Hello everyone,
A few weeks ago I installed Manjaro KDE and Windows 10 in my laptop and got the dual booting working perfectly. Since then I have had some issues with Manjaro but everything works mostly fine.
Eventhough, I am having two problems with the wifi connection which I have not managed to solve.
The first one is that sometimes when I boot the wifi driver does not load at all, just as if there is no wifi card in the laptop. Once this happens I know no way of getting it back and for the moment it just comes back as mysteriously as it left. Today I managed to get it working when connecting via ethernet to the internet but other times this has not worked. The only hint I have is that it might be related to Windows because it often happens after I boot into Windows but I am not sure this is always the case. When the wifi is working the result of the command inxi -Fazy is the following:
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=79697d44-8f86-4a9c-b9df-ca0ab0aa7df7 rw amdgpu.runpm=0 quiet
apparmor=1 security=apparmor
resume=UUID=c008fdce-f716-41a4-b909-0b41bcad73d2 udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Micro-Star product: Bravo 15 A4DDR v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16WK v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16WKAMS.10D date: 05/19/2020
ID-1: BAT1 charge: 51.4 Wh condition: 51.4/51.3 Wh (100%) volts: 12.9/11.4
model: MSI Corp. MS-16WK type: Li-ion serial: N/A status: Full
Topology: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600102 L2 cache: 4096 KiB
bogomips: 92657
Speed: 1396 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1398 3: 1397 4: 1397 5: 1397 6: 1395 7: 1498 8: 1510 9: 1397
10: 1397 11: 1400 12: 1395 13: 1396 14: 1397 15: 1397 16: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:7340
Device-2: AMD Renoir vendor: Micro-Star MSI driver: amdgpu v: kernel
bus ID: 07:00.0 chip ID: 1002:1636
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus ID: 1-4:2
chip ID: 5986:211b
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.6-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.7 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:ab38
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Micro-Star MSI driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x bus ID: 07:00.5 chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 07:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 04:00.0
chip ID: 8086:2723
IF: wlp4s0 state: up mac: <filter>
vendor: Micro-Star MSI driver: r8168 v: 8.048.03-NAPI modules: r8169
port: f000 bus ID: 05:00.0 chip ID: 10ec:8168
IF: enp5s0 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 83.63 GiB (17.5%)
ID-1: /dev/nvme0n1 model: SSSTC CL1-8D512 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: 1.01 scheme: GPT
ID-1: / raw size: 333.73 GiB size: 327.49 GiB (98.13%)
used: 83.61 GiB (25.5%) fs: ext4 dev: /dev/nvme0n1p5
ID-1: swap-1 type: partition size: 15.63 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6
System Temperatures: cpu: 48.5 C mobo: N/A
GPU: device: amdgpu temp: 54 C fan: 65535 device: amdgpu temp: 40 C
Processes: 343 Uptime: 9h 32m Memory: 15.11 GiB used: 4.07 GiB (27.0%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1303 lib: 349
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
When the wifi is not working the result is:
ID-1: BAT1 charge: 51.1 Wh condition: 52.5/51.3 Wh (102%) volts: 12.5/11.4
model: MSI Corp. MS-16WK type: Li-ion serial: N/A status: Discharging
bogomips: 92662
Speed: 1501 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 2392 2: 2197 3: 1397 4: 1397 5: 1397 6: 1396 7: 1397 8: 1396 9: 1278
10: 1324 11: 1282 12: 1328 13: 1277 14: 1284 15: 1397 16: 1397
chip ID: 1002:7340
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus ID: 1-4:3
chip ID: 5986:211b
diag: 394mm (15.5")
Device-1: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi bus ID: 04:00.0
chip ID: 8086:2723
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
dev: /dev/nvme0n1p6
System Temperatures: cpu: 40.2 C mobo: N/A
GPU: device: amdgpu temp: 42 C device: amdgpu temp: 44 C fan: 65535
Processes: 308 Uptime: 6m Memory: 15.11 GiB used: 2.09 GiB (13.8%)
flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
Note that when this problem happens in the network section for the wifi card the driver is listed as N/A (instead of iwlwifi).
The second problem, which might be related, is a slow internet speed getting most of the time 0 bytes per second both for upload and download of data.
Any help will be most welcome.
Thank you very much
