Hi! I have just reinstalled manjaro on my laptop and I do not see the wi fi icon anywhere (bottom right in the taskbar or anywhere else in the settings). I tried to read other posts about this, but none of them helped I will provide more information if you need any, but atm the only thing I can tell you is that the command inxi -Nazy returns:
Looking through some posts about the device (Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter), I think that the problem is with kernel. So you should first try switching kernels to the LTS release.
Installing this package from the AUR also seems necessary ~ rtl8821ce-dkms-git 1.0.5.r36.gca4abd8-1
You can install the LTS kernel from pamac (add/remove program) by searching for linux-lts. Enable AUR from preferences to install the package rtl8821ce-dkms-git 1.0.5.r36.gca4abd8-1
To switch your kernel, press SHIFT while rebooting to get into the grub menu, choose the advanced options and then select the LTS kernel ( kernel 5.4).
Hope this works for you, have a nice day.
In addition to the above, you will need to install the linux headers for your running kernels before installing the rtl8821ce-dkms-git from AUR. The following command from terminal will just do that:
I installed linux-lts 1:15.4-4 from “add/remove software”. Then I ran the first command that you mentioned and I got an error at some point, but the installation continued anyway so idk if that’s a big issue:
Error! Bad return status for module build on kernel: 4.14.215-1-MANJARO (x86_64)
Consult /var/lib/dkms/rtw88/r45.c63cbee/build/make.log for more information.
Then I ran the last command you gave me and then reboot. I tried to press shift while rebooting, but it did nothing, but it doesn’t matter because my wi fi is working!! Thank you so much!
As you can see i have it installed.
Or you install it from terminal: sudo mhwd-kernel -i linux54
Is the safest way to install the 5.4 kernel that is LTS. Then you reboot into it. Then proceed to what i described previously. While is safe to have 2 or 3 kernels installed and test them, no need to install them all.
That sounds good, but make sure you don’t clutter the install and you keep it tidy …
No need to do it again. Now you do have the linux headers for your running kernel and dkms will take care of the rtl8821ce-dkms-git when there will be another update.
