Earlier I was using manjaro on kernel 5.3 which was a stable one.every thing was working fine on that.But I had to reinstall manjaro on another partition so, i reinstalled it and found that kernel 5.3 has been pulledout. Now I am on kernel 5.4 and wifi and display brightness are not working.
I have already deleted windows and stuck on this with no wifi
Please help
Here are system configs:
System: Host: jai-notebook Kernel: 5.4.60-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=fa44c4db-b4ac-4b2f-a3ee-739ee3683e24 rw quiet udev.log_priority=3 Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux Machine: Type: Laptop System: HP product: HP Laptop 15q-dy0xxx v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter> Mobo: HP model: 84AE v: 86.20 serial: <filter> UEFI: Insyde v: F.10 date: 05/31/2018 Battery: ID-1: BAT1 charge: 13.4 Wh condition: 27.2/41.0 Wh (66%) volts: 12.9/11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter> status: Charging CPU: Topology: Dual Core model: AMD Ryzen 3 2200U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17) stepping: N/A microcode: 8101007 L2 cache: 1024 KiB flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 19970 Speed: 1368 MHz min/max: 1600/2500 MHz boost: enabled Core speeds (MHz): 1: 1370 2: 1565 3: 1384 4: 1595 Vulnerabilities: Type: itlb_multihit status: Not affected Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 04:00.0 chip ID: 1002:15dd Display: x11 server: X.Org 1.20.8 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa tty: N/A OpenGL: renderer: AMD RAVEN (DRM 3.35.0 5.4.60-2-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.0.7 direct render: Yes Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:15de Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard driver: N/A bus ID: 04:00.5 chip ID: 1022:15e2 Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3 Sound Server: ALSA v: k5.4.60-2-MANJARO Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 02:00.0 chip ID: 10ec:8168 IF: eno1 state: down mac: <filter> Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard driver: N/A port: 2000 bus ID: 03:00.0 chip ID: 10ec:d723 IF-ID-1: enp4s0f3u3 state: unknown speed: N/A duplex: N/A mac: <filter> Drives: Local Storage: total: 931.51 GiB used: 5.25 GiB (0.6%) ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: RSM7 scheme: GPT Partition: ID-1: / raw size: 65.67 GiB size: 64.14 GiB (97.67%) used: 5.19 GiB (8.1%) fs: ext4 dev: /dev/sda8 Sensors: System Temperatures: cpu: 52.2 C mobo: N/A gpu: amdgpu temp: 20 C Fan Speeds (RPM): N/A Info: Processes: 194 Uptime: 16m Memory: 3.57 GiB used: 980.4 MiB (26.8%) Init: systemd v: 245 Compilers: gcc: N/A Shell: bash v: 5.0.17 running in: xfce4-terminal inxi: 3.0.37
