My wifi doesn’t work properly, it takes several attempts to connect and after some time (especially if I use it heavily) the connection is lost. I have already tried a downgrade from intel-ucode
as well as going back to the 5.4 kernel
, unfortunately without any particular changes.
What else could be the cause?
here is my output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=41888f01-0692-4574-93d3-e6ba14828cb3 rw pci=noaer quiet
cryptdevice=UUID=3e8344b5-ad75-400c-84f3-a7b65370c345:luks-3e8344b5-ad75-400c-84f3-a7b65370c345
root=/dev/mapper/luks-3e8344b5-ad75-400c-84f3-a7b65370c345
resume=/dev/mapper/luks-3e8344b5-ad75-400c-84f3-a7b65370c345
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TUXEDO product: N8xxEZ v: N/A serial: <filter>
Chassis: No Enclosure type: 10 serial: <filter>
Mobo: TUXEDO model: N8xxEZ serial: <filter> UEFI: American Megatrends
v: 1.07.08 date: 10/04/2018
ID-1: BAT0 charge: 58.0 Wh (100.0%) condition: 58.0/59.9 Wh (96.7%)
volts: 12.6 min: 11.1 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
RAM: total: 15.37 GiB used: 4.52 GiB (29.4%)
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 9 MiB bogomips: 52815
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-8:5 chip-ID: 04f2:b59e class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1013x316mm (39.9x12.4")
s-diag: 1061mm (41.8")
Monitor-1: DP-1 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8")
diag: 611mm (24.1")
Monitor-2: HDMI-2 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:3 chip-ID: 0d8c:0014
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
vendor: CLEVO/KAPOK driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 3000
bus-ID: 03:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f1 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: virbr1 state: down mac: <filter>
bus-ID: 1-14:7 chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Device-1: luks-3e8344b5-ad75-400c-84f3-a7b65370c345 maj-min: 254:0
type: LUKS dm: dm-0 size: 476.64 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 476.64 GiB
Local Storage: total: 942.7 GiB used: 706.65 GiB (75.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.16 GiB (98.22%)
used: 436.91 GiB (93.3%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-3e8344b5-ad75-400c-84f3-a7b65370c345 label: N/A
uuid: 41888f01-0692-4574-93d3-e6ba14828cb3
used: 424 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 0458-99DB
ID-3: /run/media/richie/VMHDD raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 269.74 GiB (59.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: VMHDD
uuid: 3020ba83-d9f0-4606-ad81-33c722d33106
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Hub-2: 1-5:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 1a40:0201 class-ID: 0900
Hub-3: 1-5.4:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-5.4.1:6 info: Microsoft Natural Ergonomic Keyboard 4000 V1.0
type: Keyboard,HID driver: microsoft,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s power: 100mA chip-ID: 045e:00db class-ID: 0300
Device-2: 1-6:3 info: C-Media Audio Adapter (Unitek Y-247A) type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 0d8c:0014 class-ID: 0300
serial: <filter>
Device-3: 1-8:5 info: Chicony Chicony USB2.0 Camera type: Video
Device-4: 1-14:7 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 325 Uptime: 15m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1709 lib: 463
flatpak: 0 Shell: Bash v: 5.1.8 running-in: terminator inxi: 3.3.07
The output when the disconnect happens(Kernel 5.10 and latest intel-ucode):
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: Microcode SW error detected. Restarting 0x2000000.
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: Status: 0x00000040, count: 6
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: Loaded firmware version: 36.ca7b901d.0 8265-36.ucode
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000083 | trm_hw_status0
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00024A8C | branchlink2
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x0003AC1E | interruptlink1
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00004DD2 | interruptlink2
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | data1
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00001000 | data2
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x03830000 | data3
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x5E012738 | beacon time
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xDD0F789C | tsf low
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x000000F3 | tsf hi
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | time gp1
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x127F94F2 | time gp2
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000024 | uCode version major
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xCA7B901D | uCode version minor
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000230 | hw version
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x18C89000 | board version
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BAB001C | hcmd
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x26FE2002 | isr0
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x11800000 | isr1
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x0800181A | isr2
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x40417C80 | isr3
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr4
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BAB001C | last cmd Id
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | wait_event
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00004A88 | l2p_control
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00019C24 | l2p_duration
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x000003BF | l2p_mhvalid
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x000000EF | l2p_addr_match
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x0000001D | lmpm_pmg_sel
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x10032209 | timestamp
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x000098B0 | flow_handler
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: Status: 0x00000040, count: 7
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000067 | ADVANCED_SYSASSERT
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | umac branchlink1
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xC008694C | umac branchlink2
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xC0083B0C | umac interruptlink1
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xC0083B0C | umac interruptlink2
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00004000 | umac data1
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xC0083B0C | umac data2
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data3
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000024 | umac major
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xCA7B901D | umac minor
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xC088628C | frame pointer
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xC088628C | stack pointer
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x009C019C | last host cmd
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr status reg
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: Fseq Registers:
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x069D6E40 | FSEQ_ERROR_CODE
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x8435C26D | FSEQ_TOP_INIT_VERSION
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x6A1C004B | FSEQ_CNVIO_INIT_VERSION
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x0000A10B | FSEQ_OTP_VERSION
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0xB86C78AD | FSEQ_TOP_CONTENT_VERSION
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x4A986D6F | FSEQ_ALIVE_TOKEN
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x8B1A5861 | FSEQ_CNVI_ID
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x9E2AB193 | FSEQ_CNVR_ID
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000010 | CNVI_AUX_MISC_CHIP
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BADCAFE | CNVR_AUX_MISC_CHIP
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Okt 19 21:03:01 tux17 kernel: iwlwifi 0000:02:00.0: Collecting data: trigger 2 fired.
Okt 19 21:03:01 tux17 kernel: ieee80211 phy1: Hardware restart was requested
Okt 19 21:03:02 tux17 wpa_supplicant[869]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Okt 19 21:03:02 tux17 wpa_supplicant[869]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-53 noise=9999 txrate=144400
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: Microcode SW error detected. Restarting 0x2000000.
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: Status: 0x00000040, count: 6
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: Loaded firmware version: 36.ca7b901d.0 8265-36.ucode
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000083 | trm_hw_status0
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00024A8C | branchlink2
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0003AC1E | interruptlink1
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00004DD2 | interruptlink2
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | data1
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00001000 | data2
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x03830000 | data3
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x6440A2C0 | beacon time
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xDF8F0D11 | tsf low
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x000000F3 | tsf hi
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | time gp1
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x02720F1F | time gp2
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000024 | uCode version major
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xCA7B901D | uCode version minor
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000230 | hw version
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x18C89000 | board version
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0B58001C | hcmd
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x26FE3000 | isr0
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x11800000 | isr1
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0800181A | isr2
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x40417C80 | isr3
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr4
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0B58001C | last cmd Id
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | wait_event
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00004288 | l2p_control
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00019C24 | l2p_duration
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x000003BF | l2p_mhvalid
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x000000E7 | l2p_addr_match
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0000001D | lmpm_pmg_sel
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x10032209 | timestamp
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000010 | flow_handler
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: Status: 0x00000040, count: 7
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000067 | ADVANCED_SYSASSERT
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | umac branchlink1
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xC008694C | umac branchlink2
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xC0083B0C | umac interruptlink1
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xC0083B0C | umac interruptlink2
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00004000 | umac data1
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xC0083B0C | umac data2
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data3
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000024 | umac major
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xCA7B901D | umac minor
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xC088628C | frame pointer
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xC088628C | stack pointer
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0030014E | last host cmd
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr status reg
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: Fseq Registers:
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x069D6E40 | FSEQ_ERROR_CODE
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x8435C26D | FSEQ_TOP_INIT_VERSION
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x6A1C004B | FSEQ_CNVIO_INIT_VERSION
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0000A10B | FSEQ_OTP_VERSION
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0xB86C78AD | FSEQ_TOP_CONTENT_VERSION
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x4A986D6F | FSEQ_ALIVE_TOKEN
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x8B1A5861 | FSEQ_CNVI_ID
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x9E2AB193 | FSEQ_CNVR_ID
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000010 | CNVI_AUX_MISC_CHIP
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BADCAFE | CNVR_AUX_MISC_CHIP
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Okt 19 21:03:43 tux17 kernel: iwlwifi 0000:02:00.0: Collecting data: trigger 2 fired.
Okt 19 21:03:43 tux17 kernel: ieee80211 phy1: Hardware restart was requested
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Microcode SW error detected. Restarting 0x2000000.
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Status: 0x00000050, count: 6
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Loaded firmware version: 36.ca7b901d.0 8265-36.ucode
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x000000A3 | trm_hw_status0
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00024A8C | branchlink2
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0003AC1E | interruptlink1
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00004DD2 | interruptlink2
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | data1
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00001000 | data2
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x03830000 | data3
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0000DBAB | beacon time
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xDD1F625F | tsf low
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x000000F4 | tsf hi
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | time gp1
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0000DF76 | time gp2
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000024 | uCode version major
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xCA7B901D | uCode version minor
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000230 | hw version
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x18C89000 | board version
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0000001C | hcmd
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x26FE30C0 | isr0
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x11880000 | isr1
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x28201802 | isr2
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x40419180 | isr3
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr4
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x004601D2 | last cmd Id
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | wait_event
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00004A88 | l2p_control
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00019C20 | l2p_duration
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x000001BF | l2p_mhvalid
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x000000E7 | l2p_addr_match
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0000000D | lmpm_pmg_sel
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x10032209 | timestamp
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0F404858 | flow_handler
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Status: 0x00000050, count: 7
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000067 | ADVANCED_SYSASSERT
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | umac branchlink1
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xC008694C | umac branchlink2
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xC0083B0C | umac interruptlink1
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xC0083B0C | umac interruptlink2
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00004000 | umac data1
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xC0083B0C | umac data2
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xDEADBEEF | umac data3
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000024 | umac major
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xCA7B901D | umac minor
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xC088628C | frame pointer
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xC088628C | stack pointer
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x004701A9 | last host cmd
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr status reg
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Fseq Registers:
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x069D6E40 | FSEQ_ERROR_CODE
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x8435C26D | FSEQ_TOP_INIT_VERSION
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x6A1C004B | FSEQ_CNVIO_INIT_VERSION
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0000A10B | FSEQ_OTP_VERSION
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0xB86C78AD | FSEQ_TOP_CONTENT_VERSION
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x4A986D6F | FSEQ_ALIVE_TOKEN
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x8B1A5861 | FSEQ_CNVI_ID
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x9E2AB193 | FSEQ_CNVR_ID
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x00000010 | CNVI_AUX_MISC_CHIP
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BADCAFE | CNVR_AUX_MISC_CHIP
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Firmware error during reconfiguration - reprobe!
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: LED command failed: -5
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: iwlwifi transaction failed, dumping registers
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: iwlwifi device config registers:
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000000: 24fd8086 00100406 02800078 00000010 8e200004 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000020: 00000000 00000000 00000000 10108086 00000000 000000c8 00000000 000001ff
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000040: 00020010 10008ec0 00100c10 0045e811 10110142 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000060: 00000000 00080812 00000405 00000000 00010001 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 000000c0: 00000000 00000000 c823d001 0d000000 00814005 fee00518 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000100: 14010001 00000000 00000000 00462031 00000000 00002000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000140: 14c10003 fffc74c5 f85971ff 15410018 10031003 0001001e 00481e1f 40500000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: iwlwifi device memory mapped registers:
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000000: 18c89000 0000ff40 00000000 ba00008b 00000000 00000000 00000010 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000020: 00000000 08040005 00000230 d55555d5 d55555d5 d55555d5 80008040 041f0042
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: iwlwifi device AER capability structure:
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: 00000000: 14010001 00000000 00000000 00462031 00000000 00002000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: iwlwifi parent port (0000:00:1d.5) config registers:
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000000: a3358086 00100407 060400f0 00810010 00000000 00000000 00020200 200000f0
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000020: 8e208e20 0001fff1 00000000 00000000 00000000 00000040 00000000 001202ff
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000040: 01428010 00008001 00100000 0e724813 70110042 008cb200 01400000 00000008
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000060: 00000000 00000837 00000400 0000000e 00010003 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000080: 00019005 fee00258 00000000 00000000 0000a00d 85551558 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 000000a0: c8030001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 000000c0: 00000000 00000000 00000000 00000000 07001001 00021842 099e0008 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 000000e0: 00630300 00000000 00100016 00000000 00000150 4c000000 01110fb5 82000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000100: 14010001 00000000 00010000 00060011 00000000 00002000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000140: 1501000d 0000000f 00000000 00000000 2201001f 00000406 00000003 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000200: 00000000 00b02800 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: iwlwifi root port (0000:00:1d.5) AER cap structure:
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000000: 14010001 00000000 00010000 00060011 00000000 00002000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:00:1d.5: 00000020: 00000000 00000000 00000000 00000000 00000000 00000000
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: FW error in SYNC CMD MAC_PM_POWER_TABLE
Okt 19 21:03:44 tux17 kernel: CPU: 5 PID: 13905 Comm: kworker/5:3 Tainted: G W OE 5.10.70-1-MANJARO #1
Okt 19 21:03:44 tux17 kernel: Hardware name: TUXEDO N8xxEZ /N8xxEZ , BIOS 1.07.08 10/04/2018
Okt 19 21:03:44 tux17 kernel: Workqueue: events_freezable ieee80211_restart_work [mac80211]
Okt 19 21:03:44 tux17 kernel: Call Trace:
Okt 19 21:03:44 tux17 kernel: dump_stack+0x6b/0x83
Okt 19 21:03:44 tux17 kernel: iwl_trans_pcie_send_hcmd+0x425/0x430 [iwlwifi]
Okt 19 21:03:44 tux17 kernel: ? add_wait_queue_exclusive+0x70/0x70
Okt 19 21:03:44 tux17 kernel: iwl_trans_send_cmd+0x51/0xb0 [iwlwifi]
Okt 19 21:03:44 tux17 kernel: iwl_mvm_send_cmd_pdu+0x5c/0xa0 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: iwl_mvm_power_send_cmd+0x3ae/0x930 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: ? iwl_mvm_power_disable_pm_iterator+0x20/0x20 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: iwl_mvm_power_update_mac+0x14e/0x210 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: iwl_mvm_bss_info_changed+0x3d5/0x710 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: drv_bss_info_changed+0x8c/0x190 [mac80211]
Okt 19 21:03:44 tux17 kernel: ieee80211_reconfig+0xafa/0x1490 [mac80211]
Okt 19 21:03:44 tux17 kernel: ? del_timer_sync+0x67/0xb0
Okt 19 21:03:44 tux17 kernel: ieee80211_restart_work+0xb7/0xe0 [mac80211]
Okt 19 21:03:44 tux17 kernel: process_one_work+0x1ad/0x370
Okt 19 21:03:44 tux17 kernel: worker_thread+0x50/0x3b0
Okt 19 21:03:44 tux17 kernel: ? rescuer_thread+0x380/0x380
Okt 19 21:03:44 tux17 kernel: kthread+0x133/0x150
Okt 19 21:03:44 tux17 kernel: ? kthread_associate_blkcg+0xc0/0xc0
Okt 19 21:03:44 tux17 kernel: ret_from_fork+0x22/0x30
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: failed to update power mode
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: failed to update CQM thresholds
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to send MAC context (action:2): -5
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: set key failed
Okt 19 21:03:44 tux17 kernel: wlp2s0: HW problem - can not stop rx aggregation for dc:15:c8:12:31:ac tid 0
Okt 19 21:03:44 tux17 kernel: wlp2s0: HW problem - can not stop rx aggregation for dc:15:c8:12:31:ac tid 1
Okt 19 21:03:44 tux17 kernel: wlp2s0: HW problem - can not stop rx aggregation for dc:15:c8:12:31:ac tid 2
Okt 19 21:03:44 tux17 kernel: wlp2s0: HW problem - can not stop rx aggregation for dc:15:c8:12:31:ac tid 3
Okt 19 21:03:44 tux17 kernel: wlp2s0: HW problem - can not stop rx aggregation for dc:15:c8:12:31:ac tid 4
Okt 19 21:03:44 tux17 kernel: wlp2s0: HW problem - can not stop rx aggregation for dc:15:c8:12:31:ac tid 5
Okt 19 21:03:44 tux17 kernel: wlp2s0: HW problem - can not stop rx aggregation for dc:15:c8:12:31:ac tid 6
Okt 19 21:03:44 tux17 kernel: wlp2s0: HW problem - can not stop rx aggregation for dc:15:c8:12:31:ac tid 7
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to send quota: -5
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to update quotas after restart (-5)
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to send flush command (-5)
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to disable queue 2 (ret=-5)
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to remove station. Id=2
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed sending remove station
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to send binding (action:3): -5
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: PHY ctxt cmd error. ret=-5
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to remove MAC context: -5
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: mcast filter cmd error. ret=-5
Okt 19 21:03:44 tux17 kernel: wlp2s0: deauthenticating from dc:15:c8:12:31:ac by local choice (Reason: 3=DEAUTH_LEAVING)
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: failed to update MAC f8:59:71:fc:74:c5
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: flush request fail
Okt 19 21:03:44 tux17 kernel: ------------[ cut here ]------------
Okt 19 21:03:44 tux17 kernel: WARNING: CPU: 5 PID: 14910 at drivers/net/wireless/intel/iwlwifi/mvm/mac80211.c:3218 iwl_mvm_mac_sta_state+0x3cc/0x6e0 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: Modules linked in: ccm tun hidp rfcomm xt_MASQUERADE xt_conntrack ipt_REJECT nf_reject_ipv4 xt_tcpudp cmac snd_sof_pci snd_sof_intel_byt algif_hash snd_sof_intel_ipc snd_sof_intel_hda_common algif_skcipher af_alg ip6table_mangle snd_sof_xtensa_dsp snd_sof_intel_hda ip6table_nat snd_sof snd_hda_codec_hdmi ip6table_filter ip6_tables bnep snd_soc_skl snd_hda_codec_realtek snd_soc_hdac_hda snd_hda_ext_core snd_soc_sst_ipc snd_hda_codec_generic snd_soc_sst_dsp iptable_mangle intel_rapl_msr snd_soc_acpi_intel_match intel_rapl_common snd_soc_acpi ledtrig_audio iptable_nat snd_hda_intel nf_nat snd_intel_dspcfg joydev uvcvideo mousedev nf_conntrack soundwire_intel btusb soundwire_generic_allocation videobuf2_vmalloc videobuf2_memops soundwire_cadence btrtl videobuf2_v4l2 btbcm nf_defrag_ipv6 snd_usb_audio x86_pkg_temp_thermal btintel videobuf2_common nf_defrag_ipv4 libcrc32c snd_hda_codec iwlmvm bluetooth snd_usbmidi_lib intel_powerclamp iptable_filter videodev snd_rawmidi coretemp
Okt 19 21:03:44 tux17 kernel: snd_hda_core snd_seq_device bridge ecdh_generic stp snd_hwdep ecc llc mac80211 kvm_intel mc soundwire_bus snd_soc_core libarc4 qrtr iTCO_wdt ns kvm mei_hdcp intel_pmc_bxt iwlwifi ee1004 snd_compress iTCO_vendor_support irqbypass i915 wmi_bmof ac97_bus rapl i2c_algo_bit snd_pcm_dmaengine intel_cstate cfg80211 drm_kms_helper intel_spi_pci snd_pcm intel_uncore cec snd_timer intel_spi intel_gtt snd vfat spi_nor mei_me i2c_i801 syscopyarea r8168(OE) fat pcspkr psmouse mtd soundcore i2c_smbus rfkill mei sysfillrect sysimgblt fb_sys_fops intel_pch_thermal wmi video acpi_pad mac_hid intel_hid sparse_keymap uinput vboxnetflt(OE) vboxnetadp(OE) drm vboxdrv(OE) sg fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_microsoft ff_memless usbhid dm_crypt cbc encrypted_keys dm_mod trusted tpm rng_core rtsx_pci_sdmmc mmc_core crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel crypto_simd cryptd glue_helper serio_raw rtsx_pci xhci_pci
Okt 19 21:03:44 tux17 kernel: CPU: 5 PID: 14910 Comm: kworker/5:2 Tainted: G W OE 5.10.70-1-MANJARO #1
Okt 19 21:03:44 tux17 kernel: Workqueue: events iwl_mvm_reprobe_wk [iwlmvm]
Okt 19 21:03:44 tux17 kernel: RIP: 0010:iwl_mvm_mac_sta_state+0x3cc/0x6e0 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: Code: d2 31 c9 4c 89 e6 48 89 df e8 50 73 00 00 31 d2 4c 89 e6 48 89 df e8 c3 68 02 00 85 c0 74 0d 49 8b 87 b8 00 00 00 a8 08 75 02 <0f> 0b 4c 89 ef 31 db e8 a8 0f 49 d5 e9 cb fd ff ff 0f 0b 49 8b 87
Okt 19 21:03:44 tux17 kernel: RSP: 0018:ffffb2610274b7e8 EFLAGS: 00010246
Okt 19 21:03:44 tux17 kernel: RAX: 0000000000000040 RBX: ffff9da6040d1f28 RCX: 0000000000000000
Okt 19 21:03:44 tux17 kernel: RDX: 0000000000000000 RSI: ffffb2610274b740 RDI: ffff9da611d84018
Okt 19 21:03:44 tux17 kernel: RBP: ffff9da600f3c9e8 R08: ffffb2610274b794 R09: ffff9da6040d1f28
Okt 19 21:03:44 tux17 kernel: R10: 000000000000002c R11: ffffffff976b45f8 R12: ffff9da82e155570
Okt 19 21:03:44 tux17 kernel: R13: ffff9da6040d1f58 R14: 0000000000000004 R15: ffff9da6040d1f20
Okt 19 21:03:44 tux17 kernel: FS: 0000000000000000(0000) GS:ffff9da960d40000(0000) knlGS:0000000000000000
Okt 19 21:03:44 tux17 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Okt 19 21:03:44 tux17 kernel: CR2: 000056422ed4e920 CR3: 00000002fb610005 CR4: 00000000003706e0
Okt 19 21:03:44 tux17 kernel: drv_sta_state+0x7f/0x5a0 [mac80211]
Okt 19 21:03:44 tux17 kernel: sta_info_move_state+0x1b4/0x2b0 [mac80211]
Okt 19 21:03:44 tux17 kernel: __sta_info_destroy_part2+0x144/0x160 [mac80211]
Okt 19 21:03:44 tux17 kernel: __sta_info_flush+0x140/0x1a0 [mac80211]
Okt 19 21:03:44 tux17 kernel: ieee80211_set_disassoc+0xea/0x460 [mac80211]
Okt 19 21:03:44 tux17 kernel: ieee80211_mgd_deauth.cold+0x49/0x1c2 [mac80211]
Okt 19 21:03:44 tux17 kernel: cfg80211_mlme_deauth+0xb5/0x1e0 [cfg80211]
Okt 19 21:03:44 tux17 kernel: cfg80211_mlme_down+0x64/0x80 [cfg80211]
Okt 19 21:03:44 tux17 kernel: cfg80211_disconnect+0x15c/0x220 [cfg80211]
Okt 19 21:03:44 tux17 kernel: cfg80211_netdev_notifier_call+0x134/0x520 [cfg80211]
Okt 19 21:03:44 tux17 kernel: ? __iwl_err.cold+0x25/0x2a [iwlwifi]
Okt 19 21:03:44 tux17 kernel: ? iwl_mvm_mc_iface_iterator+0xdb/0xf0 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: ? iwl_mvm_mac_ctxt_remove+0xf1/0x170 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: ? __iterate_interfaces+0x9f/0x110 [mac80211]
Okt 19 21:03:44 tux17 kernel: ? iwl_mvm_set_tim+0x50/0x50 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: ? rtnl_is_locked+0x11/0x20
Okt 19 21:03:44 tux17 kernel: ? inetdev_event+0x47/0x640
Okt 19 21:03:44 tux17 kernel: ? iwl_mvm_recalc_multicast+0x45/0x70 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: raw_notifier_call_chain+0x44/0x60
Okt 19 21:03:44 tux17 kernel: __dev_close_many+0x5a/0x110
Okt 19 21:03:44 tux17 kernel: dev_close_many+0x91/0x150
Okt 19 21:03:44 tux17 kernel: dev_close+0x7e/0xb0
Okt 19 21:03:44 tux17 kernel: cfg80211_shutdown_all_interfaces+0x71/0xd0 [cfg80211]
Okt 19 21:03:44 tux17 kernel: ieee80211_remove_interfaces+0x5a/0x240 [mac80211]
Okt 19 21:03:44 tux17 kernel: ? synchronize_rcu+0x76/0x80
Okt 19 21:03:44 tux17 kernel: ? rcu_prepare_for_idle+0xb0/0xb0
Okt 19 21:03:44 tux17 kernel: ieee80211_unregister_hw+0x46/0x110 [mac80211]
Okt 19 21:03:44 tux17 kernel: iwl_op_mode_mvm_stop+0x29/0x130 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: iwl_drv_stop+0x34/0x1a0 [iwlwifi]
Okt 19 21:03:44 tux17 kernel: iwl_pci_remove+0x16/0x20 [iwlwifi]
Okt 19 21:03:44 tux17 kernel: pci_device_remove+0x3b/0xa0
Okt 19 21:03:44 tux17 kernel: __device_release_driver+0x17a/0x230
Okt 19 21:03:44 tux17 kernel: device_driver_detach+0x3c/0xa0
Okt 19 21:03:44 tux17 kernel: device_reprobe+0x19/0x90
Okt 19 21:03:44 tux17 kernel: iwl_mvm_reprobe_wk+0x17/0x40 [iwlmvm]
Okt 19 21:03:44 tux17 kernel: ---[ end trace ff0b556f941f50ef ]---
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to remove station. Id=0
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: failed to remove AP station
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: failed to update quotas
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: failed to update MAC f8:59:71:fc:74:c5 (clear after unassoc)
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to disable queue 1 (ret=-5)
Okt 19 21:03:44 tux17 kernel: iwlwifi 0000:02:00.0: Failed to remove station. Id=1
Okt 19 21:03:44 tux17 wpa_supplicant[869]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Okt 19 21:03:44 tux17 wpa_supplicant[869]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=dc:15:c8:12:31:ac reason=3 locally_generated=1
Okt 19 21:03:44 tux17 avahi-daemon[475]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
Okt 19 21:03:44 tux17 avahi-daemon[475]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address 2a02:2455:1e1:e00:9042:b4d9:d0a0:5810.
Okt 19 21:03:44 tux17 avahi-daemon[475]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
Okt 19 21:03:44 tux17 avahi-daemon[475]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.178.24.
Okt 19 21:03:44 tux17 avahi-daemon[475]: Withdrawing address record for 2a02:2455:1e1:e00:9042:b4d9:d0a0:5810 on wlp2s0.
Okt 19 21:03:44 tux17 avahi-daemon[475]: Withdrawing address record for 192.168.178.24 on wlp2s0.
Okt 19 21:03:44 tux17 NetworkManager[478]: <info> [1634670224.7481] device (wlp2s0): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Okt 19 21:03:44 tux17 NetworkManager[478]: <info> [1634670224.7837] dhcp4 (wlp2s0): canceled DHCP transaction
Okt 19 21:03:44 tux17 NetworkManager[478]: <info> [1634670224.7837] dhcp4 (wlp2s0): state changed bound -> terminated
Okt 19 21:03:44 tux17 NetworkManager[478]: <info> [1634670224.7839] dhcp6 (wlp2s0): canceled DHCP transaction
Okt 19 21:03:44 tux17 NetworkManager[478]: <info> [1634670224.7840] dhcp6 (wlp2s0): state changed bound -> terminated
Okt 19 21:03:44 tux17 wpa_supplicant[869]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Okt 19 21:03:44 tux17 wpa_supplicant[869]: Could not read interface p2p-dev-wlp2s0 flags: No such device
thanks for any help
