I have got a weird problem on my Gnome Manjaro. When I click on the WIFI->Select Network the popup window freezes along with the OS. I could do nothing except Hard shutdown the laptop. However when click on WIFI>Wifi Settings I am able to switch network. This is happening recently. I was using the kernel with Version no. 5.4.108-1 LTS and I tried to switch to latest Kernal but the same issue. Can someone guide me on this issue
~ inxi -Fazy ✔
Kernel: 5.12.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=f9274d28-6379-4bb3-befe-ffd9297360e1 ro quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 3.38.2.1
Type: Laptop System: LENOVO product: 81H7 v: Lenovo ideapad 130-15IKB
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 130-15IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724 WIN serial: <filter>
UEFI: LENOVO v: 8QCN26WW(V1.14) date: 12/29/2020
ID-1: BAT1 charge: 14.4 Wh (56.5%) condition: 25.5/30.0 Wh (84.9%)
volts: 8.1 min: 7.5 model: 0x53 0x4D 0x50 0x00 0x31 0x PABAS0241231
type: Li-ion serial: <filter> status: Charging cycles: 768
Info: Dual Core model: Intel Core i3-7020U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
microcode: DE cache: L2: 3 MiB
bogomips: 18406
Speed: 800 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 811
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Chicony EasyCamera type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 04f2:b628 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.12.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-7:4 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 71.79 GiB (7.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
rotation: 5400 rpm serial: <filter> rev: LCM2 scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.97 GiB (97.93%) used: 14.16 GiB (28.9%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 191 MiB size: 188 MiB (98.45%)
used: 294 KiB (0.2%) fs: vfat dev: /dev/sda11 maj-min: 8:11
ID-3: /home raw-size: 230 GiB size: 226.14 GiB (98.32%)
used: 46.55 GiB (20.6%) fs: ext4 dev: /dev/sda8 maj-min: 8:8
ID-4: /usr raw-size: 41.2 GiB size: 40.5 GiB (98.28%)
used: 11.08 GiB (27.4%) fs: ext4 dev: /dev/sda9 maj-min: 8:9
System Temperatures: cpu: 45.5 C mobo: N/A
Processes: 252 Uptime: 15m wakeups: 1 Memory: 7.64 GiB
used: 2.76 GiB (36.1%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: 1543 pacman: 1537 lib: 427 flatpak: 0 snap: 6
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.03
