has been reserved
[ 0.412272] system 00:03: [io 0x0c6c] has been reserved
[ 0.412272] system 00:03: [io 0x0c6f] has been reserved
[ 0.412273] system 00:03: [io 0x0cd0-0x0cd1] has been reserved
[ 0.412274] system 00:03: [io 0x0cd2-0x0cd3] has been reserved
[ 0.412275] system 00:03: [io 0x0cd4-0x0cd5] has been reserved
[ 0.412276] system 00:03: [io 0x0cd6-0x0cd7] has been reserved
[ 0.412276] system 00:03: [io 0x0cd8-0x0cdf] has been reserved
[ 0.412277] system 00:03: [io 0x0800-0x089f] has been reserved
[ 0.412278] system 00:03: [io 0x0b00-0x0b0f] has been reserved
[ 0.412279] system 00:03: [io 0x0b20-0x0b3f] has been reserved
[ 0.412280] system 00:03: [io 0x0900-0x090f] has been reserved
[ 0.412280] system 00:03: [io 0x0910-0x091f] has been reserved
[ 0.412282] system 00:03: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.412283] system 00:03: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.412284] system 00:03: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.412285] system 00:03: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.412286] system 00:03: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.412287] system 00:03: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.412287] system 00:03: [mem 0xff000000-0xffffffff] has been reserved
[ 0.412290] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.413040] pnp: PnP ACPI: found 4 devices
[ 0.419479] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.419529] NET: Registered protocol family 2
[ 0.419680] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.419747] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.419916] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.419997] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.420065] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.420095] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.420119] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.420204] NET: Registered protocol family 1
[ 0.420208] NET: Registered protocol family 44
[ 0.420220] pci 0000:00:01.4: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 0.420222] pci 0000:00:01.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[ 0.420225] pci 0000:00:01.7: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.420226] pci 0000:00:01.7: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.420236] pci 0000:00:01.4: BAR 15: assigned [mem 0xf0200000-0xf03fffff 64bit pref]
[ 0.420239] pci 0000:00:01.7: BAR 15: assigned [mem 0xf0400000-0xf05fffff 64bit pref]
[ 0.420242] pci 0000:00:01.4: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.420244] pci 0000:00:01.7: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.420246] pci 0000:00:01.4: PCI bridge to [bus 01]
[ 0.420249] pci 0000:00:01.4: bridge window [io 0x1000-0x1fff]
[ 0.420252] pci 0000:00:01.4: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.420254] pci 0000:00:01.4: bridge window [mem 0xf0200000-0xf03fffff 64bit pref]
[ 0.420259] pci 0000:00:01.5: PCI bridge to [bus 02]
[ 0.420260] pci 0000:00:01.5: bridge window [io 0xf000-0xffff]
[ 0.420263] pci 0000:00:01.5: bridge window [mem 0xfe600000-0xfe6fffff]
[ 0.420269] pci 0000:00:01.7: PCI bridge to [bus 03]
[ 0.420270] pci 0000:00:01.7: bridge window [io 0x2000-0x2fff]
[ 0.420273] pci 0000:00:01.7: bridge window [mem 0xfe500000-0xfe5fffff]
[ 0.420276] pci 0000:00:01.7: bridge window [mem 0xf0400000-0xf05fffff 64bit pref]
[ 0.420281] pci 0000:00:08.1: PCI bridge to [bus 04]
[ 0.420287] pci 0000:00:08.1: bridge window [io 0xe000-0xefff]
[ 0.420290] pci 0000:00:08.1: bridge window [mem 0xfe000000-0xfe4fffff]
[ 0.420292] pci 0000:00:08.1: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.420297] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.420298] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.420299] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.420300] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.420301] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.420301] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.420302] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xfebfffff window]
[ 0.420303] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[ 0.420304] pci_bus 0000:01: resource 0 [io 0x1000-0x1fff]
[ 0.420305] pci_bus 0000:01: resource 1 [mem 0xfe700000-0xfe7fffff]
[ 0.420305] pci_bus 0000:01: resource 2 [mem 0xf0200000-0xf03fffff 64bit pref]
[ 0.420306] pci_bus 0000:02: resource 0 [io 0xf000-0xffff]
[ 0.420307] pci_bus 0000:02: resource 1 [mem 0xfe600000-0xfe6fffff]
[ 0.420308] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.420309] pci_bus 0000:03: resource 1 [mem 0xfe500000-0xfe5fffff]
[ 0.420309] pci_bus 0000:03: resource 2 [mem 0xf0400000-0xf05fffff 64bit pref]
[ 0.420310] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 0.420311] pci_bus 0000:04: resource 1 [mem 0xfe000000-0xfe4fffff]
[ 0.420312] pci_bus 0000:04: resource 2 [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.420465] pci 0000:04:00.1: D0 power state depends on 0000:04:00.0
[ 0.420511] pci 0000:04:00.3: extending delay after power-on from D3hot to 20 msec
[ 0.420736] pci 0000:04:00.4: extending delay after power-on from D3hot to 20 msec
[ 0.420810] PCI: CLS 64 bytes, default 64
[ 0.420856] Trying to unpack rootfs image as initramfs...
[ 0.520062] Freeing initrd memory: 9380K
[ 0.520094] pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
[ 0.520207] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 0.520208] pci 0000:00:00.2: PCI INT A: not connected
[ 0.520245] pci 0000:00:01.0: Adding to iommu group 0
[ 0.520256] pci 0000:00:01.4: Adding to iommu group 1
[ 0.520265] pci 0000:00:01.5: Adding to iommu group 2
[ 0.520274] pci 0000:00:01.7: Adding to iommu group 3
[ 0.520290] pci 0000:00:08.0: Adding to iommu group 4
[ 0.520299] pci 0000:00:08.1: Adding to iommu group 5
[ 0.520311] pci 0000:00:14.0: Adding to iommu group 6
[ 0.520318] pci 0000:00:14.3: Adding to iommu group 6
[ 0.520346] pci 0000:00:18.0: Adding to iommu group 7
[ 0.520354] pci 0000:00:18.1: Adding to iommu group 7
[ 0.520361] pci 0000:00:18.2: Adding to iommu group 7
[ 0.520370] pci 0000:00:18.3: Adding to iommu group 7
[ 0.520378] pci 0000:00:18.4: Adding to iommu group 7
[ 0.520386] pci 0000:00:18.5: Adding to iommu group 7
[ 0.520394] pci 0000:00:18.6: Adding to iommu group 7
[ 0.520402] pci 0000:00:18.7: Adding to iommu group 7
[ 0.520412] pci 0000:01:00.0: Adding to iommu group 8
[ 0.520421] pci 0000:02:00.0: Adding to iommu group 9
[ 0.520430] pci 0000:03:00.0: Adding to iommu group 10
[ 0.520455] pci 0000:04:00.0: Adding to iommu group 11
[ 0.520484] pci 0000:04:00.1: Adding to iommu group 12
[ 0.520503] pci 0000:04:00.2: Adding to iommu group 12
[ 0.520514] pci 0000:04:00.3: Adding to iommu group 12
[ 0.520525] pci 0000:04:00.4: Adding to iommu group 12
[ 0.520537] pci 0000:04:00.5: Adding to iommu group 12
[ 0.520547] pci 0000:04:00.6: Adding to iommu group 12
[ 0.520559] pci 0000:04:00.7: Adding to iommu group 12
[ 0.522580] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.522582] pci 0000:00:00.2: AMD-Vi: Extended features (0x4f77ef22294ada):
[ 0.522582] PPR NX GT IA GA PC GA_vAPIC
[ 0.522585] AMD-Vi: Interrupt remapping enabled
[ 0.522585] AMD-Vi: Virtual APIC enabled
[ 0.522811] AMD-Vi: Lazy IO/TLB flushing enabled
[ 0.523825] amd_uncore: AMD NB counters detected
[ 0.523828] amd_uncore: AMD LLC counters detected
[ 0.524144] check: Scanning for low memory corruption every 60 seconds
[ 0.524523] Initialise system trusted keyrings
[ 0.524545] Key type blacklist registered
[ 0.524635] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 0.525447] zbud: loaded
[ 0.534063] Key type asymmetric registered
[ 0.534065] Asymmetric key parser 'x509' registered
[ 0.534071] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.534469] io scheduler mq-deadline registered
[ 0.534470] io scheduler kyber registered
[ 0.534486] io scheduler bfq registered
[ 0.534875] pcieport 0000:00:01.4: PME: Signaling with IRQ 8
[ 0.534951] pcieport 0000:00:01.4: AER: enabled with IRQ 8
[ 0.534972] pcieport 0000:00:01.4: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.535138] pcieport 0000:00:01.5: PME: Signaling with IRQ 9
[ 0.535184] pcieport 0000:00:01.5: AER: enabled with IRQ 9
[ 0.535311] pcieport 0000:00:01.7: PME: Signaling with IRQ 10
[ 0.535366] pcieport 0000:00:01.7: AER: enabled with IRQ 10
[ 0.535383] pcieport 0000:00:01.7: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.535533] pcieport 0000:00:08.1: PME: Signaling with IRQ 11
[ 0.535624] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.535687] efifb: probing for efifb
[ 0.535725] efifb: showing boot graphics
[ 0.537985] efifb: framebuffer at 0xe0000000, using 8128k, total 8128k
[ 0.537986] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.537986] efifb: scrolling: redraw
[ 0.537988] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.538113] Console: switching to colour frame buffer device 240x67
[ 0.541232] fb0: EFI VGA frame buffer device
[ 0.541293] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.541315] ACPI: Power Button [PWRB]
[ 0.541345] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.541356] ACPI: Lid Switch [LID0]
[ 0.541439] ACPI: Video Device [VGA1] (multi-head: yes rom: no post: no)
[ 0.541597] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0e/LNXVIDEO:01/input/input2
[ 0.541644] Monitor-Mwait will be used to enter C-1 state
[ 0.541652] ACPI: \_PR_.P000: Found 2 idle states
[ 0.541757] ACPI: \_PR_.P001: Found 2 idle states
[ 0.542227] ACPI: \_PR_.P002: Found 2 idle states
[ 0.542356] ACPI: \_PR_.P003: Found 2 idle states
[ 0.542431] ACPI: \_PR_.P004: Found 2 idle states
[ 0.542493] ACPI: \_PR_.P005: Found 2 idle states
[ 0.542578] ACPI: \_PR_.P006: Found 2 idle states
[ 0.542722] ACPI: \_PR_.P007: Found 2 idle states
[ 0.561188] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.561189] ACPI: Thermal Zone [TZS0] (31 C)
[ 0.561577] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.561578] ACPI: Thermal Zone [TZS1] (29 C)
[ 0.561799] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.562466] hpet_acpi_add: no address or irqs in _CRS
[ 0.562471] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.563416] nvme nvme0: pci function 0000:03:00.0
[ 0.563489] usbcore: registered new interface driver usbserial_generic
[ 0.563493] usbserial: USB Serial support registered for generic
[ 0.563502] rtc_cmos 00:01: RTC can wake from S4
[ 0.563598] rtc_cmos 00:01: registered as rtc0
[ 0.563683] rtc_cmos 00:01: setting system clock to 2020-09-04T15:09:20 UTC (1599232160)
[ 0.563701] rtc_cmos 00:01: no alarms, y3k, 114 bytes nvram
[ 0.563867] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.563969] drop_monitor: Initializing network drop monitor service
[ 0.564130] NET: Registered protocol family 10
[ 0.568344] Segment Routing with IPv6
[ 0.568345] RPL Segment Routing with IPv6
[ 0.568374] NET: Registered protocol family 17
[ 0.569017] microcode: CPU0: patch_level=0x08108102
[ 0.569028] microcode: CPU1: patch_level=0x08108102
[ 0.569036] microcode: CPU2: patch_level=0x08108102
[ 0.569043] microcode: CPU3: patch_level=0x08108102
[ 0.569047] microcode: CPU4: patch_level=0x08108102
[ 0.569055] microcode: CPU5: patch_level=0x08108102
[ 0.569059] microcode: CPU6: patch_level=0x08108102
[ 0.569066] microcode: CPU7: patch_level=0x08108102
[ 0.569114] microcode: Microcode Update Driver: v2.2.
[ 0.569118] IPI shorthand broadcast: enabled
[ 0.569126] sched_clock: Marking stable (395916913, 173192665)->(680083669, -110974091)
[ 0.569221] registered taskstats version 1
[ 0.569235] Loading compiled-in X.509 certificates
[ 0.571611] Loaded X.509 cert 'Build time autogenerated kernel key: 05ba798b007f7aa1c687d033889cafa88068d31a'
[ 0.573420] zswap: loaded using pool zstd/z3fold
[ 0.573648] Key type ._fscrypt registered
[ 0.573649] Key type .fscrypt registered
[ 0.573649] Key type fscrypt-provisioning registered
[ 0.573705] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.574236] PM: Magic number: 4:525:183
[ 0.574343] nvme nvme0: 8/0/0 default/read/poll queues
[ 0.574448] RAS: Correctable Errors collector initialized.
[ 0.575983] nvme0n1: p1 p2
[ 0.578631] Freeing unused decrypted memory: 2040K
[ 0.578960] Freeing unused kernel image (initmem) memory: 1656K
[ 0.594165] Write protecting the kernel read-only data: 22528k
[ 0.595060] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 0.595402] Freeing unused kernel image (rodata/data gap) memory: 1436K
[ 0.629271] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.629277] Run /init as init process
[ 0.629279] with arguments:
[ 0.629279] /init
[ 0.629280] with environment:
[ 0.629280] HOME=/
[ 0.629280] TERM=linux
[ 0.629281] BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
[ 0.736596] i8042: PNP: PS/2 Controller [PNP0303:KBD0] at 0x60,0x64 irq 5
[ 0.736598] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.738100] serio: i8042 KBD port at 0x60,0x64 irq 5
[ 0.738762] rtsx_pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 0.745346] xhci_hcd 0000:04:00.3: xHCI Host Controller
[ 0.745352] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 1
[ 0.745520] xhci_hcd 0000:04:00.3: hcc params 0x0270ffe5 hci version 0x110 quirks 0x0000000840000410
[ 0.745934] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 0.745936] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.745938] usb usb1: Product: xHCI Host Controller
[ 0.745939] usb usb1: Manufacturer: Linux 5.9.0-1-MANJARO xhci-hcd
[ 0.745940] usb usb1: SerialNumber: 0000:04:00.3
[ 0.746066] hub 1-0:1.0: USB hub found
[ 0.746081] hub 1-0:1.0: 4 ports detected
[ 0.746849] xhci_hcd 0000:04:00.3: xHCI Host Controller
[ 0.746853] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 2
[ 0.746856] xhci_hcd 0000:04:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.746884] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.746902] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 0.746904] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.746905] usb usb2: Product: xHCI Host Controller
[ 0.746906] usb usb2: Manufacturer: Linux 5.9.0-1-MANJARO xhci-hcd
[ 0.746906] usb usb2: SerialNumber: 0000:04:00.3
[ 0.746996] hub 2-0:1.0: USB hub found
[ 0.747004] hub 2-0:1.0: 4 ports detected
[ 0.747938] xhci_hcd 0000:04:00.4: xHCI Host Controller
[ 0.747944] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 3
[ 0.748107] xhci_hcd 0000:04:00.4: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000840000410
[ 0.748555] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 0.748557] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.748558] usb usb3: Product: xHCI Host Controller
[ 0.748560] usb usb3: Manufacturer: Linux 5.9.0-1-MANJARO xhci-hcd
[ 0.748561] usb usb3: SerialNumber: 0000:04:00.4
[ 0.748718] hub 3-0:1.0: USB hub found
[ 0.748725] hub 3-0:1.0: 2 ports detected
[ 0.749300] xhci_hcd 0000:04:00.4: xHCI Host Controller
[ 0.749304] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 4
[ 0.749308] xhci_hcd 0000:04:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.749353] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.749379] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 0.749381] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.749382] usb usb4: Product: xHCI Host Controller
[ 0.749383] usb usb4: Manufacturer: Linux 5.9.0-1-MANJARO xhci-hcd
[ 0.749384] usb usb4: SerialNumber: 0000:04:00.4
[ 0.749514] hub 4-0:1.0: USB hub found
[ 0.749527] hub 4-0:1.0: 1 port detected
[ 0.763712] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.806522] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.840366] random: fast init done
[ 0.888516] systemd[1]: systemd 246.3-2-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 0.888633] systemd[1]: Detected architecture x86-64.
[ 0.911909] systemd[1]: Set hostname to <HPenvy>.
[ 1.027372] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.028170] systemd[1]: Created slice system-getty.slice.
[ 1.028363] systemd[1]: Created slice system-modprobe.slice.
[ 1.028519] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 1.028729] systemd[1]: Created slice User and Session Slice.
[ 1.028777] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 1.028808] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.028942] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.028970] systemd[1]: Reached target Local Encrypted Volumes.
[ 1.028981] systemd[1]: Reached target Login Prompts.
[ 1.029004] systemd[1]: Reached target Remote File Systems.
[ 1.029014] systemd[1]: Reached target Slices.
[ 1.029029] systemd[1]: Reached target Swap.
[ 1.029094] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.029174] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 1.029309] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.030673] systemd[1]: Listening on Process Core Dump Socket.
[ 1.030777] systemd[1]: Listening on Journal Audit Socket.
[ 1.030840] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.030911] systemd[1]: Listening on Journal Socket.
[ 1.030986] systemd[1]: Listening on udev Control Socket.
[ 1.031039] systemd[1]: Listening on udev Kernel Socket.
[ 1.031736] systemd[1]: Mounting Huge Pages File System...
[ 1.032345] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.033026] systemd[1]: Mounting Kernel Debug File System...
[ 1.033730] systemd[1]: Mounting Kernel Trace File System...
[ 1.035172] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 1.035963] systemd[1]: Starting Load AppArmor profiles...
[ 1.036646] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 1.037363] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 1.038046] systemd[1]: Starting Load Kernel Module drm...
[ 1.039238] systemd[1]: Starting Set Up Additional Binary Formats...
[ 1.039317] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 1.040617] systemd[1]: Starting Journal Service...
[ 1.041618] systemd[1]: Starting Load Kernel Modules...
[ 1.042378] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 1.042429] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 1.043175] systemd[1]: Starting Coldplug All udev Devices...
[ 1.044705] systemd[1]: Mounted Huge Pages File System.
[ 1.044810] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.044898] systemd[1]: Mounted Kernel Debug File System.
[ 1.044992] systemd[1]: Mounted Kernel Trace File System.
[ 1.045107] systemd[1]: Mounted Temporary Directory (/tmp).
[ 1.045535] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 1.046699] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 240 (systemd-binfmt)
[ 1.047912] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 1.047988] Linux agpgart interface v0.103
[ 1.050934] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 1.052123] systemd[1]: Finished Set Up Additional Binary Formats.
[ 1.053414] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
[ 1.054845] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 1.055060] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 1.056137] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 1.056539] random: lvm: uninitialized urandom read (4 bytes read)
[ 1.057322] systemd[1]: Starting Load/Save Random Seed...
[ 1.057414] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 1.058572] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 1.062283] systemd[1]: Finished Load Kernel Modules.
[ 1.062598] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 1.063787] systemd[1]: Mounting Kernel Configuration File System...
[ 1.065095] systemd[1]: Starting Apply Kernel Variables...
[ 1.066823] systemd[1]: Mounted Kernel Configuration File System.
[ 1.072166] systemd[1]: Finished Apply Kernel Variables.
[ 1.074500] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 1.075998] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 1.076754] usb 1-3: new low-speed USB device number 2 using xhci_hcd
[ 1.080115] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[ 1.084608] systemd[1]: modprobe@drm.service: Succeeded.
[ 1.084972] systemd[1]: Finished Load Kernel Module drm.
[ 1.103435] systemd[1]: Finished Coldplug All udev Devices.
[ 1.161096] audit: type=1400 audit(1599232161.096:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=280 comm="apparmor_parser"
[ 1.227340] audit: type=1400 audit(1599232161.160:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=287 comm="apparmor_parser"
[ 1.228299] audit: type=1400 audit(1599232161.163:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=287 comm="apparmor_parser"
[ 1.233370] usb 3-1: New USB device found, idVendor=04ca, idProduct=709d, bcdDevice= 0.04
[ 1.233372] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.233374] usb 3-1: Product: HP Wide Vision HD Camera
[ 1.233376] usb 3-1: Manufacturer: DHQYLA19ICRLJF
[ 1.235025] usb 1-3: New USB device found, idVendor=1d57, idProduct=32da, bcdDevice= 1.10
[ 1.235028] usb 1-3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.235029] usb 1-3: Product: 2.4G Receiver
[ 1.357949] systemd[1]: Started Journal Service.
[ 1.358064] audit: type=1130 audit(1599232161.293:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.384476] usb 3-2: new full-speed USB device number 3 using xhci_hcd
[ 1.391141] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[ 1.415086] audit: type=1130 audit(1599232161.350:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.416200] audit: type=1130 audit(1599232161.350:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.417530] audit: type=1130 audit(1599232161.350:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.463790] acpi_cpufreq: overriding BIOS provided _PSD data
[ 1.476825] acpi-tad ACPI000E:00: Missing _PRW
[ 1.480923] input: HP Wireless hotkeys as /devices/virtual/input/input4
[ 1.535191] hid: raw HID events driver (C) Jiri Kosina
[ 1.537301] hp_accel: laptop model unknown, using default axes configuration
[ 1.541153] tsc: Refined TSC clocksource calibration: 2096.062 MHz
[ 1.541160] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1e36a88731c, max_idle_ns: 440795269020 ns
[ 1.541183] clocksource: Switched to clocksource tsc
[ 1.544457] usb 3-2: New USB device found, idVendor=0bda, idProduct=b00b, bcdDevice= 1.10
[ 1.544459] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.544473] usb 3-2: Product: Bluetooth Radio
[ 1.544474] usb 3-2: Manufacturer: Realtek
[ 1.544476] usb 3-2: SerialNumber: 00e04c000001
[ 1.544856] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xd7d0a000-0xd7d0afff flags 0x200] vs d7d0a000 4000
[ 1.544897] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xd7d0e000-0xd7d0efff flags 0x200] vs d7d0e000 4000
[ 1.552100] usb 1-4: New USB device found, idVendor=06cb, idProduct=00d2, bcdDevice= 1.64
[ 1.552104] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 1.552106] usb 1-4: SerialNumber: acef940dc72a
[ 1.555730] ACPI: AC Adapter [ADP1] (off-line)
[ 1.556495] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.556587] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.556677] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.558706] i2c_hid i2c-ELAN2514:00: supply vdd not found, using dummy regulator
[ 1.558757] i2c_hid i2c-ELAN2514:00: supply vddl not found, using dummy regulator
[ 1.570525] ACPI: EC: interrupt unblocked
[ 1.570528] ACPI: EC: event unblocked
[ 1.570560] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 1.570582] ACPI: EC: IRQ=47
[ 1.570616] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[ 1.570647] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 1.575673] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 1.603976] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 1.603980] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 1.604140] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 1.607103] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 1.607297] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ 1.607312] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 1.618106] lis3lv02d: unknown sensor type 0x0
[ 1.618121] hp_accel: probe of HPQ6007:00 failed with error -22
[ 1.622533] random: mktemp: uninitialized urandom read (6 bytes read)
[ 1.624745] random: mktemp: uninitialized urandom read (6 bytes read)
[ 1.647264] audit: type=1400 audit(1599232161.577:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=297 comm="apparmor_parser"
[ 1.648422] audit: type=1400 audit(1599232161.580:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=297 comm="apparmor_parser"
[ 1.662074] snd_pci_acp3x 0000:04:00.5: enabling device (0000 -> 0002)
[ 1.662307] snd_pci_acp3x 0000:04:00.5: Invalid ACP audio mode : 1
[ 1.666732] ccp 0000:04:00.2: enabling device (0000 -> 0002)
[ 1.678248] ccp 0000:04:00.2: ccp enabled
[ 1.678265] ccp 0000:04:00.2: psp: unable to access the device: you might be running a broken BIOS.
[ 1.709170] snd_rn_pci_acp3x: probe of 0000:04:00.5 failed with error -22
[ 1.734965] i2c_hid i2c-SYNA328F:01: supply vdd not found, using dummy regulator
[ 1.735034] i2c_hid i2c-SYNA328F:01: supply vddl not found, using dummy regulator
[ 1.735512] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 1.796842] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 1.796846] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 1.796941] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.801002] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.877468] cryptd: max_cpu_qlen set to 1000
[ 1.960908] AVX2 version of gcm_enc/dec engaged.
[ 1.960911] AES CTR mode by8 optimization enabled
[ 1.990584] snd_hda_intel 0000:04:00.1: enabling device (0000 -> 0002)
[ 1.990787] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[ 1.991000] snd_hda_intel 0000:04:00.6: enabling device (0000 -> 0002)
[ 2.101158] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input6
[ 2.112169] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC285: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 2.112173] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.112175] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 2.112176] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 2.112177] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 2.112179] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 2.112180] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 2.112296] kvm: disabled by bios
[ 2.200767] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input7
[ 2.200831] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input8
[ 2.214718] random: crng init done
[ 2.214723] random: 5 urandom warning(s) missed due to ratelimiting
[ 2.233446] rtw_8822be 0000:02:00.0: enabling device (0000 -> 0003)
[ 2.235074] MCE: In-kernel MCE decoding enabled.
[ 2.235446] rtw_8822be 0000:02:00.0: Firmware version 27.2.0, H2C version 13
[ 2.240617] kvm: disabled by bios
[ 2.242245] EDAC amd64: F17h_M10h detected (node 0).
[ 2.242383] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.253880] input: HP WMI hotkeys as /devices/virtual/input/input9
[ 2.363212] acer_wmi: Acer Laptop ACPI-WMI Extras
[ 2.382888] input: ELAN2514:00 04F3:23B9 Touchscreen as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN2514:00/0018:04F3:23B9.0001/input/input10
[ 2.383024] input: ELAN2514:00 04F3:23B9 as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN2514:00/0018:04F3:23B9.0001/input/input11
[ 2.385197] input: ELAN2514:00 04F3:23B9 as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN2514:00/0018:04F3:23B9.0001/input/input12
[ 2.385309] input: ELAN2514:00 04F3:23B9 as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN2514:00/0018:04F3:23B9.0001/input/input13
[ 2.385402] hid-generic 0018:04F3:23B9.0001: input,hidraw0: I2C HID v1.00 Device [ELAN2514:00 04F3:23B9] on i2c-ELAN2514:00
[ 2.386146] input: SYNA328F:01 06CB:CDBD Mouse as /devices/platform/AMDI0010:01/i2c-1/i2c-SYNA328F:01/0018:06CB:CDBD.0002/input/input16
[ 2.389956] input: SYNA328F:01 06CB:CDBD Touchpad as /devices/platform/AMDI0010:01/i2c-1/i2c-SYNA328F:01/0018:06CB:CDBD.0002/input/input17
[ 2.390095] hid-generic 0018:06CB:CDBD.0002: input,hidraw1: I2C HID v1.00 Mouse [SYNA328F:01 06CB:CDBD] on i2c-SYNA328F:01
[ 2.390596] kvm: disabled by bios
[ 2.470244] rtw_8822be 0000:02:00.0 wlo1: renamed from wlan0
[ 2.708499] EDAC amd64: F17h_M10h detected (node 0).
[ 2.708613] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.796013] input: ELAN2514:00 04F3:23B9 as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN2514:00/0018:04F3:23B9.0001/input/input19
[ 2.796144] input: ELAN2514:00 04F3:23B9 UNKNOWN as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN2514:00/0018:04F3:23B9.0001/input/input20
[ 2.796204] input: ELAN2514:00 04F3:23B9 UNKNOWN as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN2514:00/0018:04F3:23B9.0001/input/input21
[ 2.796265] input: ELAN2514:00 04F3:23B9 as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN2514:00/0018:04F3:23B9.0001/input/input22
[ 2.796359] hid-multitouch 0018:04F3:23B9.0001: input,hidraw0: I2C HID v1.00 Device [ELAN2514:00 04F3:23B9] on i2c-ELAN2514:00
[ 2.824949] EDAC amd64: F17h_M10h detected (node 0).
[ 2.824950] kvm: disabled by bios
[ 2.825040] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.872882] input: SYNA328F:01 06CB:CDBD Mouse as /devices/platform/AMDI0010:01/i2c-1/i2c-SYNA328F:01/0018:06CB:CDBD.0002/input/input25
[ 2.872995] input: SYNA328F:01 06CB:CDBD Touchpad as /devices/platform/AMDI0010:01/i2c-1/i2c-SYNA328F:01/0018:06CB:CDBD.0002/input/input26
[ 2.873083] hid-multitouch 0018:06CB:CDBD.0002: input,hidraw1: I2C HID v1.00 Mouse [SYNA328F:01 06CB:CDBD] on i2c-SYNA328F:01
[ 2.933383] mc: Linux media interface: v0.10
[ 2.936024] [drm] amdgpu kernel modesetting enabled.
[ 2.939099] mousedev: PS/2 mouse device common for all mice
[ 2.945804] amdgpu: Topology: Add APU node [0x0:0x0]
[ 2.946114] checking generic (e0000000 7f0000) vs hw (e0000000 10000000)
[ 2.946120] fb0: switching to amdgpudrmfb from EFI VGA
[ 2.946351] Console: switching to colour dummy device 80x25
[ 2.946485] amdgpu 0000:04:00.0: vgaarb: deactivate vga console
[ 2.946632] amdgpu 0000:04:00.0: enabling device (0006 -> 0007)
[ 2.950420] [drm] initializing kernel modesetting (RAVEN 0x1002:0x15D8 0x103C:0x85DE 0xC2).
[ 2.950431] amdgpu 0000:04:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 2.961406] [drm] register mmio base: 0xFE400000
[ 2.961410] [drm] register mmio size: 524288
[ 2.961438] [drm] add ip block number 0 <soc15_common>
[ 2.961440] [drm] add ip block number 1 <gmc_v9_0>
[ 2.961441] [drm] add ip block number 2 <vega10_ih>
[ 2.961443] [drm] add ip block number 3 <psp>
[ 2.961444] [drm] add ip block number 4 <gfx_v9_0>
[ 2.961446] [drm] add ip block number 5 <sdma_v4_0>
[ 2.961448] [drm] add ip block number 6 <powerplay>
[ 2.961450] [drm] add ip block number 7 <dm>
[ 2.961451] [drm] add ip block number 8 <vcn_v1_0>
[ 2.961898] amdgpu: ATOM BIOS: 113-PICASSO-114
[ 2.962216] [drm] VCN decode is enabled in VM mode
[ 2.962217] [drm] VCN encode is enabled in VM mode
[ 2.962218] [drm] JPEG decode is enabled in VM mode
[ 2.962279] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 2.962299] amdgpu 0000:04:00.0: amdgpu: VRAM: 2048M 0x000000F400000000 - 0x000000F47FFFFFFF (2048M used)
[ 2.962302] amdgpu 0000:04:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 2.962305] amdgpu 0000:04:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[ 2.962312] [drm] Detected VRAM RAM=2048M, BAR=2048M
[ 2.962314] [drm] RAM width 128bits DDR4
[ 2.962407] [TTM] Zone kernel: Available graphics memory: 3010260 KiB
[ 2.962408] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 2.962410] [TTM] Initializing pool allocator
[ 2.962418] [TTM] Initializing DMA pool allocator
[ 2.962551] [drm] amdgpu: 2048M of VRAM memory ready
[ 2.962557] [drm] amdgpu: 3072M of GTT memory ready.
[ 2.962560] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 2.962862] [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
[ 2.966809] EDAC amd64: F17h_M10h detected (node 0).
[ 2.966889] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.968366] kvm: disabled by bios
[ 2.972566] input: 2.4G Receiver as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.0/0003:1D57:32DA.0003/input/input28
[ 2.976029] amdgpu: hwmgr_sw_init smu backed is smu10_smu
[ 2.977599] [drm] Found VCN firmware Version ENC: 1.9 DEC: 1 VEP: 0 Revision: 28
[ 2.977621] [drm] PSP loading VCN firmware
[ 3.003464] [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
[ 3.019970] loop: module loaded
[ 3.028372] hid-generic 0003:1D57:32DA.0003: input,hidraw2: USB HID v1.10 Keyboard [2.4G Receiver] on usb-0000:04:00.3-3/input0
[ 3.033806] input: 2.4G Receiver as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.1/0003:1D57:32DA.0004/input/input29
[ 3.034440] hid-generic 0003:1D57:32DA.0004: input,hidraw3: USB HID v1.10 Mouse [2.4G Receiver] on usb-0000:04:00.3-3/input1
[ 3.041703] input: 2.4G Receiver System Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.2/0003:1D57:32DA.0005/input/input30
[ 3.098150] input: 2.4G Receiver Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.2/0003:1D57:32DA.0005/input/input31
[ 3.098343] hid-generic 0003:1D57:32DA.0005: input,hidraw4: USB HID v1.10 Device [2.4G Receiver] on usb-0000:04:00.3-3/input2
[ 3.098433] usbcore: registered new interface driver usbhid
[ 3.098435] usbhid: USB HID core driver
[ 3.118573] videodev: Linux video capture interface: v2.00
[ 3.119911] EDAC amd64: F17h_M10h detected (node 0).
[ 3.119992] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.122321] kvm: disabled by bios
[ 3.122562] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.130792] Bluetooth: Core ver 2.22
[ 3.130839] NET: Registered protocol family 31
[ 3.130841] Bluetooth: HCI device and connection manager initialized
[ 3.130848] Bluetooth: HCI socket layer initialized
[ 3.130852] Bluetooth: L2CAP socket layer initialized
[ 3.130862] Bluetooth: SCO socket layer initialized
[ 3.200416] usbcore: registered new interface driver btusb
[ 3.201858] kvm: disabled by bios
[ 3.203620] EDAC amd64: F17h_M10h detected (node 0).
[ 3.203750] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.203797] Bluetooth: hci0: RTL: examining hci_ver=07 hci_rev=000b lmp_ver=07 lmp_subver=8822
[ 3.205494] Bluetooth: hci0: RTL: rom_version status=0 version=2
[ 3.205498] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_fw.bin
[ 3.206049] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_config.bin
[ 3.206275] Bluetooth: hci0: RTL: cfg_sz 14, total sz 20270
[ 3.215482] uvcvideo: Found UVC 1.00 device HP Wide Vision HD Camera (04ca:709d)
[ 3.234366] uvcvideo 3-1:1.0: Entity type for entity Extension 4 was not initialized!
[ 3.234370] uvcvideo 3-1:1.0: Entity type for entity Extension 3 was not initialized!
[ 3.234372] uvcvideo 3-1:1.0: Entity type for entity Processing 2 was not initialized!
[ 3.234374] uvcvideo 3-1:1.0: Entity type for entity Camera 1 was not initialized!
[ 3.234556] input: HP Wide Vision HD Camera: HP Wi as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1:1.0/input/input32
[ 3.234993] usbcore: registered new interface driver uvcvideo
[ 3.234998] USB Video Class driver (1.1.1)
[ 3.259786] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.259789] Bluetooth: BNEP filters: protocol multicast
[ 3.259798] Bluetooth: BNEP socket layer initialized
[ 3.262003] kvm: disabled by bios
[ 3.263711] EDAC amd64: F17h_M10h detected (node 0).
[ 3.263798] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.271191] amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 3.296984] [drm] kiq ring mec 2 pipe 1 q 0
[ 3.298246] [drm] DM_PPLIB: values for F clock
[ 3.298248] [drm] DM_PPLIB: 400000 in kHz, 2974 in mV
[ 3.298249] [drm] DM_PPLIB: 933000 in kHz, 3274 in mV
[ 3.298250] [drm] DM_PPLIB: 1067000 in kHz, 3924 in mV
[ 3.298250] [drm] DM_PPLIB: 1200000 in kHz, 4074 in mV
[ 3.298252] [drm] DM_PPLIB: values for DCF clock
[ 3.298252] [drm] DM_PPLIB: 300000 in kHz, 2974 in mV
[ 3.298253] [drm] DM_PPLIB: 600000 in kHz, 3274 in mV
[ 3.298254] [drm] DM_PPLIB: 626000 in kHz, 3924 in mV
[ 3.298254] [drm] DM_PPLIB: 654000 in kHz, 4074 in mV
[ 3.298622] [drm] Display Core initialized with v3.2.95!
[ 3.302115] snd_hda_intel 0000:04:00.1: bound 0000:04:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 3.310943] EDAC amd64: F17h_M10h detected (node 0).
[ 3.311074] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.355610] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 3.357986] kfd kfd: Allocated 3969056 bytes on gart
[ 3.359445] amdgpu: Topology: Add APU node [0x15d8:0x1002]
[ 3.359450] kfd kfd: added device 1002:15d8
[ 3.359454] amdgpu 0000:04:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 11, active_cu_number 8
[ 3.361736] [drm] fb mappable at 0x19FBCA000
[ 3.361738] [drm] vram apper at 0x19F000000
[ 3.361739] [drm] size 8294400
[ 3.361740] [drm] fb depth is 24
[ 3.361740] [drm] pitch is 7680
[ 3.361861] fbcon: amdgpudrmfb (fb0) is primary device
[ 3.385955] Console: switching to colour frame buffer device 240x67
[ 3.406602] amdgpu 0000:04:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 3.424694] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 3.424699] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 3.424702] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 3.424704] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 3.424707] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 3.424709] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 3.424711] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 3.424714] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 3.424716] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 3.424718] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 3.424721] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[ 3.424724] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[ 3.424726] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[ 3.424728] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[ 3.424731] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[ 3.449144] [drm] Initialized amdgpu 3.39.0 20150101 for 0000:04:00.0 on minor 0
[ 3.728024] rtw_8822be 0000:02:00.0: start vif 40:23:43:82:63:bf on port 0
[ 3.729375] rtw_8822be 0000:02:00.0: stop vif 40:23:43:82:63:bf on port 0
[ 4.110763] Bluetooth: hci0: RTL: fw version 0xab6b705c
[ 4.205222] rtw_8822be 0000:02:00.0: start vif be:8f:c3:c7:ea:89 on port 0
[ 4.239354] NET: Registered protocol family 38
[ 5.350204] kauditd_printk_skb: 45 callbacks suppressed
[ 5.350208] audit: type=1130 audit(1599232165.280:56): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.361321] audit: type=1105 audit(1599232165.294:57): pid=1282 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
[ 6.020153] audit: type=1130 audit(1599232165.950:58): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.026962] audit: type=1334 audit(1599232165.957:59): prog-id=12 op=LOAD
[ 6.027034] audit: type=1334 audit(1599232165.957:60): prog-id=13 op=LOAD
[ 6.756749] audit: type=1130 audit(1599232166.687:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8.190898] audit: type=1131 audit(1599232168.120:62): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8.224097] audit: type=1131 audit(1599232168.157:63): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.186583] audit: type=1131 audit(1599232173.117:64): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.130025] audit: type=1130 audit(1599232177.060:65): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.164563] audit: type=1130 audit(1599232177.097:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.297846] audit: type=1131 audit(1599232193.227:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.407996] audit: type=1334 audit(1599232193.340:68): prog-id=10 op=UNLOAD
[ 33.408004] audit: type=1334 audit(1599232193.340:69): prog-id=9 op=UNLOAD
[ 72.395241] audit: type=1100 audit(1599232232.327:70): pid=1363 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="marko" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 72.397571] audit: type=1101 audit(1599232232.327:71): pid=1363 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="marko" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 72.398366] audit: type=1103 audit(1599232232.330:72): pid=1363 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="marko" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 72.398506] audit: type=1006 audit(1599232232.330:73): pid=1363 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 72.409803] rtw_8822be 0000:02:00.0: stop vif be:8f:c3:c7:ea:89 on port 0
[ 72.433987] audit: type=1130 audit(1599232232.364:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 72.446388] audit: type=1101 audit(1599232232.377:75): pid=1365 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="marko" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 72.446403] audit: type=1103 audit(1599232232.377:76): pid=1365 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="marko" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 72.446517] audit: type=1006 audit(1599232232.377:77): pid=1365 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 72.447950] audit: type=1105 audit(1599232232.380:78): pid=1365 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="marko" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 72.456803] audit: type=1334 audit(1599232232.387:79): prog-id=14 op=LOAD
[ 72.830728] fuse: init (API version 7.31)
[ 72.892617] rtw_8822be 0000:02:00.0: start vif 40:23:43:82:63:bf on port 0
[ 72.899902] rtw_8822be 0000:02:00.0: stop vif 40:23:43:82:63:bf on port 0
[ 73.382076] rtw_8822be 0000:02:00.0: start vif be:8e:ac:a2:da:11 on port 0
[ 74.767248] Bluetooth: RFCOMM TTY layer initialized
[ 74.767266] Bluetooth: RFCOMM socket layer initialized
[ 74.767281] Bluetooth: RFCOMM ver 1.11
[ 82.766007] kauditd_printk_skb: 6 callbacks suppressed
[ 82.766012] audit: type=1131 audit(1599232242.697:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 82.781932] audit: type=1131 audit(1599232242.714:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 90.595291] rtw_8822be 0000:02:00.0: stop vif be:8e:ac:a2:da:11 on port 0
[ 91.079115] rtw_8822be 0000:02:00.0: start vif 40:23:43:82:63:bf on port 0
[ 95.399049] wlo1: authenticate with 90:ef:68:d8:d1:c9
[ 95.928258] wlo1: send auth to 90:ef:68:d8:d1:c9 (try 1/3)
[ 95.930307] wlo1: authenticated
[ 95.931161] wlo1: associate with 90:ef:68:d8:d1:c9 (try 1/3)
[ 95.937294] wlo1: RX AssocResp from 90:ef:68:d8:d1:c9 (capab=0x411 status=0 aid=5)
[ 95.937333] rtw_8822be 0000:02:00.0: sta 90:ef:68:d8:d1:c9 joined with macid 0
[ 95.937646] wlo1: associated
[ 95.997767] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 96.255967] audit: type=1130 audit(1599232256.187:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 106.185061] audit: type=1131 audit(1599232266.117:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 851.422182] audit: type=1130 audit(1599233010.450:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 905.780084] audit: type=1130 audit(1599233064.810:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 905.780092] audit: type=1131 audit(1599233064.810:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 942.534796] audit: type=1131 audit(1599233101.564:93): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1116.018165] audit: type=1130 audit(1599233275.048:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1145.773664] audit: type=1131 audit(1599233304.805:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1899.014313] wlo1: failed to use reserved channel context, disconnecting (err=-95)
[ 1899.014316] wlo1: failed to finalize channel switch, disconnecting
[ 1899.224354] rtw_8822be 0000:02:00.0: sta 90:ef:68:d8:d1:c9 with macid 0 left
[ 1903.602120] wlo1: authenticate with 90:ef:68:d8:d1:c9
[ 1904.133582] wlo1: send auth to 90:ef:68:d8:d1:c9 (try 1/3)
[ 1904.145559] wlo1: authenticated
[ 1904.146893] wlo1: associate with 90:ef:68:d8:d1:c9 (try 1/3)
[ 1904.159279] wlo1: RX AssocResp from 90:ef:68:d8:d1:c9 (capab=0x411 status=0 aid=2)
[ 1904.159311] rtw_8822be 0000:02:00.0: sta 90:ef:68:d8:d1:c9 joined with macid 0
[ 1904.159590] wlo1: associated
[ 3399.575974] wlo1: AP 90:ef:68:d8:d1:c9 changed bandwidth, new config is 2462.000 MHz, width 2 (2452.000/0 MHz)
[ 3399.869792] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 3506.695911] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 3821.707629] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 3840.827518] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 3936.513053] wlo1: deauthenticated from 90:ef:68:d8:d1:c9 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[ 3936.637184] rtw_8822be 0000:02:00.0: sta 90:ef:68:d8:d1:c9 with macid 0 left
[ 3937.173506] wlo1: authenticate with 90:ef:68:d8:d1:c9
[ 3937.707047] wlo1: send auth to 90:ef:68:d8:d1:c9 (try 1/3)
[ 3937.708635] wlo1: authenticated
[ 3937.709662] wlo1: associate with 90:ef:68:d8:d1:c9 (try 1/3)
[ 3937.713400] wlo1: RX AssocResp from 90:ef:68:d8:d1:c9 (capab=0x411 status=0 aid=2)
[ 3937.713431] rtw_8822be 0000:02:00.0: sta 90:ef:68:d8:d1:c9 joined with macid 0
[ 3937.713707] wlo1: associated
[ 5258.144452] wlo1: AP 90:ef:68:d8:d1:c9 changed bandwidth, new config is 2462.000 MHz, width 1 (2462.000/0 MHz)
[ 5606.794414] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 5687.602973] audit: type=1100 audit(1599237846.652:96): pid=17212 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="marko" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[ 5894.930030] audit: type=1111 audit(1599238053.983:97): pid=570 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=1504 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 5896.456883] audit: type=1111 audit(1599238055.510:98): pid=570 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=1504 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 6758.822589] wlo1: AP 90:ef:68:d8:d1:c9 changed bandwidth, new config is 2462.000 MHz, width 2 (2452.000/0 MHz)
[ 6819.922475] rtw_8822be 0000:02:00.0: sta 90:ef:68:d8:d1:c9 with macid 0 left
[ 6824.300331] wlo1: authenticate with 90:ef:68:d8:d1:c9
[ 6824.829021] wlo1: send auth to 90:ef:68:d8:d1:c9 (try 1/3)
[ 6824.830649] wlo1: authenticated
[ 6824.831639] wlo1: associate with 90:ef:68:d8:d1:c9 (try 1/3)
[ 6824.835401] wlo1: RX AssocResp from 90:ef:68:d8:d1:c9 (capab=0x411 status=0 aid=2)
[ 6824.835436] rtw_8822be 0000:02:00.0: sta 90:ef:68:d8:d1:c9 joined with macid 0
[ 6824.835722] wlo1: associated
[ 7602.732151] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 7787.691320] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 8028.485830] wlo1: AP 90:ef:68:d8:d1:c9 changed bandwidth, new config is 2462.000 MHz, width 1 (2462.000/0 MHz)
[ 8030.676894] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 9528.406827] wlo1: AP 90:ef:68:d8:d1:c9 changed bandwidth, new config is 2462.000 MHz, width 2 (2452.000/0 MHz)
[10361.577534] wlo1: AP 90:ef:68:d8:d1:c9 changed bandwidth, new config is 2462.000 MHz, width 1 (2462.000/0 MHz)
[11041.308465] audit: type=1130 audit(1599243200.382:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11041.308473] audit: type=1131 audit(1599243200.382:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11822.873586] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[11861.745098] wlo1: AP 90:ef:68:d8:d1:c9 changed bandwidth, new config is 2462.000 MHz, width 2 (2452.000/0 MHz)
[11865.646732] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[11879.673349] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[11971.779595] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[12003.779449] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[12443.671017] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[12459.670996] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[12491.670946] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[15228.569727] wlo1: AP 90:ef:68:d8:d1:c9 changed bandwidth, new config is 2462.000 MHz, width 1 (2462.000/0 MHz)
[16078.555528] audit: type=1100 audit(1599248237.650:101): pid=37634 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="marko" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[16173.802051] audit: type=1130 audit(1599248332.894:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16181.444131] audit: type=1100 audit(1599248340.537:103): pid=38072 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="marko" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16181.445859] audit: type=1101 audit(1599248340.537:104): pid=38072 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="marko" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[16191.491266] audit: type=1131 audit(1599248350.584:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16201.804279] audit: type=1100 audit(1599248360.897:106): pid=38252 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="marko" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[16201.806431] audit: type=1101 audit(1599248360.897:107): pid=38252 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="marko" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[16710.267909] audit: type=1100 audit(1599248869.366:108): pid=40461 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="marko" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16710.269968] audit: type=1101 audit(1599248869.366:109): pid=40461 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="marko" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16710.270322] audit: type=1110 audit(1599248869.366:110): pid=40461 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16710.274444] audit: type=1105 audit(1599248869.370:111): pid=40461 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16710.285091] audit: type=1100 audit(1599248869.383:112): pid=40465 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16710.285099] audit: type=1101 audit(1599248869.383:113): pid=40465 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16710.285514] audit: type=1103 audit(1599248869.383:114): pid=40465 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16710.285684] audit: type=1105 audit(1599248869.383:115): pid=40465 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16728.626157] wlo1: failed to use reserved channel context, disconnecting (err=-95)
[16728.626161] wlo1: failed to finalize channel switch, disconnecting
[16728.744543] rtw_8822be 0000:02:00.0: sta 90:ef:68:d8:d1:c9 with macid 0 left
[16733.115486] wlo1: authenticate with 90:ef:68:d8:d1:c9
[16733.644807] wlo1: send auth to 90:ef:68:d8:d1:c9 (try 1/3)
[16733.646606] wlo1: authenticated
[16733.647749] wlo1: associate with 90:ef:68:d8:d1:c9 (try 1/3)
[16733.653879] wlo1: RX AssocResp from 90:ef:68:d8:d1:c9 (capab=0x411 status=0 aid=2)
[16733.653905] rtw_8822be 0000:02:00.0: sta 90:ef:68:d8:d1:c9 joined with macid 0
[16733.654148] wlo1: associated
[16750.501711] audit: type=1106 audit(1599248909.600:116): pid=40465 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16750.501858] audit: type=1104 audit(1599248909.600:117): pid=40465 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16750.503438] audit: type=1106 audit(1599248909.600:118): pid=40461 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16750.503577] audit: type=1104 audit(1599248909.600:119): pid=40461 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16759.204869] audit: type=1100 audit(1599248918.303:120): pid=40574 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="marko" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[16759.206725] audit: type=1101 audit(1599248918.303:121): pid=40574 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="marko" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[16759.207111] audit: type=1110 audit(1599248918.303:122): pid=40574 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[16759.211006] audit: type=1105 audit(1599248918.310:123): pid=40574 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[16759.215931] audit: type=1100 audit(1599248918.313:124): pid=40580 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/1 res=success'
[16759.216047] audit: type=1101 audit(1599248918.313:125): pid=40580 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/1 res=success'
[16759.216622] audit: type=1103 audit(1599248918.313:126): pid=40580 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/1 res=success'
[16759.216791] audit: type=1105 audit(1599248918.313:127): pid=40580 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/1 res=success'
[16797.821294] audit: type=1100 audit(1599248956.920:128): pid=40669 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="marko" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16797.823181] audit: type=1101 audit(1599248956.920:129): pid=40669 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="marko" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16797.823515] audit: type=1110 audit(1599248956.920:130): pid=40669 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16797.827400] audit: type=1105 audit(1599248956.923:131): pid=40669 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[16797.832446] audit: type=1100 audit(1599248956.930:132): pid=40674 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16797.832529] audit: type=1101 audit(1599248956.930:133): pid=40674 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16797.833109] audit: type=1103 audit(1599248956.930:134): pid=40674 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
[16797.833278] audit: type=1105 audit(1599248956.930:135): pid=40674 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=HPenvy addr=? terminal=pts/2 res=success'
