Hi there, after the latest update the wifi always fails to authenticate (it worked fine before that, and it works properly if I boot from the manjaro live distro). The card is up and running, I can see all routers around me, but the connection fails unless I disable authentication. If I keep the security of the network on, the system keeps me asking for the password and the icon in the top bar shows three dots inside the wifi symbol.
I’m working on an iMac, here is the output of inxi --admin --verbosity=8 -Fxxxz:
Kernel: 6.6.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=c104ab9f-2f28-409e-83d3-fa06b5d6dbc0 rw splash apparmor=1
Desktop: GNOME v: 46.3.1 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Apple product: iMac18,3 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-BE088AF8C5EB4FA2
Mobo: Apple model: Mac-BE088AF8C5EB4FA2 v: iMac18,3
serial: <superuser required> uuid: <superuser required> UEFI: Apple
v: 522.0.0.0.0 date: 08/17/2023
System RAM: total: 40 GiB available: 39.08 GiB used: 2.73 GiB (7.0%)
Array-1: capacity: 64 GiB note: est. slots: 4 modules: 4 EC: None
Device-1: DIMM0 type: DDR4 detail: synchronous size: 4 GiB
speed: 2400 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: 0x802C part-no: 0x344154463531323634485A2D3247334232202020
serial: <filter>
Device-2: DIMM1 type: DDR4 detail: synchronous size: 16 GiB
manufacturer: 0x859B part-no: 0x435431364734534644383234412E433136464444
serial: <filter>
Device-3: DIMM0 type: DDR4 detail: synchronous size: 4 GiB
serial: <filter>
Device-4: DIMM1 type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Info: model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF8
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 27208
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
disabled
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Apple driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 53.0 C
Device-2: Apple FaceTime HD Camera (Built-in) driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 05ac:8511
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Apple iMac serial: <filter> built: 2016
res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green:
x: 0.255 y: 0.698 blue: x: 0.149 y: 0.055 white: x: 0.310 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 3840x2160, 3200x1800, 2560x1440, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 470 Graphics
(radeonsi polaris10 LLVM 18.1.8 DRM 3.54 6.6.44-1-MANJARO)
device-ID: 1002:67df memory: 3.91 GiB unified: no display-ID: :0.0
Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.6.44-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: off tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
chip-ID: 14e4:1686 class-ID: 0200
IF: enp4s0f0 state: down mac: <filter>
Device-1: Apple Bluetooth USB Host Controller
driver: btusb,hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-6:4 chip-ID: 05ac:8296 class-ID: fe01
Local Storage: total: 1016.47 GiB used: 66.1 GiB (6.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD SM0032L
size: 26.08 GiB block-size: physical: 4096 B logical: 4096 B
speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter> fw-rev: DXZ77A0Q
temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Apple model: HDD ST1000DM003
tech: HDD rpm: 7200 serial: <filter> fw-rev: AQ04 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 model: USB Flash size: 58.88 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 25.75 GiB size: 25.18 GiB (97.77%) used: 14.74 GiB (58.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: c104ab9f-2f28-409e-83d3-fa06b5d6dbc0
ID-2: /boot/efi raw-size: 300 MiB size: 299.3 MiB (99.76%)
used: 3.3 MiB (1.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: C7D3-7D7E
ID-3: /mnt/bigdisk raw-size: 730.3 GiB size: 717.78 GiB (98.28%)
used: 40.04 GiB (5.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: data
uuid: 2b1a0cbb-018c-4423-84f1-be1b1a0e0d24
ID-4: /usr raw-size: 201.21 GiB size: 196.99 GiB (97.90%)
used: 11.32 GiB (5.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: sysusr
uuid: b703ee0f-6b1a-4a11-b2c5-2c84c04d5740
ID-1: /dev/sdb1 maj-min: 8:17 size: 3.33 GiB fs: iso9660
ID-2: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 76DC-D123
Device-1: 1-3:2 info: Logitech M90/M100 Optical Mouse type: mouse
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 046d:c05a class-ID: 0301
Device-2: 1-5:3 info: Apple FaceTime HD Camera (Built-in) type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 05ac:8511 class-ID: 0e02
serial: <filter>
Device-3: 1-6:4 info: Apple Bluetooth USB Host Controller
type: keyboard,mouse,bluetooth driver: btusb,hid-generic,usbhid
interfaces: 6 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
Device-4: 1-10:5 info: SONiX AMAZON MD005 Wired Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 413d:2114 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
Device-1: 4-2:2 info: Silicon Motion - Taiwan (formerly Feiya ) Flash
Drive type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 504mA
chip-ID: 090c:1000 class-ID: 0806
System Temperatures: cpu: 55.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1557 libs: 459 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
2: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
3: https://mirror.zetup.net/manjaro/stable/$repo/$arch
4: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://muug.ca/mirror/manjaro/stable/$repo/$arch
7: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
8: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 251
1: cpu: 10.9% command: firefox pid: 2043 mem: 675.8 MiB (1.6%)
2: cpu: 5.8% command: firefox pid: 2329 mem: 255.9 MiB (0.6%)
3: cpu: 4.1% command: gnome-shell pid: 1372 mem: 318.9 MiB (0.7%)
4: cpu: 2.9% command: firefox pid: 4272 mem: 182.5 MiB (0.4%)
5: cpu: 0.7% command: firefox pid: 4133 mem: 164.7 MiB (0.4%)
Memory top: 5 of 251
1: mem: 675.8 MiB (1.6%) command: firefox pid: 2043 cpu: 10.9%
2: mem: 318.9 MiB (0.7%) command: gnome-shell pid: 1372 cpu: 4.1%
3: mem: 255.9 MiB (0.6%) command: firefox pid: 2329 cpu: 5.8%
4: mem: 197.7 MiB (0.4%) command: firefox pid: 2424 cpu: 0.3%
5: mem: 182.5 MiB (0.4%) command: firefox pid: 4272 cpu: 2.9%
Processes: 251 Power: uptime: 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 15.61 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.35
and here there are a few lines from journalctl | wifi:
device (wlp3s0): Activation: (wifi) connection 'bbnet2' has security, and secrets exist. No new secrets needed.
ago 17 11:50:08 esposito-imac183 NetworkManager[621]: <warn> [1723888208.1662] device (wlp3s0): Activation: (wifi) association took too long
ago 17 11:50:08 esposito-imac183 NetworkManager[621]: <warn> [1723888208.1666] device (wlp3s0): Activation: (wifi) asking for new secrets
ago 17 11:50:08 esposito-imac183 NetworkManager[621]: <info> [1723888208.1677] device (wlp3s0): Activation: (wifi) connection 'bbnet2' has security, and secrets exist. No new secrets needed.
ago 17 15:16:36 esposito-imac183 NetworkManager[605]: <info> [1723900596.0256] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-wifi.so)
ago 17 15:16:41 esposito-imac183 NetworkManager[605]: <info> [1723900601.1657] device (wlp3s0): Activation: (wifi) access point 'bbnet2' has security, but secrets are required.
Any idea about how to solve the problem? Thanks in advance!
