Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0 Desktop: GNOME v: 41.5
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <superuser required>
UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
ID-1: BAT0 charge: 14.8 Wh (31.1%) condition: 47.6/60.0 Wh (79.3%) volts: 15.6 min: 15.4
model: Celxpert L19C4PC0 status: charging
Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1481 high: 2465 min/max: 1400/2900 boost: enabled cores: 1: 1397 2: 1397
3: 1396 4: 1559 5: 1404 6: 1397 7: 1396 8: 1487 9: 1395 10: 1397 11: 1397 12: 1397 13: 1397
14: 1397 15: 1428 16: 2465 bogomips: 92668
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia v: 470.103.01
bus-ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1 driver: X:
loaded: amdgpu,nvidia gpu: amdgpu resolution: 1920x1080~120Hz
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 283.21 GiB (59.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB temp: 44.9 C
ID-1: / size: 459.79 GiB used: 283.21 GiB (61.6%) fs: ext4 dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 53.0 C
Processes: 383 Uptime: 1h 33m Memory: 15.07 GiB used: 4.73 GiB (31.4%) Init: systemd Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1526 Client: gnome-shell v: 41.5 inxi: 3.3.15
When I try to connect to a new WiFi connection the password prompt appears and disappears instantly so I can’t enter the password. I had to use a terminal to connect.
