WiFi not working after a dual boot
Hi :grin: . I apologize if there is any gammer mistake in this . I’m not a native english speaker. I’m having an issue on this pc with manjaro :slightly_smiling_face: . As i mentioned in the heading , i had Manjaro single booted on my system. 2 days ago i installed Archcraft alongside Manjaro . I didn’t faced any issues while installing. Then i booted into Archcraft and i noticed that WiFi is not working :neutral_face:. Then i used ethernet in Archcraft , bcz i dont use archcraft too much. Then i booted into Manjaro and noticed that WiFi not working in manjaro also :crazy_face: . WiFi was woking perfectly on Manjaro till the installation on Archcraft.
This is my inxi output
  Kernel: 4.14.247-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: ro root=UUID=df68ec32-c7e5-45cf-8a30-dd853cb988d4
  initrd=boot\initramfs-4.14-x86_64.img
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
  Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 80CB v: 99.53 serial: <filter> UEFI: Insyde v: F.28
  date: 05/17/2019
  ID-1: BAT1 charge: 32.4 Wh (96.1%) condition: 33.7/33.7 Wh (100.0%)
  volts: 16.7 min: 14.6 model: 131-42-6E HS04041 type: Unknown
  serial: <filter> status: Charging
  RAM: total: 6.76 GiB used: 2.13 GiB (31.5%)
  Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64
  type: MCP arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1
  microcode: 7030106 cache: L2: 2 MiB bogomips: 17574
  Speed: 998 MHz min/max: 1000/2200 MHz boost: enabled Core speeds (MHz):
  1: 998 2: 998 3: 998 4: 998
  Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
  clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
  decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
  hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
  movbe msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
  pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
  sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall wdt xsave
  xsaveopt
  disabled, RSB filling
  Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
  driver: radeon v: kernel alternate: amdgpu bus-ID: 00:01.0
  chip-ID: 1002:9851 class-ID: 0300
  Device-2: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: USB
  driver: uvcvideo bus-ID: 4-1.1:3 chip-ID: 05c8:0382 class-ID: 0e02
  loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  OpenGL: renderer: AMD KABINI (DRM 2.50.0 4.14.247-1-MANJARO LLVM 12.0.1)
  v: 4.5 Mesa 21.2.1 direct render: Yes
  Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
  class-ID: 0403
  Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
  v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
  Sound Server-1: ALSA v: k4.14.247-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.35 running: yes
  Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: N/A
  port: 3100 bus-ID: 02:00.0 chip-ID: 14e4:4365 class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
  driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  IF-ID-1: enp0s18u1u1 state: unknown speed: N/A duplex: N/A mac: <filter>
  Device-1: OPPO RMX2193 type: USB driver: rndis_host v: kernel
  bus-ID: 1-1.1:5 chip-ID: 22d9:276a class-ID: 0a00 serial: <filter>
  Device-2: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
  bus-ID: 1-1.4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
  Local Storage: total: 931.51 GiB used: 23.42 GiB (2.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
  type: HDD rpm: 5400 serial: <filter> rev: 2C scheme: GPT
  Optical-1: /dev/sr0 vendor: hp model: DVDRW GUB0N rev: UB00 dev-links: cdrom
  ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 10.52 GiB (21.5%)
  fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: df68ec32-c7e5-45cf-8a30-dd853cb988d4
  ID-2: /boot/efi raw-size: 1 GiB size: 1022.6 MiB (99.80%)
  used: 123.3 MiB (12.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  label: LINUX_BOOT uuid: 26EB-9915
  ID-3: /home raw-size: 75 GiB size: 73.27 GiB (97.69%)
  used: 12.77 GiB (17.4%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
  uuid: aadeeae0-0e10-441b-90d3-637edf0ef7c2
  ID-1: /dev/sda2 maj-min: 8:2 size: 46 GiB fs: ext4 label: N/A
  uuid: 3abd51f3-9b3f-4220-84ac-5431604946a8
  ID-2: /dev/sda5 maj-min: 8:5 size: 381 GiB fs: ntfs label: Gaming
  uuid: 6C38EEE738EEAEF0
  ID-3: /dev/sda6 maj-min: 8:6 size: 273.9 GiB fs: ntfs label: Others
  uuid: B0CAF063CAF0276E
  ID-4: /dev/sda7 maj-min: 8:7 size: 4 GiB fs: swap label: N/A
  uuid: 4e946f44-e3cf-4d65-a1a4-2ec872e6c4a4
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
  speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
  Device-1: 1-1.1:5 info: OPPO RMX2193 type: Bluetooth,CDC-Data
  driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-2: 1-1.4:3 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth
  driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:216d
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Device-1: 2-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
  driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 98mA
  chip-ID: 046d:c534 class-ID: 0301
  Device-2: 2-2:3 info: China Resource Semico Keyboard type: Keyboard,HID
  power: 98mA chip-ID: 1a2c:2124 class-ID: 0300
  Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-6: 4-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
  Device-1: 4-1.1:3
  info: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: Video
  System Temperatures: cpu: 48.4 C mobo: 20.0 C gpu: radeon temp: 48.0 C
  Processes: 166 Uptime: 14m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1151 lib: 304 Shell: Zsh v: 5.8
  running-in: konsole inxi: 3.3.06
I think the driver is missing. I’m still a newbie at linux. I’m sure that you guys cam help me with this :grinning_face_with_smiling_eyes:
Although Kernel 4.14 is LTS, I would try with a different kernel to begin with. I would try with 5.4 LTS or 5.10LTS. It would be a good idea to install the kernel headers for the corresponding kernel as well. You can do this by going to Manjaro Settings Manager-Kernels section, Install kernel and reboot. Make sure that your system is fully updated.
It looks like this wifi chip requires the broadcom wl driver. In pamac, install the corresponding wl software for your kernel e.g. linux414-broadcom-wl or linux54-broadcom-wl etc. A reboot may be necessary here as well.
Also, don’t forget the obvious like maybe your laptop has a hard switch for turning wifi on or off, or in Network Manager(in tray) that "Enable Wifi is not checked.
Thanks sir , it worked :grin:. I installed 5.10LTS and installed the corresponding wl software. Now its working. Thankyou very much :grin:
No my pc dont have that key
