Wifi was working fine 1 week age. Suddenly It doesn’t connect to my home router and Now it won’t even show any wifi network.
inxi --full --verbosity=7 --filter --no-host
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
Type: Portable System: Dell product: Inspiron N4010 v: A13
serial:
Mobo: Dell model: N/A v: A13 serial: BIOS: Dell v: A13
date: 03/31/2011
ID-1: BAT0 charge: 2.6 Wh (100.0%) condition: 2.6/4.4 Wh (59.7%)
volts: 11.6 min: 11.1 model: SIMPLO Dell type: Li-ion serial:
status: Charging
RAM: total: 3.64 GiB used: 2.77 GiB (76.0%)
RAM Report:
Info: Dual Core model: Intel Core i5 M 480 bits: 64 type: MT MCP
arch: Nehalem rev: 5 cache: L2: 3 MiB bogomips: 21286
Speed: 1463 MHz min/max: 1199/2667 MHz boost: enabled Core speeds (MHz):
1: 1463 2: 1463 3: 1463 4: 1462
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx
monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pdcm pebs pge pni
popcnt pse pse36 pti rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Device-1: Intel Core Processor Integrated Graphics vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: Microdia Sonix 1.3 MP Laptop Integrated Webcam type: USB
driver: uvcvideo bus-ID: 1-1.4:4 chip-ID: 0c45:6480 class-ID: 0e02
Display: x11 server: X. Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa s-res: 1366x768 s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 21.1.2
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Device-1: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
v: kernel port: 1860 bus-ID: 03:00.0 chip-ID: 8086:0083 class-ID: 0280
IF: wlp3s0 state: down mac:
Device-2: Qualcomm Atheros AR8152 v1.1 Fast Ethernet vendor: Dell
driver: atl1c v: kernel port: 2000 bus-ID: 04:00.0 chip-ID: 1969:2060
class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 465.76 GiB used: 210.87 GiB (45.3%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
size: 465.76 GiB speed: 3.0 Gb/s rotation: 5400 rpm serial:
rev: AF10 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD±RW GT32N rev: A201
dev-links: cdrom
ID-1: / size: 80.51 GiB used: 24.83 GiB (30.8%) fs: ext4 dev: /dev/sda2
label: N/A uuid: d799f943-70fb-49a9-a0be-27d11f0eb16e
ID-2: /mnt/mustafizur size: 376.39 GiB used: 186.03 GiB (49.4%) fs: ext4
dev: /dev/sda1 label: mustafizur
uuid: 4cb3444a-d036-4072-8e5a-60bbe7f70b77
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Hub-3: 1-1.1:3
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 1-1.1.1:5 info: Dell Integrated Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 2mA chip-ID: 413c:8161 class-ID: 0301
Device-2: 1-1.1.2:7 info: Dell Integrated Touchpad [Synaptics] type: Mouse
power: 2mA chip-ID: 413c:8162 class-ID: 0301
Device-3: 1-1.4:4 info: Microdia Sonix 1.3 MP Laptop Integrated Webcam
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 0c45:6480 class-ID: 0e02
Device-4: 1-1.5:6 info: Realtek RTS5138 Card Reader Controller
type: Mass Storage driver: ums-realtek interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0bda:0138 class-ID: 0806
serial:
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:5 info: China Resource Semico Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1a2c:2124 class-ID: 0300
Device-2: 2-1.3:4 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
System Temperatures: cpu: 49.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Processes: 219 Uptime: 1h 45m wakeups: 1 Init: systemd v: 248 Compilers:
gcc: 11.1.0 Packages: pacman: 1101 Shell: Zsh v: 5.8
running-in: xfce4-terminal inxi: 3.3.04
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp4s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether **********Preformatted text
brd ff:ff:ff:ff:ff:ff
3: wlp3s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DORMANT group default qlen 1000
link/ether ******** brd ff:ff:ff:ff:ff:ff permaddr *********
I have already tried
sudo systemctl restart NetworkManager
sudo ip link set dev wlp3s0 up
RTNETLINK answers: Operation not permitted
But none worked.
i have checked if wifi works on Live Boot but it doesn’t work there either.
