WIFI loses connection after some minutes working
Hello!
I’m new here and a complete beginner when it comes to Linux, apart from a few attempts with Mint.
I want to move away from Windows on my desktop computer. Since I haven’t installed any Ethernet cables in my house, I connect all my computers through Wi-Fi. My PC has an ASUS PCI card with a Broadcom 4352 chip. I’ve tried a few things and apparently the driver isn’t included with Fedora because it’s not open source.
While booting from USB to install Manjaro I clicked into system information and in the configuration menu it tells me that there is a proprietary driver for my Broadcom chip. I tried to install it but got many errors. I tethered an internet connection through my iPhone which worked just fine so I went on with the installation.
After rebooting it recognized the chip and installed drivers on its own. I could enter the WIFI password and connect.
BUT:
After some minutes beside the Wi-Fi icon there appeared a yellow exclamation mark indicating a limited connection. From that point, no matter what I do, it doesn’t work anymore. If I reboot I have a connection again till the same thing happens again.
I tried Fedora, with the same result, I tried Mint where it works flawless and without any problems, like in Windows.
I’m at a loss as to what could be causing this. I would appreciate any help or advice.
Note that the NetworkManager pings to http://ping.manjaro.org/check_network_status.txt. If it detects that packages are lost, it will show you this message. See this file: /usr/lib/NetworkManager/conf.d/20-connectivity.conf
I guess Fedora and Manjaro has this in common, while Linux Mint does not check the connection.
Can you check the journal when it happens it again?
journalctl --boot 0 --unit NetworkManager --no-pager --no-hostname
You could probably try to restart the NetworkManager:
systemctl restart NetworkManager
:notebook: That are terminal commands. Open a terminal and write it into it, to get results.
I guess you will need to look at the logs and do some debugging:
sudo dmesg -w
and/or
journalctl -f
in a terminal allow you to watch what happens at the time the connection gets lost and cant be reestablished.
Also, hardware info can help:
inxi -Fazy
for instance.
That is the wrong track - Mint does do a connection check as well, at least by default.
They have an extra package for that:
network-manager-config-connectivity...
and they check:
http://connectivity-check.ubuntu.com./
I know because I just installed Mint. :grinning:
Alright. It was just a guess. Thanks for clarification.
{;ease supply inxi -Fazy for this issue, there may be multiple areas of hardware/kernel that can be contributing factors, mobo, wifi/nics, kernel, etc.
I recently saw this issue with the 6.1 kernel ‘forgetting’ about network connections, nothing I did could restore them once they got forgotten, this happened with intel NIC, another intel NIC, and a USB NIC, at which point I realized this had to be a kernel regression, which was demonstrated as almost certainly the case when I rolled back to 5.19 kernel, which instantly solved the issue. I’m holding off on kernel updates for a few more kernel releases on the assumptioni that the issue has been resolved now since networking is so critical to the linux kernel.
I didn’t get log data unfortunately because I was assuming it was a hardware issue, it was only after the 3rd device failed in this way that I realized it was not possible that it was a hardware issue.
I’ll be testing a new kernel on that system fairly soon and will be able to determine if the regression persists or not in 6.2 kernels. This is a case where inxi -Fazy would have been very helpful, since this issue does not generally happen on most hardware and definitely not on all kernels, I found it probably related to suspend/wake events, but I could not pin it down beyond it certainly being a kernel regression that impacted one of my hardware configurations, but none of the others.
These were all wired NICs, not wifi, but given the event occured on mobo nic, pcie nic, and usb nic, it appears to have been at a higher level in the kernel, the actual networking stack above the specific device, so it might have also happened with wifi nics.
I’ve seen this ‘forgetting’ behavior on other features, back when liquorix used I think the bfs scheduler, it would ‘forget’ large usb writes, and simply stop, and nothing you did could make it remember it again. I tend to have run fairly new zen/liquorix kernels so I have seen these xcheduler related issues before, and this nic forgetting seems like it might have been related. Liquorix uses the more default scheduler now, that is I think part of the kernel project, but it is the optimized one and may be suffering from an issue like this, depends on the behavior, i saw it here with wake/suspend after a few days, for example, and the symptom was the same, a nic would work for about 15 minutes, then would just stop working, that’s why I posted, the behavior is quite similar to what I found, though with wifi it can also be other things since wifi is far more prone to failure for various reasons, like low end router with not enough ram for example, or just general hardware failure that is not fully failed yet, wifi is far more difficult to diagnose, wired is easier since there are far fewer variables involved.
For those who don’t know, damentz basically runs the zen kernel project, with some other people, and liquorix is the reference kernel for that project, so if you use a zen kernel, you are using the liquorix modifications, so that’s highly relevant.
Hi and welcome to the Forum :+1:
Can you check if the info on this page helps you? :thinking:
Thats an approach … but I dont think it can be considered ‘how to turn off wireless power management permanently (in every case)’. iwlmvm comes to mind.
https://wiki.archlinux.org/title/Power_management#Network_interfaces
I’m about to reinstall Manjaro now. dmesg says:
b43-phy0: Broadcom 4352 WLAN found (core revision 42)
[ 13.574976] b43-phy0 ERROR: FOUND UNSUPPORTED PHY (Analog 12, Type 11 (AC), Revision 1)
I managed to install the proprietary driver in the system settings. now it says:
and
[ 2760.814431] wl: version magic '6.1.22-1-MANJARO SMP preempt mod_unload ’ should be '6.1.19-1-MANJARO SMP preempt mod_unload ’
Inxi -Fazy says:
  Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_2205 quiet systemd.show_status=1
    splash driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: MAXIMUS VIII RANGER v: Rev 1.xx
    serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 3504
    date: 06/30/2017
  Info: model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xBA
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 3500 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3500 2: 3500 3: 3500 4: 3500 bogomips: 28009
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT disabled
  Type: mmio_stale_data status: Vulnerable: Clear CPU buffers attempted, no
    microcode; SMT disabled
  Type: retbleed status: Vulnerable
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
    PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Type: tsx_async_abort status: Vulnerable: Clear CPU buffers attempted, no
  Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: ASUSTeK
    driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2023-02) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1e84 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
    s-diag: 692mm (27.26")
  Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 109
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX 2070
    SUPER/PCIe/SSE2 direct-render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
    driver: snd_hda_intel bus-ID: 1-9:4 v: kernel bus-ID: 00:1f.3
    chip-ID: 08bb:2902 class-ID: 0300 chip-ID: 8086:a170 class-ID: 0403
  Device-2: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10f8 class-ID: 0403
  Device-3: Texas Instruments PCM2902 Audio Codec type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4352 802.11ac Wireless Network Adapter
    vendor: ASUSTeK driver: N/A modules: bcma, wl pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 04:00.0 chip-ID: 14e4:43b1 class-ID: 0280
  Device-3: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad
    bus-ID: 1-10:5 chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
  Local Storage: total: 3.21 TiB used: 0 KiB (0.0%)
    model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: 731100WD temp: 29.9 C scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    type: SSD serial: <filter> rev: 3B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Samsung
    model: SSD 850 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Transcend
    model: JetFlash 32GB size: 29.44 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> rev: 1.00 scheme: MBR
  Message: No partition data found.
  System Temperatures: cpu: 26.0 C mobo: N/A gpu: nvidia temp: 28 C
  Processes: 186 Uptime: 50m wakeups: 1 Memory: 15.56 GiB
  used: 3.68 GiB (23.7%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1197 libs: 322 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
I’m now trying to install it and then report back…
ok. I installed everything by ethernet cable, I did all the updates and it worked for an hour now. I installed steam, downloaded a game… and then suddenly it disconnects, I get an error message: limited internet connection. It worked till now without any problem.
I am connected to my router. Again. With a yellow “!”-mark.
dmesg gives me an error:
ERROR @wl_notify_scan_status:
wlpp4s0 Scan_results error (-22)
journalctl -f gives me an error:
bgscan simple: Failed to enable signal strength monitoring
journalctl -f
Apr 10 16:39:15 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:39:15 Linux NetworkManager[2688]: <info>  [1681137555.4582] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:39:15 Linux NetworkManager[2688]: <info>  [1681137555.4583] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:39:15 Linux NetworkManager[2688]: <info>  [1681137555.4737] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:15 Linux NetworkManager[2688]: <info>  [1681137555.4738] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:39:15 Linux NetworkManager[2688]: <info>  [1681137555.4738] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:15 Linux NetworkManager[2688]: <info>  [1681137555.4740] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:39:15 Linux NetworkManager[2688]: <info>  [1681137555.4740] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:15 Linux NetworkManager[2688]: <info>  [1681137555.4741] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:39:15 Linux NetworkManager[2688]: <info>  [1681137555.4741] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:18 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:39:18 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:39:18 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:39:18 Linux NetworkManager[2688]: <info>  [1681137558.6689] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:39:18 Linux NetworkManager[2688]: <info>  [1681137558.7685] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:39:20 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.4103] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:39:20 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:39:20 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:39:20 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.4803] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.4941] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:39:20 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:39:20 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:39:20 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.5127] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.5129] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.5271] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.5271] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.5273] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.5275] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.5275] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.5276] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:39:20 Linux NetworkManager[2688]: <info>  [1681137560.5276] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:23 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:39:23 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:39:23 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:39:23 Linux NetworkManager[2688]: <info>  [1681137563.6011] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:39:23 Linux NetworkManager[2688]: <info>  [1681137563.7016] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:39:25 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.3738] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:39:25 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:39:25 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:39:25 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.4497] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.4608] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:39:25 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:39:25 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:39:25 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.4802] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.4805] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.5071] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.5072] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.5073] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.5075] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.5076] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.5076] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:39:25 Linux NetworkManager[2688]: <info>  [1681137565.5077] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:27 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:39:27 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:39:27 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:39:27 Linux NetworkManager[2688]: <info>  [1681137567.7043] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:39:27 Linux NetworkManager[2688]: <info>  [1681137567.8040] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:39:29 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.4503] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:39:29 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:39:29 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:39:29 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5311] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5418] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:39:29 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:39:29 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:39:29 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5618] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5620] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5804] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5805] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5806] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5808] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5809] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5809] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:39:29 Linux NetworkManager[2688]: <info>  [1681137569.5810] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:32 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:39:32 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:39:32 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:39:32 Linux NetworkManager[2688]: <info>  [1681137572.8144] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:39:32 Linux NetworkManager[2688]: <info>  [1681137572.9139] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:39:34 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.5636] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:39:34 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:39:34 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:39:34 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6392] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6525] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:39:34 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:39:34 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:39:34 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6701] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6702] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6937] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6939] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6941] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6943] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6944] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6944] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:39:34 Linux NetworkManager[2688]: <info>  [1681137574.6945] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:35 Linux plasmashell[1635]: Fontconfig warning: Directory/file mtime in the future. New fonts may not be detected.
Apr 10 16:39:37 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:39:37 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:39:37 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:39:37 Linux NetworkManager[2688]: <info>  [1681137577.7811] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:39:37 Linux NetworkManager[2688]: <info>  [1681137577.8805] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:39:38 Linux rtkit-daemon[638]: Supervising 9 threads of 5 processes of 1 users.
Apr 10 16:39:39 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.5205] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:39:39 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:39:39 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:39:39 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.5963] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6083] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:39:39 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:39:39 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:39:39 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6284] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6285] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6503] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6505] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6506] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6508] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6509] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6509] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:39:39 Linux NetworkManager[2688]: <info>  [1681137579.6510] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:42 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:39:42 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:39:42 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:39:42 Linux NetworkManager[2688]: <info>  [1681137582.9942] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:39:43 Linux NetworkManager[2688]: <info>  [1681137583.0938] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:39:44 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.7405] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:39:44 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:39:44 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:39:44 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8159] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8264] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:39:44 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:39:44 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:39:44 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8459] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8460] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8737] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8738] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8739] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8742] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8742] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8742] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:39:44 Linux NetworkManager[2688]: <info>  [1681137584.8743] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:48 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:39:48 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:39:48 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:39:48 Linux NetworkManager[2688]: <info>  [1681137588.0576] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:39:48 Linux NetworkManager[2688]: <info>  [1681137588.1571] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:39:49 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.7968] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:39:49 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:39:49 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:39:49 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.8702] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.8807] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:39:49 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:39:49 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:39:49 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.8973] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.8974] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.9204] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.9205] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.9206] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.9208] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.9209] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.9209] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:39:49 Linux NetworkManager[2688]: <info>  [1681137589.9210] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:53 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:39:53 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:39:53 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:39:53 Linux NetworkManager[2688]: <info>  [1681137593.1142] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:39:53 Linux NetworkManager[2688]: <info>  [1681137593.2138] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:39:54 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.8562] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:39:54 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:39:54 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:39:54 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9382] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9494] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:39:54 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:39:54 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:39:54 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9696] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9698] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9870] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9871] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9872] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9875] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9875] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9876] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:39:54 Linux NetworkManager[2688]: <info>  [1681137594.9876] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:39:58 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:39:58 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:39:58 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:39:58 Linux NetworkManager[2688]: <info>  [1681137598.1909] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:39:58 Linux NetworkManager[2688]: <info>  [1681137598.2904] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:39:59 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:39:59 Linux NetworkManager[2688]: <info>  [1681137599.9337] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:40:00 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:40:00 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:40:00 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0101] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0234] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:40:00 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:40:00 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:40:00 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0406] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0407] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0604] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0605] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0606] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0608] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0609] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0609] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:40:00 Linux NetworkManager[2688]: <info>  [1681137600.0610] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:03 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:40:03 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:40:03 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:40:03 Linux NetworkManager[2688]: <info>  [1681137603.1076] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:40:03 Linux NetworkManager[2688]: <info>  [1681137603.2070] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:40:04 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.8473] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:40:04 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:40:04 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:40:04 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9168] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9293] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:40:04 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:40:04 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:40:04 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9560] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9561] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9671] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9671] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9673] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9675] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9676] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9676] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:40:04 Linux NetworkManager[2688]: <info>  [1681137604.9676] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:06 Linux plasmashell[1635]: Fontconfig warning: Directory/file mtime in the future. New fonts may not be detected.
Apr 10 16:40:07 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:40:07 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:40:07 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:40:08 Linux NetworkManager[2688]: <info>  [1681137608.0010] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:40:08 Linux NetworkManager[2688]: <info>  [1681137608.1005] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:40:09 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.7571] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:40:09 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:40:09 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:40:09 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8307] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8419] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:40:09 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:40:09 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:40:09 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8594] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8596] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8937] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8938] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8939] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8941] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8942] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8942] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:40:09 Linux NetworkManager[2688]: <info>  [1681137609.8943] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:13 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:40:13 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:40:13 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:40:13 Linux NetworkManager[2688]: <info>  [1681137613.3709] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:40:13 Linux NetworkManager[2688]: <info>  [1681137613.4704] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:40:15 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:40:15 Linux NetworkManager[2688]: <info>  [1681137615.1137] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:40:15 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:40:15 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:40:15 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:40:15 Linux NetworkManager[2688]: <info>  [1681137615.1966] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2023] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:40:16 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:40:16 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:40:16 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2251] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2253] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2637] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2638] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2639] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2641] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2642] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2642] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:40:16 Linux NetworkManager[2688]: <info>  [1681137616.2643] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:20 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:40:20 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:40:20 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:40:20 Linux NetworkManager[2688]: <info>  [1681137620.5644] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:40:20 Linux NetworkManager[2688]: <info>  [1681137620.6640] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:40:22 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.3002] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:40:22 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:40:22 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:40:22 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4296] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4384] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:40:22 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:40:22 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:40:22 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4566] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4567] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4770] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4771] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4772] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4774] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4775] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4775] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:40:22 Linux NetworkManager[2688]: <info>  [1681137622.4776] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:26 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:40:26 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:40:26 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:40:26 Linux NetworkManager[2688]: <info>  [1681137626.7210] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:40:26 Linux NetworkManager[2688]: <info>  [1681137626.8206] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:40:28 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.4536] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:40:28 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:40:28 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:40:28 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5262] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5379] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:40:28 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:40:28 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:40:28 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5543] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5543] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5671] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5671] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5672] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5674] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5674] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5675] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:40:28 Linux NetworkManager[2688]: <info>  [1681137628.5675] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:31 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:40:31 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:40:31 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:40:31 Linux NetworkManager[2688]: <info>  [1681137631.7810] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:40:31 Linux NetworkManager[2688]: <info>  [1681137631.8805] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:40:33 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.5440] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:40:33 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:40:33 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:40:33 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7102] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7183] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:40:33 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:40:33 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:40:33 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7351] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7352] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7537] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7538] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7539] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7542] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7542] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7543] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:40:33 Linux NetworkManager[2688]: <info>  [1681137633.7543] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:37 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:40:37 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:40:37 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:40:37 Linux NetworkManager[2688]: <info>  [1681137637.4298] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:40:37 Linux NetworkManager[2688]: <info>  [1681137637.5295] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:40:37 Linux plasmashell[1635]: Fontconfig warning: Directory/file mtime in the future. New fonts may not be detected.
Apr 10 16:40:39 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.1863] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:40:39 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:40:39 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:40:39 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.2610] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.2765] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:40:39 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:40:39 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:40:39 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.2934] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.2935] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.3237] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.3238] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.3239] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.3241] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.3242] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.3242] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:40:39 Linux NetworkManager[2688]: <info>  [1681137639.3243] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:43 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=2c:91:ab:30:3e:a5 reason=0
Apr 10 16:40:43 Linux wpa_supplicant[548]: BSSID 2c:91:ab:30:3e:a5 ignore list count incremented to 2, ignoring for 10 seconds
Apr 10 16:40:43 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Apr 10 16:40:43 Linux NetworkManager[2688]: <info>  [1681137643.5078] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 10 16:40:43 Linux NetworkManager[2688]: <info>  [1681137643.6074] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 10 16:40:45 Linux wpa_supplicant[548]: wlp4s0: Trying to associate with 2c:91:ab:cc:a9:86 (SSID='Kuhdorf1' freq=2412 MHz)
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.2706] device (wlp4s0): supplicant interface state: scanning -> associating
Apr 10 16:40:45 Linux wpa_supplicant[548]: wlp4s0: Associated with 2c:91:ab:30:3e:a5
Apr 10 16:40:45 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 10 16:40:45 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4271] device (wlp4s0): supplicant interface state: associating -> associated
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4362] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 10 16:40:45 Linux wpa_supplicant[548]: wlp4s0: WPA: Key negotiation completed with 2c:91:ab:30:3e:a5 [PTK=CCMP GTK=CCMP]
Apr 10 16:40:45 Linux wpa_supplicant[548]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:30:3e:a5 completed [id=0 id_str=]
Apr 10 16:40:45 Linux wpa_supplicant[548]: bgscan simple: Failed to enable signal strength monitoring
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4533] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4535] device (wlp4s0): ip:dhcp4: restarting
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4737] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4738] dhcp4 (wlp4s0): state changed no lease
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4739] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4741] device (wlp4s0): ip:dhcp6: restarting
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4742] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4742] dhcp6 (wlp4s0): state changed no lease
Apr 10 16:40:45 Linux NetworkManager[2688]: <info>  [1681137645.4743] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Does ethernet work now? If it works, does it also manifest the same issue of working for a bit, then stopping, and nothing being able to start it?
This is the same kernel version I saw the issue with, and there’s an intel nic, and the wifi broadcom (which has I believe a poor reputation for linux support).
Test on ethernet connection, if it works for days, then it’s not the issue, if it also stops after a while, it is.
Please edit your post to use proper code blocks to show program output/logs, see:
This means you are using a wrong driver version, which is compiled for a different kernel…
Reconcile what you did to install that driver and fix it to have the version for the same kernel version as you are running…
Thank you for your help!
I installed the driver by going into the system menu and clicking on the “install proprietary drivers” button. There I could click on my WIFI card and automatically install them.
So the function by Manjaro installed the wrong driver version? That is all?
Does this mean it’s better to install them in the Terminal?
How do I find the right driver version? Or should I find the right kernel fitting to the drivers?
If that is true then that is a bug you should be able to report somewhere :+1:
Most logically a new thread just about that…
You could try to first uninstall the current version and then after reboot try the DKMS version which should auto-compile for the kernels you have.
You will need to install extra packages like kernel headers for the kernels you use etc.
is the issue corrected with the new driver? that would confirm what damentz suspects about this issue, roughly, that a bug in a driver is triggering higher up erratic issues in the networking stack. Not necessarily the driver that is apparently active by the way, which I think is one reason the issue is hard to track down.
I tried to install the driver but I got error messages:
Unload and load kernel modules (wl is provided by broadcom-wl-dkms):
  rmmod b43 b43legacy bcm43xx bcma brcm80211 brcmfmac brcmsmac ssb tg3 wl
  modprobe wl
:: Post-transaction-Hooks werden gestartet …
(1/3) Arming ConditionNeedsUpdate...
(2/3) Install DKMS modules
==> ERROR: Missing sys kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing sbin kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing proc kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing mnt kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing srv kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing rootfs-pkgs.txt kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing lib kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing run kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing etc kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing tmp kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing lib64 kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing boot kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing dev kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing home kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing root kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing desktopfs-pkgs.txt kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing var kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing opt kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing bin kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing usr kernel headers for module broadcom-wl/6.30.223.271.
==> ERROR: Missing lost+found kernel headers for module broadcom-wl/6.30.223.271.
(3/3) Refreshing PackageKit...
How do I install those missing kernel headers?
Like that for kernel 6.1:
pamac install linux61-headers
Ok, I managed to update / install the missing kernel headers.
Everything worked fine, I installed with sudo pacman -S broadcom-wl-dkms and after 8 minutes, the internet was gone. :frowning:
I don’t know what to do from now. I feel like I have tried so many things. And nothing works…
I did not expect the drivers to make a difference to be honest, though it was worth trying, this is more and more looking like you may have found a test case for this network vanish issue.
Obvious things to do are try installing a 5.19 kernel, and a 6.2 kernel, I know liquorix has previous kernels available for install, but I don’t know how you do that in arch based distros. If 5.19 resolves the issue then, again, you have almost certainly confirmed the issue is real and is in at least the 6.1 kernel, which is where I experienced it.
Another very obvious thing to test is first, LAN/ethernet direct connection, if that works, and keeps working, then it’s not the issue I suspect. If it also starts failing, it is certainly the issue I suspect. However, do yourself a favor, wifi introduces so many failure points, eliminate wifi from the equation and use ethernet real wired to confirm that it’s not the kernel issue, if that works, it’s just a normal wifi issue.
On the wifi end, it’s highly relevant as well to determine if the router is failing, or if the failure is actually in linux kernel itself. Low end consumer routers always ship with minimum ram or cpu power, the ones that ISPs give you for example are total junk, and could easily lead to failed or dropped wifi connections, particularly if more than one person is using them at a time, and in extra particular, if it’s a shared wifi in a household where people use their devices to stream audio or video.
Other options are that your wifi chip is failing, or the router wifi chip is failing, but is not failed, that is simple to test by using a usb wifi device that is linux compatible.
The lan connection is working.
I can definitely say that it is neither my router nor my Wi-Fi card. I’m playing video games with it on a daily basis. Without disconnects. The router is a mesh capable high end router. It works flawless. Due to the house being special I have no other possibilities than Wi-Fi.
I used my Wi-Fi extender near my PC and plugged a Ethernet cable into it. This works in Manjaro. As does tethering with my iPhone into my Wi-Fi.
So it is a driver problem. Something I haven’t figured out yet…
Please give a current inxi as well as
rfkill list
pacman -Qs broadcom
lsmod | grep 'broadcom\|wl'
And oh yeah … TLP?
systemctl status tlp
