I’m running Manjaro with LXQt on an HP laptop, model 14-fq0013dx. At first my WiFi didn’t work at all, but I was able to get it working after installing the package rtl8821ce-dkms-git from AUR through pamac. But now the WiFi will fail seemingly at random. It doesn’t fail so often that I can’t use the laptop, but if I’m streaming over Zoom for a long period of time it tends to interrupt me.
Here is the output of inxi -Fxza --no-host
System: Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=b7150d35-3223-47db-8b79-9c021a5d9b10 rw quiet
udev.log_priority=3 acpi_backlight=vendor
Desktop: LXQt 0.15.1 tk: Qt 5.15.0 info: lxqt-panel wm: Openbox 3.6.1 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP Laptop 14-fq0xxx v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 87B7 v: 28.12 serial: <filter> UEFI: AMI v: F.01 date: 04/23/2020
Battery: ID-1: BAT0 charge: 30.3 Wh condition: 41.0/41.0 Wh (100%) volts: 12.0/11.6 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: Discharging cycles: 369
CPU: Topology: Dual Core model: AMD Athlon Silver 3050U with Radeon Graphics bits: 64 type: MCP arch: Zen+
family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109 L2 cache: 1024 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 9187
Speed: 1222 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz): 1: 1219 2: 1320
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:15d8
Device-2: Chicony type: USB driver: uvcvideo bus ID: 1-5.2:4 chip ID: 04f2:b62a serial: <filter>
Display: x11 server: X.org 1.20.8 compositor: compton driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa resolution: <xdpyinfo missing>
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: N/A alternate: snd_pci_acp3x bus ID: 03:00.5 chip ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.7.14-1-MANJARO
Network: Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8821ce v: N/A
modules: 8821ce port: f000 bus ID: 01:00.0 chip ID: 10ec:c821
Drives: Local Storage: total: 119.24 GiB used: 49.78 GiB (41.7%)
ID-1: /dev/sda model: SSSTC CV8-8E128-HP size: 119.24 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: V881 scheme: GPT
Partition: ID-1: / raw size: 79.32 GiB size: 77.57 GiB (97.80%) used: 49.72 GiB (64.1%) fs: ext4 dev: /dev/sda5
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda6
Sensors: System Temperatures: cpu: 40.9 C mobo: N/A gpu: amdgpu temp: 40 C
Info: Processes: 175 Uptime: 2h 04m Memory: 3.30 GiB used: 2.03 GiB (61.7%) Init: systemd v: 245 Compilers: gcc: 10.1.0
clang: 10.0.1 Packages: pacman: 1277 lib: 318 Shell: Zsh v: 5.8 running in: qterminal inxi: 3.1.05
Now today I had two issues. The first was at 12:10pm and the second was at 12:42pm. Here is the output of journalctl -b -1 -p err
for those times:
12:10pm
Aug 19 12:10:30 wpa_supplicant[577]: ioctl[SIOCGIWMODE]: No such device
Aug 19 12:10:30 wpa_supplicant[577]: ioctl[SIOCSIWAP]: No such device
Aug 19 12:10:30 wpa_supplicant[577]: ioctl[SIOCSIWESSID]: No such device
Aug 19 12:10:30 wpa_supplicant[577]: Could not read interface wlo1 flags: No such device
Aug 19 12:10:31 wpa_supplicant[577]: ioctl[SIOCSIWAP]: Operation not permitted
Aug 19 12:10:31 wpa_supplicant[577]: ioctl[SIOCSIWENCODEEXT]: Invalid argument
Aug 19 12:10:46 wpa_supplicant[577]: ioctl[SIOCSIWSCAN]: Operation not permitted
Aug 19 12:11:07 wpa_supplicant[577]: ioctl[SIOCGIWMODE]: No such device
Aug 19 12:11:07 wpa_supplicant[577]: ioctl[SIOCSIWAP]: No such device
Aug 19 12:11:07 wpa_supplicant[577]: ioctl[SIOCSIWESSID]: No such device
Aug 19 12:11:07 wpa_supplicant[577]: Could not read interface wlo1 flags: No such device
Aug 19 12:11:08 wpa_supplicant[577]: ioctl[SIOCSIWAP]: Operation not permitted
Aug 19 12:11:08 wpa_supplicant[577]: ioctl[SIOCSIWENCODEEXT]: Invalid argument
Aug 19 12:11:18 wpa_supplicant[577]: ioctl[SIOCSIWSCAN]: Operation not permitted
Aug 19 12:11:29 wpa_supplicant[577]: Failed to add supported operating classes IE
Aug 19 12:11:30 wpa_supplicant[577]: bgscan simple: Failed to enable signal strength monitoring
When this happened I ran a script I prepared based on suggestions I’d seen elsewhere:
#!/bin/zsh
modprobe -r 8821ce; modprobe 8821ce
The problem was quickly solved. I don’t know if the script helped or not.
12:42
Aug 19 12:42:49 kernel: rtl8821ce 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0009 address=0xdfc8e800 flags=0x0000]
Aug 19 12:42:49 kernel: rtl8821ce 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0009 address=0xdfc8e900 flags=0x0000]
Aug 19 12:42:49 kernel: rtl8821ce 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0009 address=0xdfc8e880 flags=0x0000]
Aug 19 12:42:49 kernel: rtl8821ce 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0009 address=0xdfc8e830 flags=0x0000]
Aug 19 12:44:06 wpa_supplicant[577]: ioctl[SIOCSIWPMKSA]: No such device
The last line was repeated many times. This time I tried my script again but it apparently didn’t work, and I ended up rebooting.
This all happened while I was on my university’s WiFi. I’m now back at my apartment and I’ve had no WiFi issues yet. I have had issues here in the past though. Finally, here is the entire output of journalctl -b -p err
-- Logs begin at Sun 2020-08-09 13:27:53 CDT, end at Wed 2020-08-19 15:18:11 CDT. --
Aug 19 12:45:54 kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
Aug 19 12:45:55 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Aug 19 12:45:56 kernel: kvm: disabled by bios
Aug 19 12:45:56 kernel: snd_pci_acp3x 0000:03:00.5: Invalid ACP audio mode : 1
Aug 19 12:46:05 lightdm[991]: gkr-pam: unable to locate daemon control file
Aug 19 12:46:24 wpa_supplicant[565]: bgscan simple: Failed to enable signal strength monitoring
Aug 19 12:46:25 ntpd[1718]: bind(21) AF_INET6 fe80::e797:c001:bafe:1c12%2#123 flags 0x11 failed: Cannot assign requested address
Aug 19 12:46:25 ntpd[1718]: unable to create socket on wlo1 (5) for fe80::e797:c001:bafe:1c12%2#123
Aug 19 14:30:22 wpa_supplicant[565]: bgscan simple: Failed to enable signal strength monitoring
Aug 19 14:30:22 ntpd[3576]: bind(21) AF_INET6 fe80::f24f:2cd9:3fea:bbe6%2#123 flags 0x11 failed: Cannot assign requested address
Aug 19 14:30:22 ntpd[3576]: unable to create socket on wlo1 (5) for fe80::f24f:2cd9:3fea:bbe6%2#123
