Whenever I turn on my laptop from sleep (i.e. I close the lid, and later open the lid), WiFi is disabled, and I need to press the function key twice to turn on the WiFi.
This does not happed when waking up from suspend (even if I close the lid when the laptop is in suspend mode).
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=067bb185-2ee6-4461-8d00-69086fb7fed6 rw quiet udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel, vala-panel wm: xfwm4
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP 250 G5 Notebook PC
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 81EB v: 61.41 serial: <filter> UEFI: Insyde v: F.24
date: 01/05/2017
ID-1: BAT1 charge: 32.1 Wh (100.0%) condition: 32.1/32.1 Wh (100.0%)
volts: 16.6 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Full
RAM: total: 3.73 GiB used: 2.89 GiB (77.3%)
Info: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: E2 cache:
L2: 3 MiB bogomips: 16006
Speed: 501 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 501 2: 500 3: 500
4: 500
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Chicony HP TrueVision HD type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 04f2:b56c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: eDP1 res: 1600x900 hz: 60 dpi: 120 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
bus-ID: 1-4:2 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 931.51 GiB used: 514.93 GiB (55.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
rotation: 5400 rpm serial: <filter> rev: 4C scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW GUD1N rev: MD00 dev-links: cdrom
ID-1: / raw-size: 51.76 GiB size: 50.64 GiB (97.85%) used: 32.02 GiB (63.2%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 067bb185-2ee6-4461-8d00-69086fb7fed6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 100.9 MiB (39.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: DAA7-28F1
ID-3: /home raw-size: 22.98 GiB size: 22.45 GiB (97.70%)
used: 2.27 GiB (10.1%) fs: ext4 dev: /dev/sda9 maj-min: 8:9 label: N/A
uuid: e9f5c454-28c8-46b9-9160-97f9fcaf28ff
ID-4: /run/media/archisman/Store raw-size: 674.65 GiB
size: 674.65 GiB (100.00%) used: 480.53 GiB (71.2%) fs: ntfs dev: /dev/sda4
maj-min: 8:4 label: Store uuid: 01D30BC133BF3900
ID-1: swap-1 type: zram size: 2 GiB used: 308.5 MiB (15.1%) priority: 5
dev: /dev/zram0
ID-1: /dev/sda10 maj-min: 8:10 size: 68.36 GiB fs: ext4 label: N/A
uuid: c69fac7e-e0ba-4d3e-8923-7b7d799496ff
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 99.55 GiB fs: ntfs label: Windows
uuid: 70C06E16C06DE338
ID-4: /dev/sda6 maj-min: 8:6 size: 980 MiB fs: ntfs label: Windows RE tools
uuid: E26C282D6C27FB45
ID-5: /dev/sda7 maj-min: 8:7 size: 12.98 GiB fs: ntfs label: RECOVERY
uuid: 1840ED4740ED2C66
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-4:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-5:3 info: Chicony HP TrueVision HD type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b56c
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 38.0 C mobo: 29.8 C
Processes: 221 Uptime: 2d 13h 03m wakeups: 13 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1555
lib: 327 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
How to change this behavior?
Expected behavior
If the WiFi was turned on before closing the lid, it should be turned on afterwards.
If the WiFi was turned off before closing the lid, it should remain turned off afterwards.
Right now, it is always turned off after closing the lid.
Please let me know if I need to provide any other information.
