Wifi - No available networks
On a surface book 2 and decided to try Manjaro Linux KDE on a live usb. Everything seems to be working fine except for the wifi. It just says no available networks. Can anyone help
  Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=51a252a7-c283-4f02-a3ff-6b15fdee4997 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Microsoft product: Surface Book 2
    v: 124000000000000000000000D:0B:09K:0F:5C:09P:38
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: Microsoft model: Surface Book 2 serial: <superuser required>
    UEFI: Microsoft v: 392.72.768 date: 02.08.2014
  ID-1: BAT1 charge: 12.1 Wh (100.0%) condition: 12.1/18.0 Wh (67.2%)
    volts: 8.5 min: 7.5 model: SMP M1030911 type: Li-ion serial: <filter>
    status: full cycles: 695
  ID-2: BAT2 charge: 44.4 Wh (100.0%) condition: 44.4/51.1 Wh (86.8%)
    volts: 8.6 min: 7.5 model: SMP M1030908 type: Li-ion serial: <filter>
    status: full cycles: 732
  RAM: total: 7.68 GiB used: 2.75 GiB (35.7%)
  RAM Report:
  Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xEC
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 699 high: 700 min/max: 400/3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 700 2: 699 3: 700 4: 700
    bogomips: 21607
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
    cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
    epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
    ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: l1tf
  Device-1: Intel HD Graphics 620 vendor: Microsoft driver: i915 v: kernel
    ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:5916 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3000x2000 s-dpi: 96 s-size: 793x529mm (31.22x20.83")
    s-diag: 953mm (37.53")
  Monitor-1: eDP-1 model: Panasonic TDM13O56 serial: <filter> built: 2016
    res: 3000x2000 hz: 60 dpi: 263 gamma: 1.2 size: 290x190mm (11.42x7.48")
    diag: 343mm (13.5") ratio: 3:2 modes: 3000x2000
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.8
    direct render: Yes
  Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
  Unit
    driver: ipu3-imgu alternate: ipu3_imgu bus-ID: 00:05.0 chip-ID: 8086:1919
    class-ID: 0480
  Device-2: Intel CSI-2 Host driver: ipu3-cio2 alternate: ipu3_cio2
    bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
  Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.49 running: yes
  Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie
    v: 1.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0
    chip-ID: 11ab:2b38 class-ID: 0200
  IF-ID-1: enp0s20f0u1u1u2 state: unknown speed: -1 duplex: half
    mac: <filter>
  Device-1: Samsung Galaxy series misc. (tethering mode) type: USB
    driver: rndis_host v: kernel bus-ID: 1-1.1.2:7 chip-ID: 04e8:6863
    class-ID: 0a00 serial: <filter>
  Local Storage: total: 238.47 GiB used: 8.92 GiB (3.7%)
    model: MZFLW256HEHP-000MV size: 238.47 GiB block-size: physical: 512 B
    rev: CXB72M0Q temp: 32.9 C scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 8.92 GiB (3.8%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 51a252a7-c283-4f02-a3ff-6b15fdee4997
    label: NO_LABEL uuid: 4AF8-D0C6
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-1:2 info: Microsoft L1 USB2 Hub ports: 3 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 045e:0942 class-ID: 0900
  Hub-3: 1-1.1:3 info: Microsoft L2 USB2 Hub ports: 3 rev: 2.1
    speed: 480 Mb/s power: 100mA chip-ID: 045e:0944 class-ID: 0900
  Device-1: 1-1.1.2:7 info: Samsung Galaxy series misc. (tethering mode)
    type: Bluetooth,CDC-Data driver: rndis_host interfaces: 2 rev: 2.1
    speed: 480 Mb/s power: 500mA chip-ID: 04e8:6863 class-ID: 0a00
    serial: <filter>
  Device-2: 1-1.1.3:5 info: SINOWEALTH 2.4G Wireless Receiver
    type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 12 Mb/s power: 256mA chip-ID: 258a:002f class-ID: 0301
  Device-3: 1-1.3:4 info: Microsoft Surface Keyboard type: HID
    driver: hid-multitouch,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s
    power: 100mA chip-ID: 045e:0922 class-ID: 0300
  Hub-4: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Hub-5: 2-1:2 info: Microsoft L1 USB3 Gen1 Hub ports: 2 rev: 3.1
    speed: 5 Gb/s chip-ID: 045e:0941 class-ID: 0900
  Hub-6: 2-1.1:3 info: Microsoft L2 USB3 Gen1 Hub ports: 3 rev: 3.1
    speed: 5 Gb/s chip-ID: 045e:0943 class-ID: 0900
  System Temperatures: cpu: 41.0 C pch: 33.0 C mobo: N/A
  Processes: 189 Uptime: 6m wakeups: 2 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1195 lib: 332
  flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.15
Hi @Mus08, and welcome!
I see it looks like you device is using the correct driver. Or so it seems to me. So I think I can safely rule that out. Have you gone through this:
Also, on this page the answer is this:
https://github.com/linux-surface/linux-surface/wiki/Installation-and-Setup#arch
I don’t know if it’s the same and if it’ll work or not, just passing the info I’ve found.
Couldnt really find anything that relates to my issue on the links unfortunately
Install the package named linux-firmware-marvell.
sudo pacman -S linux-firmware-marvell
This solved my problem. Thanks a lot!
