Wifi not working with adapter
Hello there, I understand that this is probably quite a widespread problem as i spent quite a bit looking around this forum for a fix but i came to the conclusion that it probably isn’t something that can be fixed from another persons problem, as computers are different. Currently wired through my phone with usb tethering and will post my inxi -Fazy results so that maybe someone can help me.
Here is the aforementioned inxi -Fazy, i disconnected from my phone and turned on wifi to get the results of the actual wifi connection. Thanks in advance to anyone willing to help. :smiley:
  Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=f540c5aa-d669-44bd-9633-417d2bf4c4a6 rw quiet splash apparmor=1
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASRock model: B450 Gaming K4 serial: <superuser required>
    uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: P1.80
    date: 12/18/2018
  Info: model: AMD Ryzen 5 1600X bits: 64 type: MT MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001137
    smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 1879 min/max: 2200/3600 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1879 2: 1879 3: 1879
    4: 1879 5: 1879 6: 1879 7: 1879 8: 1879 9: 1879 10: 1879 11: 1879 12: 1879
    bogomips: 86267
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nvidia
    v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
    (as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: none off: HDMI-A-1,HDMI-A-2
    empty: DP-1,DVI-D-1,HDMI-A-3 bus-ID: 26:00.0 chip-ID: 10de:1c82
    class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch note: X driver n/a, try sudo/root
    display-ID: :1 note: <missing: xdpyinfo/xrandr>
  Monitor-1: HDMI-A-1 size-res: N/A modes: N/A
  Monitor-2: HDMI-A-2 size-res: N/A modes: N/A
  Monitor-3: Unknown-1 size-res: N/A modes: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: gbm,wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
    memory: 3.91 GiB
  Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
    bus-ID: 26:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock
    bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
  API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp37s0 state: down mac: <filter>
  Device-2: TP-Link 802.11n NIC driver: rtl8xxxu type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 2357:0126
    class-ID: 0000 serial: <filter>
  IF: wlp39s0f3u3 state: down mac: <filter>
  IF-ID-1: enp3s0f0u9 state: unknown speed: -1 duplex: half mac: <filter>
  Local Storage: total: 2.05 TiB used: 9.94 GiB (0.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXE7 temp: 35.9 C
    scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A02 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: MBR
  ID-1: / raw-size: 51.51 GiB size: 50.4 GiB (97.85%) used: 9.94 GiB (19.7%)
    fs: ext4 dev: /dev/sdb2 maj-min: 8:18
  System Temperatures: cpu: 42.2 C mobo: N/A gpu: nvidia temp: 45 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Memory: total: 16 GiB available: 15.55 GiB used: 2.27 GiB (14.6%)
  Processes: 329 Power: uptime: 16m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1130 libs: 312 tools: gnome-software,pamac
    pm: flatpak pkgs: 0 Compilers: N/A Shell: Bash v: 5.2.37
    running-in: gnome-terminal inxi: 3.3.36
It looks like you have a driver installed:
Are you dual-booting Windows? If so, make certain that Windows is completely shutdown and that Hibernation, hybrid sleep and fast startup are completely disabled.
Have you tried a different kernel e.g. 6.6LTS or 6.1LTS?
Is it blocked somehow? What does the following command show?
rfkill list
A solution I have seen involves blacklisting the kernel driver and installing rtl8192eu driver which is available from the AUR. This particular driver requires that dkms be installed on your system. I would also recommend the appropriate linux headers for the kernel that you are running.
If it doesn’t workout, you can always reverse the kernel driver blacklist.
echo "blacklist rtl8xxxu" | sudo tee /etc/modprobe.d/rtl8xxxu.conf
Easiest method is in pamac GUI. Ensure that AUR is enabled in pamac.
To build packages from AUR, make certain that the base-devel package is installed.
Via terminal:
pamac install base-devel
pamac install dkms
pamac install linux612-headers
reboot after installation of dkms and the kernel headers. Then:
In terminal or via Pamac GUI:
pamac build rtl8192eu
https://aur.archlinux.org/packages/rtl8192eu
There was a problem a till a day or two ago with recent ISO’s missing some firmware.
I don’t know whether this WiFi adapter would need it.
Perhaps try using a freshly downloaded ISO.
I downloaded my ISO like 10-12 hours ago, i don’t know if you mean recent recent, like some minutes ago. :stuck_out_tongue:
I’ll try what you mention, but just to answer a few right now.5
No so I don’t think it matters, but tell me if i am wrong there. I am running Manjaro on one of my SSD’s, I have 2 SSD (a 250gb which has my windows, and a 1tb that has a partition which is running Manjaro) and 1tb HDD.
Not yet, didn’t think of it as a solution to the adapter not working.
It shows this: (Currently on ethernet through phone tethering.)
1: phy1: Wireless LAN
Soft blocked: yes
Hard blocked: no
That’s all from me now, i’ll go ahead and try everything else.
I don’t know about the two SSD situation. I would run the following:
rfkill unblock all
the name of the file should end in
… 24.2.0-241209-linux612.iso - the one from the day before
… 24.2.0-241208- … .iso
was missing firmware
