It could also indicate a break in the antenna in the hinge of the laptop lid - if it occurs again.
Itβs happening.
But I donβt think itβs a hardware issue since itβs perfectly fine in some boots and causing issues in other boots. There are also no other connection issues.
I suggest testing my idea with a live stick . In this constellations, open lid, close it, open it, close itβ¦and see what happens. You will report ?
Sure, Iβll do that tomorrow morning and let you know. Btw, since Iβm testing hardware issues, itβs okay if I use XFCE instead of KDE, right? (I have one XFCE live image lying around that I made a week or so ago.)
@Manfrago I tried a live usb and it works perfectly. Hereβs my journalctl output around lid closure and opening. Itβs a bit different than was originally posted. I think @D.Dave 's suggestions had some kind of effect.
journalctl -xe -n 1000
Mar 04 15:56:31 sintan-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 15:56:31 sintan-pc kernel: kauditd_printk_skb: 13 callbacks suppressed
Mar 04 15:56:31 sintan-pc kernel: audit: type=1131 audit(1614853591.135:116): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 15:56:31 sintan-pc audit: BPF prog-id=10 op=UNLOAD
Mar 04 15:56:31 sintan-pc audit: BPF prog-id=9 op=UNLOAD
Mar 04 15:56:31 sintan-pc kernel: audit: type=1334 audit(1614853591.244:117): prog-id=10 op=UNLOAD
Mar 04 15:56:31 sintan-pc kernel: audit: type=1334 audit(1614853591.244:118): prog-id=9 op=UNLOAD
Mar 04 15:56:31 sintan-pc dhcpcd[515]: wlo1: no IPv6 Routers available
Mar 04 15:56:31 sintan-pc kdeinit5[2466]: Qt: Session management error: networkIdsList argument is NULL
Mar 04 15:56:36 sintan-pc kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xd8 on isa0060/serio0).
Mar 04 15:56:36 sintan-pc kernel: atkbd serio0: Use 'setkeycodes e058 <keycode>' to make it known.
Mar 04 15:56:36 sintan-pc kernel: atkbd serio0: Unknown key released (translated set 2, code 0xd8 on isa0060/serio0).
Mar 04 15:56:36 sintan-pc systemd-logind[510]: Lid closed.
Mar 04 15:56:37 sintan-pc kscreenlocker_greet[2508]: Qt: Session management error: networkIdsList argument is NULL
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
Mar 04 15:56:38 sintan-pc kernel: wlo1: deauthenticating from 10:be:f5:fe:1e:ee by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 04 15:56:38 sintan-pc wpa_supplicant[618]: wlo1: CTRL-EVENT-DISCONNECTED bssid=10:be:f5:fe:1e:ee reason=3 locally_generated=1
Mar 04 15:56:38 sintan-pc avahi-daemon[501]: Interface wlo1.IPv6 no longer relevant for mDNS.
Mar 04 15:56:38 sintan-pc avahi-daemon[501]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::783a:5845:4bbe:83e8.
Mar 04 15:56:38 sintan-pc dhcpcd[515]: wlo1: carrier lost
Mar 04 15:56:38 sintan-pc wpa_supplicant[618]: rfkill: WLAN soft blocked
Mar 04 15:56:38 sintan-pc avahi-daemon[501]: Interface wlo1.IPv4 no longer relevant for mDNS.
Mar 04 15:56:38 sintan-pc avahi-daemon[501]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.0.2.
Mar 04 15:56:38 sintan-pc avahi-daemon[501]: Withdrawing address record for fe80::a60f:1d73:17d0:3a98 on wlo1.
Mar 04 15:56:38 sintan-pc avahi-daemon[501]: Withdrawing address record for fe80::783a:5845:4bbe:83e8 on wlo1.
Mar 04 15:56:38 sintan-pc avahi-daemon[501]: Withdrawing address record for 192.168.0.2 on wlo1.
Mar 04 15:56:38 sintan-pc NetworkManager[506]: <info> [1614853598.4702] manager: rfkill: Wi-Fi now disabled by radio killswitch
Mar 04 15:56:38 sintan-pc NetworkManager[506]: <info> [1614853598.4705] device (wlo1): state change: activated -> unavailable (reason 'none', sys-iface-state: 'managed')
Mar 04 15:56:38 sintan-pc NetworkManager[506]: <info> [1614853598.4879] dhcp4 (wlo1): canceled DHCP transaction
Mar 04 15:56:38 sintan-pc NetworkManager[506]: <info> [1614853598.4879] dhcp4 (wlo1): state changed bound -> done
Mar 04 15:56:38 sintan-pc dhcpcd[515]: wlo1: deleting address fe80::a60f:1d73:17d0:3a98
Mar 04 15:56:38 sintan-pc dhcpcd[515]: wlo1: deleting route to 192.168.0.0/24
Mar 04 15:56:38 sintan-pc dhcpcd[515]: wlo1: deleting default route via 192.168.0.1
Mar 04 15:56:38 sintan-pc NetworkManager[506]: <info> [1614853598.4922] manager: NetworkManager state is now DISCONNECTED
Mar 04 15:56:38 sintan-pc NetworkManager[506]: <info> [1614853598.5005] device (p2p-dev-wlo1): state change: disconnected -> unavailable (reason 'supplicant-failed', sys-iface-state: 'managed')
Mar 04 15:56:38 sintan-pc wpa_supplicant[618]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
Mar 04 15:56:38 sintan-pc dbus-daemon[505]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.7' (uid=0 pid=506 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 04 15:56:38 sintan-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
ββ Subject: A start job for unit NetworkManager-dispatcher.service has begun execution
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ
ββ A start job for unit NetworkManager-dispatcher.service has begun execution.
ββ
ββ The job identifier is 1965.
Mar 04 15:56:38 sintan-pc kded5[1041]: plasma-nm: Network connectivity limited, scheduling notification
Mar 04 15:56:38 sintan-pc dbus-daemon[505]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 04 15:56:38 sintan-pc systemd[1]: Started Network Manager Script Dispatcher Service.
ββ Subject: A start job for unit NetworkManager-dispatcher.service has finished successfully
ββ
ββ A start job for unit NetworkManager-dispatcher.service has finished successfully.
ββ
Mar 04 15:56:38 sintan-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 15:56:38 sintan-pc kernel: audit: type=1130 audit(1614853598.542:119): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 15:56:38 sintan-pc avahi-daemon[501]: Got SIGHUP, reloading.
Mar 04 15:56:38 sintan-pc avahi-daemon[501]: No service file found in /etc/avahi/services.
Mar 04 15:56:38 sintan-pc wpa_supplicant[618]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
Mar 04 15:56:38 sintan-pc systemd-logind[510]: Lid opened.
Mar 04 15:56:38 sintan-pc kscreenlocker_greet[2508]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/components/KeyboardLayoutButton.qml:17: TypeError: Cannot read property 'longName' of undefined
Mar 04 15:56:43 sintan-pc audit[2609]: USER_AUTH pid=2609 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="sintan" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mar 04 15:56:43 sintan-pc kernel: audit: type=1100 audit(1614853603.111:120): pid=2609 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="sintan" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mar 04 15:56:43 sintan-pc kscreenlocker_greet[2508]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:27: TypeError: Cannot read property 'width' of null
Mar 04 15:56:43 sintan-pc kscreenlocker_greet[2508]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:45: TypeError: Cannot read property 'height' of null
Mar 04 15:56:43 sintan-pc kwin_x11[1045]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23314, resource id: 157286458, major code: 18 (ChangeProperty), minor code: 0
Mar 04 15:56:43 sintan-pc appimagelauncherd[947]: Directories to watch disappeared, unintegrating AppImages formerly found in there
Mar 04 15:56:43 sintan-pc kwin_x11[1045]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24074, resource id: 44040378, major code: 20 (GetProperty), minor code: 0
Mar 04 15:56:43 sintan-pc kwin_x11[1045]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24075, resource id: 44040378, major code: 15 (QueryTree), minor code: 0
Mar 04 15:56:46 sintan-pc systemd[939]: Started st.
And this is the output of the same from a boot where this isnβt happening.
Mar 04 16:02:36 sintan-pc kernel: atkbd serio0: Unknown key released (translated set 2, code 0xd8 on isa0060/serio0).
Mar 04 16:02:36 sintan-pc kernel: atkbd serio0: Use 'setkeycodes e058 <keycode>' to make it known.
Mar 04 16:02:36 sintan-pc systemd-logind[496]: Lid closed.
Mar 04 16:02:36 sintan-pc appimagelauncherd[936]: Done
Mar 04 16:02:36 sintan-pc kscreenlocker_greet[2440]: Qt: Session management error: networkIdsList argument is NULL
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:37 sintan-pc systemd-logind[496]: Lid opened.
Mar 04 16:02:37 sintan-pc systemd[1]: systemd-hostnamed.service: Succeeded.
ββ Subject: Unit succeeded
ββ
ββ The unit systemd-hostnamed.service has successfully entered the 'dead' state.
Mar 04 16:02:37 sintan-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 16:02:37 sintan-pc kernel: audit: type=1131 audit(1614853957.727:107): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 16:02:37 sintan-pc systemd-timesyncd[482]: Initial synchronization to time server 192.46.210.39:123 (2.manjaro.pool.ntp.org).
Mar 04 16:02:37 sintan-pc kscreenlocker_greet[2440]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/components/KeyboardLayoutButton.qml:17: TypeError: Cannot read property 'longName' of undefined
Mar 04 16:02:37 sintan-pc audit: BPF prog-id=10 op=UNLOAD
Mar 04 16:02:37 sintan-pc audit: BPF prog-id=9 op=UNLOAD
Mar 04 16:02:37 sintan-pc kernel: audit: type=1334 audit(1614853957.219:108): prog-id=10 op=UNLOAD
Mar 04 16:02:37 sintan-pc kernel: audit: type=1334 audit(1614853957.219:109): prog-id=9 op=UNLOAD
Mar 04 16:02:41 sintan-pc audit[2502]: USER_AUTH pid=2502 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="sintan" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mar 04 16:02:41 sintan-pc kernel: audit: type=1100 audit(1614853961.606:110): pid=2502 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="sintan" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mar 04 16:02:41 sintan-pc kscreenlocker_greet[2440]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:27: TypeError: Cannot read property 'width' of null
Mar 04 16:02:41 sintan-pc kscreenlocker_greet[2440]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:45: TypeError: Cannot read property 'height' of null
Mar 04 16:02:41 sintan-pc kwin_x11[1034]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18946, resource id: 167772218, major code: 18 (ChangeProperty), minor code: 0
Mar 04 16:02:47 sintan-pc kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xd8 on isa0060/serio0).
Mar 04 16:02:47 sintan-pc kernel: atkbd serio0: Use 'setkeycodes e058 <keycode>' to make it known.
Mar 04 16:02:47 sintan-pc kernel: atkbd serio0: Unknown key released (translated set 2, code 0xd8 on isa0060/serio0).
Mar 04 16:02:47 sintan-pc systemd-logind[496]: Lid closed.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: Qt: Session management error: networkIdsList argument is NULL
Mar 04 16:02:48 sintan-pc systemd-logind[496]: Lid opened.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
Mar 04 16:02:48 sintan-pc kscreenlocker_greet[2504]: qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
I have the same problem.
Maybe create a new issue mentioning this? As this is an old issue, it probably wonβt receive much attention.
Is it okay to create multiple threads for the same problem in this forum? Iβm unsure about that, so posted here.
