rfkill list result
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
inxi -Fazy result
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=b9347fc8-fa22-4041-89b9-4bac8f435b9f rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: Stealth GS77 12UGS v: REV:1.0
Mobo: Micro-Star model: MS-17P1 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E17P1IMS.106 date: 01/27/2022
ID-1: BAT1 charge: 42.1 Wh (43.8%) condition: 96.1/95.0 Wh (101.2%)
volts: 14.8 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: discharging
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x414
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 424 high: 487 min/max: 400/5000:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 480 2: 468 3: 487 4: 415
5: 424 6: 410 7: 429 8: 454 9: 432 10: 422 11: 431 12: 431 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 116780
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU]
vendor: Micro-Star MSI driver: nvidia v: 510.68.02
alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:24a0 class-ID: 0302
Device-3: Acer FHD Camera type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 5986:213a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2048x1152 s-dpi: 96 s-size: 541x304mm (21.30x11.97")
s-diag: 621mm (24.43")
Monitor-1: eDP-1 model: BOE Display 0x09f9 built: 2021 res: 2048x1152
dpi: 137 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: 2560x1440
OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio
vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228b class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
driver: N/A modules: iwlwifi bus-ID: 00:14.3 chip-ID: 8086:51f0
class-ID: 0280
Device-2: Realtek Killer E3000 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 30:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp48s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 2.75 TiB used: 12.74 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Micron model: 3400 MTFDKBA1T0TFH
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P7MA000 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 12.71 GiB (1.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:5
used: 27.6 MiB (9.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 354 Uptime: 7m wakeups: 1207 Memory: 31.06 GiB
used: 2.32 GiB (7.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1216 lib: 336 flatpak: 0
Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.15
