In future please do not add your issue to another Member’s topic, no matter how similar it might be. This is commonly referred to as hijacking and is generally discouraged. Of course, if you have a solution for an issue, posting in their topic is always welcome.
Please provide system information as described below.
Your post has been moved to a dedicated topic. Feel free to change the title if you wish.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
@daff0d17 I am using this under Manjaro and Windows 10 without issues. It’s the AMD-branded card though. The Linux driver on latest kernels is stable. The Windows driver is very likely very outdated. You should find a more recent driver online from at least 2022. I know you can download it from Lenovo if you click past their pop-up banners.
Mine is the AMD RZ608 MT7921. Look up your PCI ID on your own using lspci -nn. Should be the same driver package though.
