After getting Manjaro installed and various things installed, I noticed my wifi is no longer working.
I can’t figure out what the issue is as it still works on the Windows install on the same machine.
I’m using a Asus ROG Crosshair VIII Dark Hero ATX AM4 Motherboard which ahs wifi built-in. What should I do to get it working properly again?
provide system info:
inxi -Faz
use formatting, click this icon in editor: </>
I got info to appear but when trying to save it as a plain text document, it won’t let me save the file to my external storage, just the OS storage
just copy the output, click this icon in the editor: </> and copy the output there
I’m so sorry…I pasted in Kate and KWrite and I can’t find it for the life of me
so just run the command again, or just take a picture of this:
mhwd-kernel -li && inxi -N
Currently running: 5.15.71-1-MANJARO (linux515)
Device-1 Realtek RTL8125 2.5GbE driver: r8169
Device-2 Intel I211 Gigabit Network driver: igb
Device-3 Intel Wi-Fi 6 AX200 driver: iwlwifi
Got it! I’ll try to copy those previous contents again, had to move it to a flash drive since it wouldn’t let me copy it on my internal extra storage, something about being read-only unless it was running on Windows
Had to type this out since the forum wouldn’t let me embed any images
so are you dual booting with windows? if yes, disable fast startup in windows, and then check if wifi is working in manjaro
I am, sorta. I’ve got two SSDs installed but I select which one I want to boot through the BIOS at start up
I’ll try disabling fast startup in the BIOS if I can
Kernel: 5.15.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=53f0a461-1e24-41d3-af43-ea78d27015b8 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3401
date: 03/19/2021
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3010 high: 4276 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3599 2: 2876
3: 2877 4: 2876 5: 2877 6: 2877 7: 2876 8: 2875 9: 2877 10: 4276 11: 2877
12: 2883 13: 2876 14: 2873 15: 2877 16: 2879 17: 3595 18: 3594 19: 2878
20: 2874 21: 2878 22: 2874 23: 2878 24: 2880 25: 2879 26: 3600 27: 2875
28: 2879 29: 2877 30: 2875 31: 2874 32: 2876 bogomips: 217674
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.0 chip-ID: 10de:2216
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 106 s-size: 613x362mm (24.13x14.25")
s-diag: 712mm (28.03")
Monitor-1: DP-4 res: 2560x1440 dpi: 107 size: 608x355mm (23.94x13.98")
diag: 704mm (27.72") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k5.15.71-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 7.28 TiB used: 14.32 GiB (0.2%)
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 613200WD temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital model: WD BLACK
SN850 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 614600WD
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD6003FZBX-00K5WB0 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 14.32 GiB
(1.6%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
System Temperatures: cpu: 43.1 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 48%
Processes: 501 Uptime: 0m wakeups: 0 Memory: 31.26 GiB used: 1.28 GiB
(4.1%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1341 libs: 414
tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.22
update, I couldn’t find this option in the BIOS, not sure where to go from here
brahma
10 October 2022 07:01
12
i told you to check if fast startup is disabled in windows :
I did it! Disabled it within the control panel, gave it a reboot to Manjaro and wifi works now! Thanks again, i’m very dense and somehow got confused. Thank you for your help
system
Closed
13 October 2022 15:26
14
