I recently updated to kernel 6.14.6-2-MANJARO
and updated a few more packages after (nvidia-linux-meta, firefox, etc.). After a system restart my wifi is no longer working.
I have tried different kernels (6.12.xx, 6.6.xx) and restored from a timeshift one week ago, but neither worked. I am not sure where to look, and any help would be greatly appreciated.
$ inxi -Fazy
Kernel: 6.14.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
root=UUID=2dc1aead-efcd-4b0a-9cab-d13b0c8c0d48 rw quiet
resume=UUID=55a4bfc8-2bef-4478-be36-a0e9946e9f1d udev.log_priority=3
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506HEB_FX566HEB
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FX506HEB v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FX506HEB.310
date: 11/25/2021
ID-1: BAT1 charge: 72.3 Wh (84.5%) condition: 85.6/90.2 Wh (94.8%)
volts: 16.2 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x56
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB
desc: 6x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1117 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 1117 2: 1117 3: 1117 4: 1117 5: 1117 6: 1117
7: 1117 8: 1117 9: 1117 10: 1117 11: 1117 12: 1117 bogomips: 64512
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a68
class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 ports: active: none off: DP-2
empty: DP-1 bus-ID: 0000:01:00.0 chip-ID: 10de:25a0 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 322e:202c
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: DP-2 mapped: DP-1-0.2 note: disabled pos: right model: LG
(GoldStar) IPS FULLHD built: 2014 res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.63")
diag: 551mm (21.7") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: primary,left model: Najing CEC Panda 0x004d
built: 2019 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau drv: nvidia
platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2 drv: iris
device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11:
drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
device-ID: 8086:9a68 memory: 7.5 GiB unified: yes
API: Vulkan v: 1.4.313 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3050 Ti Laptop GPU driver: nvidia v: 570.144
device-ID: 10de:25a0 surfaces: N/A
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA107 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:2291
class-ID: 0403
Device-3: Logitech G435 Wireless Gaming Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-4.3:6 chip-ID: 046d:0acb class-ID: 0300
serial: <filter>
API: ALSA v: k6.14.6-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
Device-1: Realtek vendor: ASUSTeK driver: r8169 v: kernel port: 3000
bus-ID: 0000:02:00.0 chip-ID: 10ec:8162 class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-4.1:3
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20f0u4u1 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:5 chip-ID: 8087:0032
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c010c
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 290.06 GiB (20.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 44.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 59.9 C
scheme: GPT
ID-1: / raw-size: 195.79 GiB size: 192.16 GiB (98.14%) used: 55.3 GiB (28.8%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:4
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 720.58 GiB size: 708.2 GiB (98.28%)
used: 156.03 GiB (22.0%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:6
ID-1: swap-1 type: partition size: 14.65 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:5
System Temperatures: cpu: 56.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.36 GiB used: 4.02 GiB (26.2%)
Processes: 276 Power: uptime: 11m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.11 GiB services: org_kde_powerdevil,upowerd
Packages: 1801 pm: pacman pkgs: 1784 libs: 434 tools: pamac pm: flatpak
pkgs: 17 Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.38
