Wifi not working after update, i915, kernel 6.12, network
Manjaro XFCE 25.0.0, kernel 6.12.19
Home network
Hi,
today I installed the new stable update for XFCE
Now, I’m loosing wifi since then.
Before until kernel 6.11, I sometimes had to I disconnect the network then reconnect, because one of the core was in high demand after a suspend mode, seems an issue with i915 boards, but now, I suspect the culprit is kernel 6.12, after a few minutes I loose the connection, I try to disable the network then reconnect, but thought it says connected a ping to google.com show that is not.
I’ll try to boot with kernel 6.6,but now I do see the menu to select which kernel to boot from.
Thanks for helping
Hi @artofit,
You can find everything on the Wiki:
Thanks, but the issue was to have a internet connection at all, so my priority was to install kernel 6.6
Secondly, at boot just press ESC to make GRUB menu appear and select kernel 6.6
Since I revert to 6.6, wifi is stable.
Googling with “kernel 6.12 wifi disconnect” found other people having issues with 6.12
I stay away from 6.12 for a while
Or, you could provide system information that might help others discover the actual cause or inconsistency.
Many users (myself included) are using kernel 6.12 without any indication of the problem(s) you’re presenting.
I suspect your issue might lay elsewhere, but we can’t know without maximum input from you, and many eyes to investigate the possibilities.
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
With i915 board, after a suspend mode, one core is running at 100%, this almost invariably happens after suspend mode since ages, I think kernel 5.15. By disconnecting to the network and reconnecting, then CPU runs “normally”.
In this very instance, it’s core1 which runs full speed, often is core2.
I output the console output of the request cmd before disconnecting and just after.
$ inxi --filter --verbosity=8
  Kernel: 6.6.84-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=edf45810-6d78-45d4-a5d0-bd1186fae9c2 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: TOSHIBA product: SATELLITE C855-112 v: PSKC8E-00J00QBT
    serial: <superuser required>
  Mobo: Type2 - Board Vendor Name1 model: Type2 - Board Product Name1
    v: Type2 - Board Version serial: <superuser required>
    part-nu: PSKC8E-00J00QBT uuid: <superuser required> UEFI-[Legacy]: Insyde
    v: 6.80 date: 10/01/2013
  System RAM: total: 8 GiB available: 7.65 GiB used: 4.52 GiB (59.0%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471B5273DH0-CH9 serial: <filter>
  Device-2: DIMM1 type: DDR3 detail: synchronous size: 4 GiB
    manufacturer: Samsung part-no: M471B5273BH1-CH9 serial: <filter>
  Info: model: Intel Core i5-2450M bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2624 min/max: 800/3100 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2624 2: 2624 3: 2624 4: 2624 bogomips: 19960
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
    md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
    sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Toshiba driver: i915 v: kernel arch: Gen-6 code: Sandybridge
    process: Intel 32nm built: 2011 ports: active: HDMI-A-1 off: LVDS-1
    empty: DP-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
  Device-2: Chicony TOSHIBA Web Camera - HD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:4
    chip-ID: 04f2:b307 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.16 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: HDMI-A-1 model: Idek Iiyama PL2875UH serial: <filter>
    built: 2018 res: 3840x2160 dpi: 157 gamma: 1.2 chroma: red: x: 0.635
    y: 0.341 green: x: 0.310 y: 0.635 blue: x: 0.157 y: 0.059 white: x: 0.314
    y: 0.329 size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 93 2: parse_edid:
    unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 96 5: parse_edid: unhandled CEA mode 97
  Monitor-2: LVDS-1 model: LG Display 0x02dc built: 2010 res: 1366x768
    dpi: 101 gamma: 1.2 chroma: red: x: 0.624 y: 0.369 green: x: 0.345 y: 0.612
    blue: x: 0.149 y: 0.098 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 25.0.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB
    GT2) device-ID: 8086:0126 memory: 1.46 GiB unified: yes
  Info: Tools: api: eglinfo,glxinfo
    de: kscreen-doctor,xfce4-display-settings x11: xprop
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Toshiba
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  API: ALSA v: k6.6.84-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
    chip-ID: 10ec:8176 class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Toshiba
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
  Local Storage: total: 465.76 GiB used: 385.01 GiB (82.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD050
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 2M scheme: MBR
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SN-208AB rev: TO03
    dev-links: cdrom
  ID-1: / raw-size: 62.02 GiB size: 60.74 GiB (97.94%) used: 55 GiB (90.5%)
    fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: x245
    uuid: edf45810-6d78-45d4-a5d0-bd1186fae9c2
  ID-2: /run/media/x245/DOCS raw-size: 64 GiB size: 64 GiB (100.00%)
    used: 54.21 GiB (84.7%) fs: ntfs dev: /dev/sda5 maj-min: 8:5 label: DOCS
    uuid: ECDCA490DCA4571C
  ID-3: /run/media/x245/MMedia raw-size: 279.87 GiB
    size: 279.87 GiB (100.00%) used: 275.8 GiB (98.5%) fs: ntfs dev: /dev/sda6
    maj-min: 8:6 label: MMedia uuid: 7A2EAC312EABE47B
  ID-1: /dev/sda3 maj-min: 8:3 size: 1 KiB fs: <superuser required> label: N/A
    uuid: N/A
  ID-2: /dev/sda4 maj-min: 8:4 size: 16.16 GiB fs: ntfs label: archive
    uuid: 11B387743FFE5038
  ID-3: /dev/sda7 maj-min: 8:7 size: 16.36 GiB fs: ntfs label: OS_WORK
    uuid: 6822685722682BEE
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.1:3 info: Realtek RTS5138 Card Reader Controller
    type: mass storage driver: ums-realtek interfaces: 1 rev: 2.0
    chip-ID: 0bda:0138 class-ID: 0806 serial: <filter>
  Device-2: 1-1.3:4 info: Chicony TOSHIBA Web Camera - HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b307 class-ID: 0e02
    serial: <filter>
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: HP HP USB Keyboard type: keyboard,HID
    chip-ID: 03f0:064a class-ID: 0300
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 76.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1664 libs: 396 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    2: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    4: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    5: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    6: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    8: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    9: https://linorg.usp.br/manjaro/stable/$repo/$arch
    10: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    11: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    12: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    13: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    14: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    15: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    18: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    22: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    23: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    24: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    25: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    26: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    27: http://manjaro.grena.ge/stable/$repo/$arch
    28: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    29: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    31: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    32: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    33: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    34: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    35: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    36: https://mirrors2.manjaro.org/stable/$repo/$arch
    37: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    38: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    39: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    40: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    41: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    42: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    43: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    44: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    45: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    46: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    47: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    48: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    49: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    50: http://manjaro.mirror.ac.za/stable/$repo/$arch
    51: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    52: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    53: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    54: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    55: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    56: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    57: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    58: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    59: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    60: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    61: https://manjaro.ynh.ovh/stable/$repo/$arch
    62: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    63: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    64: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    65: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    66: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    67: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    68: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    69: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    70: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    71: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    72: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    73: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    74: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    75: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    76: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    77: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    78: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    79: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    80: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    81: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    82: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    83: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    84: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    85: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    86: https://manjaro.kurdy.org/stable/$repo/$arch
    87: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    88: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    89: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    90: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    91: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    92: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    93: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    94: https://mirror.init7.net/manjaro/stable/$repo/$arch
    95: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    96: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    97: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    98: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    99: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    100: https://mirror.23m.com/manjaro/stable/$repo/$arch
    101: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    102: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    103: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    104: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    105: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    106: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    107: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    108: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 234
  1: cpu: 400% command: ps pid: 31997 mem: 3.75 MiB (0.0%)
  2: cpu: 22.8% command: chromium pid: 31917 mem: 252.1 MiB (3.2%)
  3: cpu: 6.1% command: xfce4-terminal pid: 31975 mem: 52.0 MiB (0.6%)
  4: cpu: 4.3% command: Xorg pid: 778 mem: 138.5 MiB (1.7%)
  5: cpu: 4.1% command: xfce4-mime-helper pid: 31969 mem: 30.7 MiB (0.3%)
  Memory top: 5 of 234
  1: mem: 412.7 MiB (5.2%) command: Thunar pid: 1031 cpu: 1.1%
  2: mem: 400.7 MiB (5.1%) command: chromium pid: 2369 cpu: 1.0%
  3: mem: 313.8 MiB (4.0%) command: chromium pid: 20269 cpu: 0.5%
  4: mem: 309.5 MiB (3.9%) command: chromium pid: 20305 cpu: 0.5%
  5: mem: 263.5 MiB (3.3%) command: chromium pid: 20049 cpu: 0.7%
  Processes: 234 Power: uptime: 15h 47m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 3.05 GiB services: upowerd,xfce4-power-manager
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.37
[x245@x245 ~]$
Please read through everything below – particularly the link about preformatted text.
I have edited your post in this instance. In future you are expected to use what you learn from those links; and use some common sense.
Update Announcements
System Information
or the short form:
inxi -zv8
Required reading
Resources
Although maybe not the cause of this particular issue, it’s definitely something you should attend to. See: Swap
Basically, the system will have to dump processes when RAM gets too full; yours is already at almost 60% after less than 16 hours uptime. This can, naturally, lead to crashes and other “unexpected behaviour”.
While this doesn’t necessarily relate to WiFi not working, it is nonetheless a serious consideration given that you have comparatively little space left on /:
In this instance I’d recommend any (or all) of the following;
  • Move infrequently used personal files (ISOs, video’s, etc) to external storage.
  • Create sufficient swap space for your system - this can be either a swap partition (or a swap file on /).
  • Invest in additional system RAM - 16GB might be an advantage.
Resources:
Indeed! Worth looking at du -h /var/cache/pacman/pkg/
… I currently have 15G in mine! Time for a cleanup.
Maybe pamac clean will help. :wink:
e.g.:
[brian@BG-T440-MANJARO ~] $ pamac clean
Number of versions of each package to keep in the cache: 3
To delete: 130 files  (870.3 MB)
Clean cache ? [y/N]
Maybe just set that to keep the last one, or do what I do:
sudo rm -r /var/cache/pacman/pkg/*
… although THIS IS CONSIDERED the NUCLEAR :warning: option!
Yes, possibly.
@artofit - please see;
In fact, read through the entire page, and bookmark it.
I took note of your remark reggarding swap in case of hypernation and changed that.
However, the problem is else where.
Often when I come out of hybernation, I get one of my core running at 100%, as soon as I disconnect from the network and reconnect immediately, then it’s back to normal.
I wanted to make the outputs as text file to easily make a file compare, by can’t attach(only img)
You’ll find 2 output related to the execution:
It happened just at boot(so after a shut down).
1st output, one of my core running wild, in this instance core 2
the 2nd output is after disconnect/reconnect to network, CPU is normal.
One sees that problem is:
1: cpu: 133% command: ps pid: 1607 mem: 3.75 MiB (0.0%)
Looking on the web, I’ve found people complaining about this very problem with board i915(my case)
Thanks
1st execution:
  System RAM: total: 8 GiB available: 7.65 GiB used: 1.24 GiB (16.2%)
  Speed (MHz): avg: 800 min/max: 800/3100 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 19961
    vulnerable
    affected
    modes: 1366x768
    class-ID: 0403
  Local Storage: total: 465.76 GiB used: 104.89 GiB (22.5%)
    dev-links: cdrom
  ID-1: / raw-size: 62.02 GiB size: 60.74 GiB (97.94%) used: 55.43 GiB (91.3%)
    used: 49.45 GiB (77.3%) fs: ntfs dev: /dev/sda5 maj-min: 8:5 label: DOCS
  ID-1: swap-1 type: partition size: 16.16 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 9e50aca1-7fa6-4fdc-871c-b311e729dea0
  ID-1: /dev/sda2 maj-min: 8:2 size: 17.58 GiB fs: ntfs label: dfast
    uuid: 0FD32C6469F59E95
  ID-2: /dev/sda3 maj-min: 8:3 size: 1 KiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda6 maj-min: 8:6 size: 279.87 GiB fs: ntfs label: MMedia
  ID-4: /dev/sda7 maj-min: 8:7 size: 16.36 GiB fs: ntfs label: OS_WORK
    serial: <filter>
  System Temperatures: cpu: 69.0 C mobo: N/A
  Packages: pm: pacman pkgs: 1673 libs: 397 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    3: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    4: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirrors2.manjaro.org/stable/$repo/$arch
    6: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    8: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    9: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    10: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    11: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    12: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    13: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    14: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    17: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    18: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    19: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    20: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    22: https://manjaro.ynh.ovh/stable/$repo/$arch
    23: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    24: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    25: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    26: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    27: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    28: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    29: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    32: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    33: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    34: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    35: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    36: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    37: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    38: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    39: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    40: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    41: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    42: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    43: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    44: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    45: https://mirror.init7.net/manjaro/stable/$repo/$arch
    46: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    47: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    48: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    50: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    51: https://mirror.23m.com/manjaro/stable/$repo/$arch
    52: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    53: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    54: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    55: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    56: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    57: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    58: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    59: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    60: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    62: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    63: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    64: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    65: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    66: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    67: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    68: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    69: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    70: https://manjaro.kurdy.org/stable/$repo/$arch
    71: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    72: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    73: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    74: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    75: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    76: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    77: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    78: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    79: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    80: https://linorg.usp.br/manjaro/stable/$repo/$arch
    81: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    82: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    83: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    84: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    85: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    86: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    87: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    88: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    89: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    90: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    91: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    92: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    93: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    94: http://manjaro.grena.ge/stable/$repo/$arch
    95: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    96: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    97: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    98: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    99: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    100: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    101: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    102: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    103: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    104: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    105: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    106: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 213
  2: cpu: 8.2% command: xfce4-terminal pid: 1582 mem: 51.8 MiB (0.6%)
  3: cpu: 6.5% command: Xorg pid: 780 mem: 106.0 MiB (1.3%)
  4: cpu: 3.0% command: Thunar pid: 1032 mem: 64.7 MiB (0.8%)
  5: cpu: 2.9% command: xfce4-mime-helper pid: 1575 mem: 30.2 MiB (0.3%)
  Memory top: 5 of 213
  1: mem: 106.0 MiB (1.3%) command: Xorg pid: 780 cpu: 6.5%
  2: mem: 80.5 MiB (1.0%) command: xfwm4 pid: 980 cpu: 1.3%
  3: mem: 77.7 MiB (0.9%) command: xfdesktop pid: 1038 cpu: 0.8%
  4: mem: 67.3 MiB (0.8%) command: libcpugraph.so started-by: wrapper-2.0
    pid: 1071 cpu: 0.2%
  5: mem: 64.7 MiB (0.8%) command: Thunar pid: 1032 cpu: 3.0%
  Processes: 213 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    running-in: xfce4-terminal inxi: 3.3.38
2nd output
  System RAM: total: 8 GiB available: 7.65 GiB used: 1.24 GiB (16.3%)
  Speed (MHz): avg: 2396 min/max: 800/3100 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2396 2: 2396 3: 2396 4: 2396 bogomips: 19961
    vulnerable
    affected
    modes: 1366x768
    class-ID: 0403
    dev-links: cdrom
    serial: <filter>
  System Temperatures: cpu: 64.0 C mobo: N/A
Processes:
  CPU top: 5 of 202
  1: cpu: 7.2% command: Xorg pid: 780 mem: 106.1 MiB (1.3%)
  2: cpu: 3.0% command: Thunar pid: 1032 mem: 65.2 MiB (0.8%)
  3: cpu: 1.5% command: xfwm4 pid: 980 mem: 83.5 MiB (1.0%)
  4: cpu: 0.9% command: NetworkManager pid: 650 mem: 27.4 MiB (0.3%)
  5: cpu: 0.9% command: xfce4-panel pid: 1027 mem: 49.2 MiB (0.6%)
  Memory top: 5 of 202
  1: mem: 106.1 MiB (1.3%) command: Xorg pid: 780 cpu: 7.2%
  2: mem: 83.5 MiB (1.0%) command: xfwm4 pid: 980 cpu: 1.5%
  3: mem: 78.3 MiB (0.9%) command: xfdesktop pid: 1038 cpu: 0.7%
  4: mem: 67.9 MiB (0.8%) command: libcpugraph.so started-by: wrapper-2.0
    pid: 1071 cpu: 0.2%
  5: mem: 65.2 MiB (0.8%) command: Thunar pid: 1032 cpu: 3.0%
  Processes: 202 Power: uptime: 5m states: freeze,mem,disk suspend: deep
