WIFI isn't available on live CD
Hello,
I want to install Manjaro and trying the live version first with a USB stick - however i can’t connect to the internet via WIFI. Wireless networks isn’t visable at all when i click the networks
symbol in the corner. Tried to look around at the settings and didn’t find anything useful. Also didn’t find a solution on the forum that i can be sure suitable for my machine - I don’t want to run commands i am not sure of.
Any help will be very much appriciated.
Here are my system details:
  Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
  Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Laptop 15-dw2xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: HP model: 85F3 v: 40.26 serial: <filter> UEFI: Insyde v: F.30
  date: 06/03/2020
  ID-1: BAT1 charge: 41.9 Wh condition: 41.9/41.0 Wh (102%)
  volts: 12.9/11.3 model: COMPAL PABAS0241231 type: Li-ion
  serial: <filter> status: Full
  RAM: total: 7.56 GiB used: 604.7 MiB (7.8%)
  RAM Report:
  Topology: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
  arch: Ice Lake rev: 5 L2 cache: 4096 KiB bogomips: 9524
  Speed: 1001 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 1001
  2: 1000 3: 1000 4: 1000
  arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
  avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
  avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
  constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
  epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
  fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req
  ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx ospke
  pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt
  pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg sep sha_ni smap
  smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
  syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
  tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1
  xsave xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:8a56
  Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
  bus ID: 1-5:3 chip ID: 0408:5365
  Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel
  unloaded: modesetting alternate: fbdev,vesa resolution: 1920x1080~60Hz
  s-dpi: 96
  OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 20.1.8
  direct render: Yes
  Device-1: Intel Smart Sound Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:34c8
  Sound Server: ALSA v: k5.8.11-1-MANJARO
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000
  bus ID: 01:00.0 chip ID: 10ec:8168
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
  vendor: Hewlett-Packard driver: N/A port: 3000 bus ID: 02:00.0
  chip ID: 10ec:c821
  WAN IP: No WAN IP found. Connected to web? SSL issues?
  Local Storage: total: 297.19 GiB used: 110.0 MiB (0.0%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC511 HFM256GDJTNI-82A0A
  size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: HPS0
  scheme: GPT
  ID-2: /dev/sda type: USB vendor: SanDisk model: Cruzer Blade
  size: 58.71 GiB serial: <filter> rev: 1.00 scheme: MBR
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode]
  driver: ahci v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a
  rev: 30
  ID-1: / size: 5.67 GiB used: 110.0 MiB (1.9%) fs: overlay
  source: ERR-102 label: N/A uuid: N/A
  ID-1: /dev/nvme0n1p1 size: 260.0 MiB fs: vfat label: SYSTEM
  uuid: 164E-B7C6
  ID-2: /dev/nvme0n1p2 size: 16.0 MiB fs: <superuser/root required>
  ID-3: /dev/nvme0n1p3 size: 237.68 GiB fs: ntfs label: Windows
  uuid: B6F89971F899311B
  ID-4: /dev/nvme0n1p4 size: 534.0 MiB fs: ntfs label: Windows RE tools
  uuid: 1A4099F24099D4BB
  ID-5: /dev/sda1 size: 2.90 GiB fs: iso9660 label: MANJARO_KDE_2011
  uuid: 2020-10-01-14-09-49-00
  ID-6: /dev/sda2 size: 4.0 MiB fs: vfat label: MISO_EFI uuid: 1AFD-57C6
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002
  Device-1: 1-1:2 info: SanDisk Cruzer Blade type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
  chip ID: 0781:5567 serial: <filter>
  Device-2: 1-5:3 info: Quanta HP TrueVision HD Camera type: Video
  driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
  chip ID: 0408:5365
  Device-3: 1-10:4 info: Realtek Realtek Bluetooth 4.2 Adapter
  type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
  chip ID: 0bda:b00a serial: <filter>
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1
  speed: 10 Gb/s chip ID: 1d6b:0003
  System Temperatures: cpu: 48.0 C mobo: 10.0 C
  Processes: 177 Uptime: 9m Init: systemd v: 246 Compilers: gcc: N/A
  Packages: pacman: 1201 Shell: Bash v: 5.0.18 running in: konsole
  inxi: 3.1.05
You don’t have driver for wifi card. You need install dkms and rtl8821ce-dkms-git. Kernel 5.9 probably will bring native support(*) so you can wait (most likely 2-3 weeks).
(*) See patches for 5.9
EDIT: 5.9 was released today :smiley: So with next update this kernel should be stable in Manjaro. Now you can install RC version (I forgot about it earlier :sweat_smile:).
Thanks a lot!
is the linux5.9 stable? When I open system settings GUI, it says that the kernel is experimental, but in linux kernel archives - “mainline”, which is considered stable if i understood correctly. Which is true? Am I missing something? I’m still new to these concepts.
In Manjaro 5.9 is still experimental. For stable, you need to wait until Manjaro Team compile 5.9 and release update. It may be tomorrow or next week, I don’t know. The process is so:
  1. Kernel team work on new kernel and when ready release it. There 5.9 was released and stable.
  2. After 1. Manjaro Team compile kernel and add new version to repo > new kernel is released in update. Now new kernel must go all way from unstable to stable branch. You can see here where new kernel is.
  3. After 2 .end user install kernel when want and use :smiley:
Very nicely explained. I will wait for the update release. Thank you :slight_smile: .
Hi,
I have installed manjaro and today installed the 5.9.1 kernel. However WIFI is still not working, and i can see that there is no driver for WIFI card (as shown below). That is true for booting with the normal 5.9.1 kernel and also with the fallback initramfs version (not sure this is relevant to the issue, but I checked them both).
is there any further action i need to take to activate the driver?
Thanks in advance
  Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=f1329415-c460-4aa8-b2a0-3d5f7a728849 rw quiet apparmor=1
  Type: Laptop System: HP product: HP Laptop 15-dw2xxx v: Type1ProductConfigId
  serial: <filter> Chassis: type: 10 serial: <filter>
  date: 06/03/2020
  ID-1: BAT1 charge: 22.8 Wh condition: 40.7/41.0 Wh (99%) volts: 12.3/11.3
  model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Charging
  arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: 78
  L2 cache: 4096 KiB
  bogomips: 9524
  Speed: 1101 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 1101 2: 1000
  3: 1071 4: 1001
  Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
  unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  direct render: Yes
  driver: snd_hda_intel v: kernel alternate: snd_sof_pci bus ID: 00:1f.3
  chip ID: 8086:34c8
  Sound Server: ALSA v: k5.9.1-1-MANJARO
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 01:00.0
  chip ID: 10ec:8168
  vendor: Hewlett-Packard driver: N/A modules: rtw88_8821ce port: 3000
  bus ID: 02:00.0 chip ID: 10ec:c821
  Local Storage: total: 238.47 GiB used: 8.93 GiB (3.7%)
  size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: HPS0 scheme: GPT
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a rev: 30
  ID-1: / raw size: 159.70 GiB size: 156.19 GiB (97.80%) used: 8.87 GiB (5.7%)
  fs: ext4 dev: /dev/nvme0n1p5
  System Temperatures: cpu: 56.0 C mobo: 10.0 C
  Processes: 174 Uptime: 27m Memory: 7.56 GiB used: 2.24 GiB (29.6%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1173 lib: 319
  flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
