Wifi is not getting detected suddenly
I am facing a weird issue now – my Wi-Fi and LAN were working fine till yesterday morning. Suddenly, in the morning, my screen went completely black and was not responding. I forced a shutdown of my laptop - Lenovo c340s. Still, this issue was there for some time. Later, the system started working, but my network is not connected, and the network widget in my plasma taskbar shows unknown. At that point, even wired was not detected. I could manage with mobile USB tethering and updated the system to the latest. Still my wifi is not getting detected. Earlier, I used to see a toggling option for flight mode and so on on Plasma network widget. Now it is not showing any such options except a search bar.
uname -r
6.18.49-1-MANJARO
❯ inxi -N
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
  Device-2: Realtek RTL8152 Fast Ethernet Adapter driver: r8152 type: USB
❯ rfkill list
0: ideapad_wlan: Wireless LAN
        Soft blocked: no
        Hard blocked: no
1: ideapad_bluetooth: Bluetooth
        Soft blocked: no
        Hard blocked: no
2: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
❯ lspci -nnk | grep -A3 Net
00:14.3 Network controller [0280]: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] [8086:9df0] (rev 30)
        Subsystem: Intel Corporation Device [8086:0034]
        Kernel driver in use: iwlwifi
        Kernel modules: iwlwifi
❯ inxi -Fazy
  Kernel: 6.18.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=9046f096-701c-4c87-ac8f-07f095764c4c rw rootflags=subvol=@ quiet
    splash resume=UUID=40f2c8c5-bd0d-4e96-961a-526261b7d039
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
    wm: kwin_wayland with: krunner vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Convertible System: LENOVO product: 81N4 v: Lenovo IdeaPad C340-14IWL
    serial: <superuser required> Chassis: type: 31 v: Lenovo IdeaPad C340-14IWL
  Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
    part-nu: LENOVO_MT_81N4_BU_idea_FM_IdeaPad C340-14IWL
    uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: AHCN34WW(V2.11)
    date: 06/18/2021
  ID-1: BAT1 charge: 18.8 Wh (42.2%) condition: 44.4/45.5 Wh (97.5%)
    volts: 15.11 min: 15.36 model: 0x4C 0x47 0x43 0x00 PABAS0241231 type: Li-ion
    serial: <filter> charging: status: discharging type: standard
    avail: long_life,standard cycles: 306
  Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 400 min/max: 400/3900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 28800
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
    class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX230] vendor: Lenovo driver: N/A
    alternate: nouveau, nova_core, nvidia_drm, nvidia non-free: 550-580.xx+
    status: legacy-active (EOL~2028-09-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
    bus-ID: 01:00.0 chip-ID: 10de:1d11 class-ID: 0302
  Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:32 chip-ID: 13d3:56b2
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d4 built: 2016 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
    device-ID: 8086:3ea0 memory: 18.8 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.357 layers: 4 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 620 (WHL GT2) driver: mesa intel v: 26.2.2-arch1.1
    device-ID: 8086:3ea0 surfaces: N/A
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.18.49-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.2:40
    chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u3u2 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:7
  Local Storage: total: 953.87 GiB used: 129.03 GiB (13.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L2
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3L1QEXF7 temp: 39.9 C
    scheme: GPT
  ID-1: / raw-size: 463.59 GiB size: 463.59 GiB (100.00%)
    used: 78.67 GiB (17.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 664 KiB (0.0%)
    fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 244.14 GiB size: 244.14 GiB (100.00%)
    used: 6.33 GiB (2.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-4: /var/log raw-size: 463.59 GiB size: 463.59 GiB (100.00%)
  ID-1: swap-1 type: partition size: 9.77 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:5
  System Temperatures: cpu: 50.0 C pch: 51.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 20 GiB note: est. available: 19.25 GiB used: 4.25 GiB (22.1%)
  Processes: 295 Power: uptime: 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 7.61 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Packages: 2390 pm: dpkg pkgs: 0 pm: pacman pkgs: 2382 libs: 453
    tools: pamac pm: flatpak pkgs: 8 Compilers: clang: 22.1.8 gcc: 16.2.1 alt: 15
    Shell: Zsh v: 5.9.2 default: Bash v: 5.3.15 running-in: konsole
    inxi: 3.3.41
❯ nmcli g
STATE      CONNECTIVITY  WIFI-HW  WIFI     WWAN-HW  WWAN     METERED
connected  full          missing  enabled  missing  enabled  no (guessed)
I was using the 6.12 kernel and installed 6.18 to see if it solved the problem or not. It did not. I tried blacklisting, changing power options on modprobe, and so on. It also did not work.
sudo dmesg | grep iwlwifi | tail -n 20
[sudo] password for sreekanth:
[   18.245861] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[   18.245872] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[   18.245913] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[   18.245933] iwlwifi 0000:00:14.3: 0x8877A4FB | FSEQ_PREV_CNVIO_INIT_VERSION
[   18.245941] iwlwifi 0000:00:14.3: 0x60C4E298 | FSEQ_WIFI_FSEQ_VERSION
[   18.245949] iwlwifi 0000:00:14.3: 0x2F38EF49 | FSEQ_BT_FSEQ_VERSION
[   18.245958] iwlwifi 0000:00:14.3: 0xF3AAAF77 | FSEQ_CLASS_TP_VERSION
[   18.245978] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x3, CPU2 Status: 0x2324
[   18.245997] iwlwifi 0000:00:14.3: WFPM_ARC1_PD_NOTIFICATION: 0x0
[   18.246016] iwlwifi 0000:00:14.3: HPM_SECONDARY_DEVICE_STATE: 0x42
[   18.246029] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[   18.246042] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_DATA: 0x4
[   18.246054] iwlwifi 0000:00:14.3: UMAC PC: 0x804533c8
[   18.246067] iwlwifi 0000:00:14.3: LMAC PC: 0xe8
[   18.246068] iwlwifi 0000:00:14.3: Failed to start INIT ucode: -5
[   18.246070] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   18.710978] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[   18.716123] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=4, type=5
[   18.716128] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=6, type=5
[   18.961423] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -5
I searched the internet and tried resetting by holding the power button for 30 seconds after shutting down the system. I tried with a live usb Manjaro and it did not detect the wifi. I am not sure how to debug the problem now, so I will try to solve it. Any input will be greatly useful.
I’m not sure why dmesg gave Failed to run INIT ucode: -5 error, and nmcli says HW is missing. Not sure how to debug.
Thank you. Please let me know if you need any more details.
Impossible to guess…
This points to either a hardware failue or physical switch.
From the system info provided you card is detected.
rfkill list
Command output?
He had mentioned that in his first post.
As far as I remember, I did not set physical switch off. Is there any way to debug? Some answers in Gemini and some pages suggest the possibility of capacitor - I am not sure of debug that either.
And the rfkill output confirms that you didn’t
A forced shutdown is always dangerous - especially for the file system.
Even though btrfs is resilient to file system errors
Nothing can prevent the loss of data when you force power off.
I don’t know what is causing your issue but I am fairly certain that the unresponsiveness combined with a forced power down has created some inconsistencies.
You may, maybe, be able to repair the system by feeding the currently installed list of native packages back into pacman - but it is a huge maybe - given the nature of btrfs I don’t think you have disk errors - that would have given other issues - I think btrfs simply lost track of the files - and if that is the case the following command may repair that
sudo pacman -Syu $(pacman -Qqn)
Of course that requires the use of your USB network connection strategy :slight_smile:
I will try this. Thank you
Tried that. Yet same issue is persisting.
You really should interrogate the journal from around the time the laptop became unresponsive/black screen. The above snippet will only show the last 20 messages during your current boot not when the error occurred.
It does appear though your card has up and died - particularly if it isn’t working in a live USB booted environment either.
Has your laptop been getting hot recently? Excess temps are one of the most common reasons a wifi card will fail.
Today I tried with a wifi dongle and it is working. So will it be a hardware issue?
Using different hardware doesn’t necessarily mean its a hardware issue with the other card, but what you have said here I highly suspect it is.
I might guess that your Networking has been failing for reasons that (now) it’s unlikely anyone can pin-point.
This may simply have been “the straw that broke the camel’s back”, and it’s difficult to determine what else may have contributed to the problem, in the first place.
A hard shutdown or reset can often be responsible for filesystem damage, and because your system software resides on that filesystem, there are a variety of system processes that can potentially fail as a result.
Often, it may be best to replace rather than repair.
This logic might extend from removing and reinstalling (and reconfiguring) components suspected of being damaged, through to a complete reinstallation of the OS (if the damage cannot be easily identified).
If hardware was affected then replacing the damaged part can obviously be a workable solution; as you have already discovered:
However, while your immediate inconvenience is resolved, other damage might not be, so at least checking the filesystem for inconsistencies might be warranted.
If other indeterminate issues happen to arise in the meantime, a fresh Manjaro install might still be a consideration.
Thank you for your responses. If I am using a live USB Manjaro, it is not detected. Will that behavior change if I install it? (Although I am happy if somebody says there is no hardware issue, we need to just manage it in a software way :wink: - but as it is working with an external dongle, I’m afraid it points to a hardware problem :frowning: Currently it works with an external dongle.
One suggestion I have seen online is to do a complete power off of the device. As you are using a laptop, this may require removing the battery, if possible, for a short while (at least five minutes). For a device that is plugged in to a power outlet, the power should be switched off at the outlet.
Theoretically, this will cause the firmware that is currently on the device’s components to do a full reload upon the next reboot, using the firmware packages installed on your system, and hopefully return functionality to your WiFi card.
The suggestion was in the following post on the Arch forum:
Unfortunately, the link to Lenovo contained in the above post no longer works.
I have seen complete power-offs fix issues related to WiFi or Bluetooth before on this forum. I’ve even done it myself successfully a couple of times after firmware updates temporarily stopped Bluetooth on my mini-PC from working.
I’m not saying that a complete power off will work for you as the issue may indeed be a hardware failure; however it certainly won’t do any harm (and may get your WiFi working again).
This is one of the first things I try with most hardware issues, it’s free and doesn’t take any effort. I do often forget most people don’t automatically do this.
If the hardware is damaged, it is damaged. Period. There is then usually no other resolve than to replace it.
It’s nice to know that would make you happy.
However, that is not what I wrote. The takeaway is that there can be both hardware and filesystem/software damage.
So, irrespective of your emoji, the suggestion is to monitor for any other inconsistencies – signs of other possible damage that may not yet have revealed itself – and be prepared to take action, if necessary.
That no longer seems to be relevant, given that he writes that his Wi-Fi isn’t recognised when using a Live ISO either.
It can be relevant.
As already stated multiple times there is obvious hardware damage – however, there can often be other damage to look out for that isn’t as obvious, as a result of a hard shutdown or reset.
It is prudent to be aware of the possibility.
It looks that way to me. :thinking:
It may be worth getting a replacement Wifi module, which, when I last checked only cost a few £/$/Euro. Be sure to get one of the same type though as there are several “form factors” and also some Lenovo machines have a hardware “whitelist”; a different brand may not work.
Good luck with that
Slight correction: Good luck finding which ones are on that. :roll_eyes:
