inxi -zv8
Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=8903b866-1773-4ef1-b00d-accf8066eedc rw rootflags=subvol=@
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: Cinnamon v: 6.4.12 tk: GTK v: 3.24.50 wm: Muffin v: 6.4.1 tools:
avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Apple product: Macmini5,1 v: 1.0
serial: <superuser required> Chassis: type: 16 v: Mac-8ED6AF5B48C039E1
Mobo: Apple model: Mac-8ED6AF5B48C039E1 v: Macmini5,1
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: Apple v: 135.0.0.0.0 date: 06/13/2019
System RAM: total: 16 GiB available: 15.53 GiB used: 2.44 GiB (15.7%)
Array-1: capacity: 16 GiB note: est. slots: 2 modules: 2 EC: None
Device-1: DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1333 MT/s volts: N/A width: N/A manufacturer: 0x80CE
part-no: 0x202020202020202020202020202020202020 serial: <filter>
Device-2: DIMM0 type: DDR3 detail: synchronous size: 8 GiB
Info: model: Intel Core i5-2415M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2900 min/max: 800/2900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2900 2: 2900 3: 2900 4: 2900 bogomips: 18367
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Apple driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: DP-1 empty: DP-2, DP-3,
HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0126
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
Monitor-1: DP-1 model: NEC LCD2490WUXi2 serial: <filter> built: 2009 res:
mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2 chroma: red:
x: 0.643 y: 0.333 green: x: 0.302 y: 0.616 blue: x: 0.145 y: 0.071 white:
x: 0.314 y: 0.329 size: 480x300mm (18.9x11.81") diag: 611mm (24")
ratio: 16:10, 15:9 modes: 1920x1200, 1600x1200, 1680x1050, 1400x1050,
1280x1024, 1440x900, 1360x768, 1152x864, 1280x720, 1024x768, 832x624,
800x600, 640x480, 720x400
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
drv: crocus inactive: wayland
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) device-ID: 8086:0126 memory: 1.46 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
class-ID: 0403
API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp2s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n driver: bcma-pci-bridge v: N/A
modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 14e4:4331 class-ID: 0280
IF-ID-1: wlp3s0b1 state: up mac: <filter>
Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.1.3:6
chip-ID: 05ac:8281 class-ID: fe01
Local Storage: total: 232.89 GiB used: 8.26 GiB (3.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
used: 8.26 GiB (3.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 8903b866-1773-4ef1-b00d-accf8066eedc
used: 624 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1AD3-79CF
ID-3: /home raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
ID-4: /var/cache raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
ID-5: /var/log raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-3: 2-1:2 info: Microchip (formerly SMSC) 2.0 Hub ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 0424:2513 class-ID: 0900
Hub-4: 2-1.1:3 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 2-1.1.3:6 info: Apple Bluetooth Host Controller type: bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 05ac:8281 class-ID: fe01
Hub-5: 3-0:1 info: full speed or root hub ports: 8 rev: 2.0
Hub-6: 3-1:2 info: Microchip (formerly SMSC) 2.0 Hub ports: 3 rev: 2.0
Device-1: 3-1.1:3 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 05ac:8242 class-ID: 0300
Hub-7: 3-1.3:4 info: Apple Hub in Aluminum Keyboard ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 300mA
chip-ID: 05ac:1006 class-ID: 0900
Device-1: 3-1.3.1:5 info: Logitech M185 compact wireless mouse type: mouse
lanes: 1 mode: 1.1 power: 50mA chip-ID: 046d:c542 class-ID: 0301
Device-2: 3-1.3.2:6 info: Apple Aluminium Keyboard (ISO)
type: keyboard,HID driver: apple,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 20mA
chip-ID: 05ac:0250 class-ID: 0300
Hub-8: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
System Temperatures: cpu: 59.0 C mobo: 50.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1167 libs: 340 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.koddos.net/manjaro/stable/$repo/$arch
2: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
Processes:
CPU top: 5 of 239
1: cpu: 9.3% command: firefox pid: 1529 mem: 573.5 MiB (3.6%)
2: cpu: 8.2% command: firefox pid: 1753 mem: 324.7 MiB (2.0%)
3: cpu: 3.3% command: cinnamon pid: 1057 mem: 176.1 MiB (1.1%)
4: cpu: 2.8% command: gnome-terminal-server pid: 2374 mem: 50.1 MiB (0.3%)
5: cpu: 2.2% command: Xorg pid: 699 mem: 116.8 MiB (0.7%)
Memory top: 5 of 239
1: mem: 573.5 MiB (3.6%) command: firefox pid: 1529 cpu: 9.3%
2: mem: 465.1 MiB (2.9%) command: manjaro-hello started-by: python3
pid: 1140 cpu: 0.2%
3: mem: 324.7 MiB (2.0%) command: firefox pid: 1753 cpu: 8.2%
4: mem: 305.9 MiB (1.9%) command: soffice.bin pid: 1484 cpu: 0.8%
5: mem: 176.1 MiB (1.1%) command: cinnamon pid: 1057 cpu: 3.3%
Processes: 239 Power: uptime: 30m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: csd-power,upowerd
Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.3 running-in: gnome-terminal
inxi: 3.3.40
This all the info with inxi -zv8 command.
Quite a lot of info. And not sure where to look for unfortunately.
