WiFi randomly disconnects and shows 'No Networks Available'
Both my bluetooth headphones and my wifi disconnected at the same time, trying to reconnect wifi shows there are no networks available,while reconnecting Bluetooth says connection failed.
Edit: The bluetooth issue was just my headphones connecting to another device.
It happened to me once and I thought if was a one off and restarted my system and it fixed till it just happened again. How do I fix it?
(I’m posting this after another restart)
inxi output:
  Kernel: 6.1.112-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=f48d994e-c928-4379-8442-a607bddaabd8 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IH_FA506IH
    v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: FA506IH v: 1.0 serial: <filter>
    uuid: a8b88a53-ee0a-8341-8b7e-bc8cd6176cb5 UEFI: American Megatrends
    v: FA506IH.316 date: 03/12/2021
  ID-1: BAT1 charge: 30.3 Wh (100.0%) condition: 30.3/48.1 Wh (63.0%)
    volts: 12.3 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: full
  System RAM: total: 16 GiB available: 15.05 GiB used: 3.89 GiB (25.9%)
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1K43DB1-CWE serial: <filter>
  Info: model: AMD Ryzen 5 4600H with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600104
    desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 3000 min/max: 1400/3000 boost: enabled
    base/boost: 3000/4000 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 3000 2: 3000 3: 3000 4: 3000
    5: 3000 6: 3000 7: 3000 8: 3000 9: 3000 10: 3000 11: 3000 12: 3000
    bogomips: 71894
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1f99 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 60.0 C
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 13d3:56a2
  Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: eDP-1 model: BOE Display 0x0c02 built: 2023 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm:
    drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 18.1.8 DRM 3.49 6.1.112-1-MANJARO) device-ID: 1002:1636
    memory: 500 MiB unified: no
  API: Vulkan v: 1.3.295 layers: 2 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1650 driver: nvidia v: 550.120 device-ID: 10de:1f99
    surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
    Graphics (RADV RENOIR) driver: mesa radv v: 24.2.4-arch1.0.1
    device-ID: 1002:1636 surfaces: xcb,xlib
  Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.112-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: n/a (root, process) with:
    1: pipewire-pulse status: active 2: pipewire-media-session status: active
    3: pipewire-alsa type: plugin 4: pw-jack type: plugin
    tools: pactl,pw-cat,pw-cli
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:c822
    class-ID: 0280
  Info: services: mld, NetworkManager, nfsd, nginx, sshd, systemd-timesyncd,
    wpa_supplicant
  Device-1: Lite-On Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 04ca:4005
  Local Storage: total: 942.7 GiB used: 453.67 GiB (48.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
    lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA001 temp: 42.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 1y 130d 18h cycles: 3,504
    read-units: 146,075,909 [74.7 TB] written-units: 73,771,954 [37.7 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
    family: Micron Client SSDs size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: M3CR043
    temp: 34 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 193d 16h cycles: 1016
    written: 5.46 TiB
  ID-1: / raw-size: 273.44 GiB size: 268.08 GiB (98.04%)
    used: 201.18 GiB (75.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
    maj-min: 259:5 label: N/A uuid: f48d994e-c928-4379-8442-a607bddaabd8
  ID-2: /run/media/hydra/ExternalWin raw-size: 97.66 GiB
    size: 97.65 GiB (100.00%) used: 26.5 MiB (0.0%) fs: exfat block-size: 512 B
    dev: /dev/sda2 maj-min: 8:2 label: ExternalWin uuid: 67FE-BC8E
  ID-3: /srv/mmedia raw-size: 368.1 GiB size: 361.26 GiB (98.14%)
    used: 252.34 GiB (69.8%) fs: ext4 block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: External-Linux
    uuid: 1bcf4134-86d3-4721-9900-4bd126368ed5
  ID-1: swap-1 type: partition size: 15.62 GiB used: 127.2 MiB (0.8%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: a609475d-b410-4232-b6c3-455a25e67113
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: E465-6F98
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 187.1 GiB fs: ntfs label: N/A
    uuid: 648069A180697B06
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 674 MiB fs: ntfs label: N/A
    uuid: B69804FD9804BE3D
  Device-1: 1-4:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Device-1: 2-2:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153
    3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 174c:55aa
    class-ID: 0806 serial: <filter>
  Device-1: 3-1:2 info: Lite-On Bluetooth Radio type: bluetooth driver: btusb
    interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 04ca:4005 class-ID: e001 serial: <filter>
  Device-2: 3-2:3 info: Holtek USB Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a0ac class-ID: 0300
  System Temperatures: cpu: 71.5 C mobo: N/A gpu: amdgpu temp: 60.0 C
  Fan Speeds (rpm): cpu: 4200
  Processes: 383 Power: uptime: 0m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 2717 pm: pacman pkgs: 2676 libs: 527 tools: octopi,pamac,yay
    pm: flatpak pkgs: 41 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo)
    v: 1.9.16 default: Bash v: 5.2.37 running-in: yakuake inxi: 3.3.36
This was the network and bluetooth section when a disconnect happened:
    speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s port: d000
    bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
    wpa_supplicant
  WAN IP: No WAN IP found. Connected to web? SSL issues?
Have you tried a newer kernel? There may be a bug in the rtw_8822ce driver in kernel 6.1 that was fixed in a newer version.
Which kernel should i try? and how do i do it?
I would recommend a more recent LTS version such as 6.6 first. If that doesn’t work, try a non-LTS kernel such as 6.10 or 6.11 (but avoid the realtime kernels as they are for special uses such as audio processing).
Launch the GUI from your application launcher: Manjaro Settings Manager => Kernel
Launch the GUI from a terminal: manjaro-settings-manager -m msm_kernel
Then reboot and your system should be running on the more recent kernel.
Thank you! I did try newer kernels but the same issue appears again.
My suspicion is that it is a BIOS issue since on going to windows(im dual booting), the network connection seems to replicate the situation in Manjaro. i.e if i rebooted into windows when there were no networks available on Manjaro, windows would say the same. Similarly if there were connections, it would connect on windows just fine as well.
This is the output of sudo dmesg | grep rtw :
[  267.457691]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  267.457711]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  267.457757]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  267.457769]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  267.457780]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  267.457793]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  267.457820]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  267.457917] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  267.460996] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  267.566767] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  267.569863] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  267.572964] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  267.576121] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  267.579219] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  267.579504] WARNING: CPU: 6 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  267.579516] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  267.579707] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  267.579721] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  267.579747]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  267.579759]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  267.579781]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  267.579787]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  267.579793]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  267.579806]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  267.579858] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  269.593969] WARNING: CPU: 8 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  269.593989] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  269.594180] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  269.594247] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  269.594280]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  269.594297]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  269.594325]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  269.594330]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  269.594336]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  269.594342]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  269.594356]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  269.594411] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  269.597493] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  269.703449] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  269.706557] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  269.709671] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  269.712810] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  269.715909] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  269.716169] WARNING: CPU: 8 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  269.716177] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  269.716337] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  269.716350] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  269.716377]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  269.716387]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  269.716409]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  269.716415]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  269.716421]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  269.716434]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  269.716478] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  271.510634] WARNING: CPU: 8 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  271.510653] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  271.510943] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  271.510995] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  271.511022]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  271.511036]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  271.511060]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  271.511065]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  271.511070]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  271.511076]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  271.511089]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  271.511138] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  271.514214] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  271.620107] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  271.623209] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  271.626319] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  271.629384] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  271.632541] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  271.635632] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  271.635907] WARNING: CPU: 8 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  271.635923] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  271.636250] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  271.636276] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  271.636331]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  271.636352]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  271.636397]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  271.636410]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  271.636423]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  271.636451]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  271.636547] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  273.430675] WARNING: CPU: 3 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  273.430696] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  273.431043] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  273.431070] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  273.431138]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  273.431168]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  273.431228]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  273.431243]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  273.431258]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  273.431274]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  273.431309]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  273.431436] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  273.434517] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  273.540390] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  273.543503] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  273.546618] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  273.549788] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  273.552893] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  273.553180] WARNING: CPU: 3 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  273.553200] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  273.553611] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  273.553643] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  273.553728]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  273.553756]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  273.553813]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  273.553830]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  273.553846]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  273.553881]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  273.554004] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  275.564025] WARNING: CPU: 3 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  275.564049] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  275.564401] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  275.564449] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  275.564508]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  275.564534]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  275.564585]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  275.564596]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  275.564608]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  275.564620]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  275.564649]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  275.564754] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  275.567825] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  275.673412] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  275.676525] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  275.679621] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  275.682750] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  275.685845] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  275.686122] WARNING: CPU: 3 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  275.686139] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  275.686465] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  275.686491] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  275.686547]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  275.686568]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  275.686614]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  275.686627]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  275.686639]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  275.686667]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  275.686763] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  277.483996] WARNING: CPU: 3 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  277.484018] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  277.484433] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  277.484490] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  277.484560]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  277.484584]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  277.484642]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  277.484657]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  277.484671]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  277.484687]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  277.484723]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  277.484844] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  277.487944] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  277.593748] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  277.596847] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  277.599956] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  277.703156] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  277.706257] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  277.706531] WARNING: CPU: 2 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  277.706547] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  277.706875] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  277.706901] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  277.706956]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  277.706977]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  277.707038]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  277.707051]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  277.707064]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  277.707092]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  277.707188] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  279.617393] WARNING: CPU: 2 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  279.617411] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  279.617738] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  279.617770] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  279.617827]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  279.617847]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  279.617892]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  279.617903]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  279.617915]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  279.617927]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  279.617956]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  279.618053] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  279.621122] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  279.726744] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  279.729859] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  279.732951] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  279.736021] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  279.739176] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  279.742270] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  279.742527] WARNING: CPU: 2 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  279.742536] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  279.742695] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  279.742708] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  279.742734]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  279.742745]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  279.742766]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  279.742772]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  279.742778]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  279.742790]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  279.742834] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  281.537269] WARNING: CPU: 2 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  281.537278] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  281.537435] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  281.537450] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  281.537475]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  281.537486]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  281.537508]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  281.537513]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  281.537518]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  281.537524]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  281.537536]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  281.537582] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  281.540653] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  281.650097] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  281.653210] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  281.656324] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  281.659473] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  281.662584] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  281.662863] WARNING: CPU: 4 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  281.662879] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  281.663204] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  281.663230] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  281.663286]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  281.663310]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  281.663357]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  281.663370]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  281.663383]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  281.663411]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  281.663510] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  283.457322] WARNING: CPU: 4 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  283.457339] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  283.457662] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  283.457688] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  283.457743]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  283.457763]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  283.457809]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  283.457821]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  283.457832]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  283.457845]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  283.457873]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  283.457970] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  283.461061] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  283.566777] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  283.569887] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  283.572997] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  283.576148] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  283.579252] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  283.579532] WARNING: CPU: 4 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  283.579549] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  283.579875] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  283.579901] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  283.579957]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  283.579978]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  283.580024]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  283.580037]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  283.580049]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  283.580077]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  283.580173] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  285.590646] WARNING: CPU: 0 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  285.590662] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  285.590988] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  285.591015] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  285.591070]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  285.591091]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  285.591136]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  285.591148]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  285.591160]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  285.591172]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  285.591200]  rtw_watch_dog_work+0x1d0/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  285.591297] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  285.594381] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  285.700087] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  285.703201] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  285.706297] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  285.709431] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  285.712532] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  285.712812] WARNING: CPU: 0 PID: 12 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  285.712829] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  285.713154] Workqueue: phy0 rtw_watch_dog_work [rtw_core]
[  285.713180] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  285.713235]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  285.713256]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  285.713303]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  285.713316]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  285.713328]  rtw_enter_lps+0x7b/0x100 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  285.713356]  rtw_watch_dog_work+0x297/0x2e0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  285.713453] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  286.950698] WARNING: CPU: 4 PID: 600 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  286.950726] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  286.951353] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  286.951429]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  286.951461]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  286.951525]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  286.951540]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  286.951555]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  286.951572]  rtw_leave_lps+0x78/0x1b0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  286.951612]  rtw_recalc_lps+0x7a/0xc0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  286.951646]  rtw_ops_bss_info_changed+0x1f5/0x2d0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  286.952553] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  286.955631] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  287.063423] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  287.248330] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  287.251416] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  289.338501] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  289.338783] WARNING: CPU: 3 PID: 600 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  289.338792] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  289.339030] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  289.339059]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.339072]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.339097]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.339102]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.339108]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.339114]  rtw_enter_ips+0x46/0x50 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  289.339131]  rtw_ops_config+0xa8/0xd0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  289.339634] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  289.440839] WARNING: CPU: 5 PID: 867 at /var/lib/dkms/rtw88/r514.c547846/build/pci.c:1279 rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  289.440855] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  289.441182] RIP: 0010:rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci]
[  289.441236]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.441257]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.441303]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.441315]  ? rtw_dbi_read8.constprop.0+0xa7/0xc0 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.441326]  rtw_pci_link_ps.part.0+0x89/0x100 [rtw_pci f1ffe1da6ad59ecb3618e4efb2da17830e8cdc0c]
[  289.441339]  rtw_leave_ips+0x2f/0xc0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  289.441368]  rtw_core_scan_start+0xac/0xd0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  289.441395]  rtw_hw_scan_start+0xe0/0x170 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  289.441424]  rtw_ops_hw_scan+0x51/0xb0 [rtw_core 0b3280200090080a4d46bbd5c6b5f591350e5bbd]
[  289.442488] rtw_8822ce 0000:03:00.0: failed to read ASPM, ret=-5
[  291.528445] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  291.528472] rtw_8822ce 0000:03:00.0: mac power on failed
[  291.528478] rtw_8822ce 0000:03:00.0: failed to power on mac
[  291.528482] rtw_8822ce 0000:03:00.0: leave idle state failed
[  291.531567] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  292.135629] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  292.138696] rtw_8822ce 0000:03:00.0: failed to send h2c command
[  292.138827] rtw_8822ce 0000:03:00.0: failed to leave ips state
[  292.138829] rtw_8822ce 0000:03:00.0: failed to leave idle state
[  307.124914] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  307.125363] Modules linked in: exfat rfcomm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rpcrdma rdma_cm iw_cm ib_cm ib_core ccm qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci edac_mce_amd snd_sof_xtensa_dsp snd_sof kvm_amd snd_sof_utils kvm snd_soc_core snd_compress irqbypass ac97_bus crct10dif_pclmul rtw_8822ce(OE) rtw_8822c(OE) snd_hda_intel snd_pcm_dmaengine crc32_pclmul rtw_pci(OE) snd_pci_ps snd_intel_dspcfg polyval_clmulni snd_rpl_pci_acp6x rtw_core(OE) snd_intel_sdw_acpi polyval_generic snd_acp_pci gf128mul nvidia_drm(POE) snd_acp_legacy_common ghash_clmulni_intel uvcvideo btusb mac80211 snd_hda_codec sha512_ssse3 nvidia_modeset(POE) snd_pci_acp6x btrtl videobuf2_vmalloc sha256_ssse3 uvc snd_pci_acp5x btintel sha1_ssse3 snd_hda_core videobuf2_memops asus_nb_wmi snd_rn_pci_acp3x btbcm aesni_intel
[  309.217928] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  309.217952] rtw_8822ce 0000:03:00.0: mac power on failed
[  309.217956] rtw_8822ce 0000:03:00.0: failed to power on mac
[  311.868481] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  311.868507] rtw_8822ce 0000:03:00.0: mac power on failed
[  311.868512] rtw_8822ce 0000:03:00.0: failed to power on mac
[  313.955584] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  313.955610] rtw_8822ce 0000:03:00.0: mac power on failed
[  313.955613] rtw_8822ce 0000:03:00.0: failed to power on mac
[  316.050393] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  316.050416] rtw_8822ce 0000:03:00.0: mac power on failed
[  316.050420] rtw_8822ce 0000:03:00.0: failed to power on mac
[  318.136993] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  318.137018] rtw_8822ce 0000:03:00.0: mac power on failed
[  318.137022] rtw_8822ce 0000:03:00.0: failed to power on mac
[  320.231264] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  320.231291] rtw_8822ce 0000:03:00.0: mac power on failed
[  320.231295] rtw_8822ce 0000:03:00.0: failed to power on mac
[  322.317257] rtw_8822ce 0000:03:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[  322.317280] rtw_8822ce 0000:03:00.0: mac power on failed
[  322.317283] rtw_8822ce 0000:03:00.0: failed to power on mac
If you are experiencing wifi disconnections, I recommend first these two workarounds:
1º Disable wifi power saving
2º Disable MAC randomization
I’ve just done these 2 and restarted. Will let you know if the issue remains.
Edit: 6hrs in, seems to be alright so far.
Edit again: Seems to have fixed it for now
I had a similar thing happen to me recently on my “Netflix” lappy. Everything would work with the wifi and then it would turn off.
I did a journalctl -f and discovered the system was trying to mount a partition in the second drive. I disabled that one for mounting on login.
I think the wifi was turning off bc it sensed a security breach.
