Hello, recently i updated my system, and after reboot wifi stopped working properly.
It connects to the network, works for ~30 seconds, then drops the connection and reconnects again, same thing happens. Tried switching networkmanager’s backend to iwd - did not help either.
Here’s my inxi output:
Kernel: 6.18.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.18-x86_64
root=UUID=0abc5eab-b861-4568-8213-3c6f060ac31c rw quiet apparmor=1
security=apparmor udev.log_priority=3 rootfstype=ext4 mitigations=off
split_lock_detect=off
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Type: Laptop System: Dell product: Vostro 3558 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0PPH4M v: A00 serial: <superuser required> part-nu: 06C1
uuid: <superuser required> Firmware: UEFI vendor: Dell v: A15
date: 05/14/2019
ID-1: BAT0 charge: 1.5 Wh (100%) condition: 1.5/41.4 Wh (3.6%)
alert: bad battery? volts: 16.27 min: 14.8 model: LGC DELL 991XP6CA6CA
type: Li-ion serial: <filter> charging: status: full control: start: 50%
end: 90% type: adaptive avail: adaptive,custom,standard,trickle cycles: N/A
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1896 min/max: 500/1900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1896 2: 1896 3: 1896 4: 1896 bogomips: 15963
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: itlb_multihit status: KVM: Vulnerable
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
Type: srbds status: Vulnerable
Type: vmscape status: Vulnerable
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Microdia Integrated Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-5:4 chip-ID: 0c45:6710
class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0620 built: 2014 res: mode: 1366x768
hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
device-ID: 8086:1616 memory: 3.64 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 2 device: 0 type: integrated-gpu name: Intel
HD Graphics 5500 (BDW GT2) driver: mesa intel v: 25.3.2-arch1.1
device-ID: 8086:1616 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
API: ALSA v: k6.18.3-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.9 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 17.0-98-gb096 status: active with:
tools: pacat,pactl
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 06:00.0 chip-ID: 168c:0036 class-ID: 0280
vendor: Dell driver: r8168 v: 8.055.00 modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-6:7 chip-ID: 0cf3:e005
class-ID: e001
Local Storage: total: 238.47 GiB used: 100.21 GiB (42.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: DEXP model: SSD C100 256Gb
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 8A0 scheme: GPT
ID-1: / raw-size: 237.97 GiB size: 233.68 GiB (98.20%)
used: 100.01 GiB (42.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 205.2 MiB (40.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 40 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 4 GiB used: 16 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 46.0 C mobo: N/A sodimm: 35.0 C
Fan Speeds (rpm): cpu: 0 fan-2: 0 fan-3: 0 fan-4: 0
Memory: total: 4 GiB available: 3.73 GiB used: 2.54 GiB (68.1%)
Processes: 206 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.48 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 258 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1988 libs: 496 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.3.9
running-in: konsole inxi: 3.3.40
I also tried switching kernels, no luck.
Tried booting into LiveCD latest manjaro build - issue persists
Then i tried another’s distro LiveCD (endevaour) and wifi worked fine. So i’m pretty sure this is a Manjaro bug
pobrn
12 January 2026 21:23
2
You’re using a release candidate kernel, having bugs is not too surprising there.
Or it has to do with the kernel. Did you check which one uses which version?
journalctl -f logs
янв 13 00:22:31 elenp-vostro kernel: wlan0: associate with 48:22:54:81:cb:03 (try 2/3)
янв 13 00:22:32 elenp-vostro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
янв 13 00:22:32 elenp-vostro kernel: wlan0: associate with 48:22:54:81:cb:03 (try 3/3)
янв 13 00:22:32 elenp-vostro kernel: wlan0: association with 48:22:54:81:cb:03 timed out
янв 13 00:22:32 elenp-vostro wpa_supplicant[655]: wlan0: Added BSSID 48:22:54:81:cb:03 into ignore list, ignoring for 10 seconds
янв 13 00:22:32 elenp-vostro NetworkManager[619]: <info> [1768252952.3010] device (wlan0): supplicant interface state: associating -> disconnected
янв 13 00:22:32 elenp-vostro NetworkManager[619]: <info> [1768252952.3011] device (p2p-dev-wlan0): supplicant management interface state: associating -> disconnected
янв 13 00:22:32 elenp-vostro NetworkManager[619]: <info> [1768252952.7992] device (wlan0): supplicant interface state: disconnected -> scanning
янв 13 00:22:32 elenp-vostro NetworkManager[619]: <info> [1768252952.7992] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
янв 13 00:22:33 elenp-vostro wpa_supplicant[655]: wlan0: Removed BSSID 48:22:54:81:cb:03 from ignore list (clear)
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.6733] dhcp4 (wlan0): state changed no lease
янв 13 00:22:44 elenp-vostro avahi-daemon[620]: Withdrawing address record for 192.168.0.161 on wlan0.
янв 13 00:22:44 elenp-vostro avahi-daemon[620]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.161.
янв 13 00:22:44 elenp-vostro avahi-daemon[620]: Interface wlan0.IPv4 no longer relevant for mDNS.
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <warn> [1768252964.7261] device (wlan0): link timed out.
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7265] device (wlan0): state change: activated -> failed (reason 'supplicant-timeout', managed-type: 'full')
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7269] manager: NetworkManager state is now DISCONNECTED
янв 13 00:22:44 elenp-vostro avahi-daemon[620]: Interface wlan0.IPv6 no longer relevant for mDNS.
янв 13 00:22:44 elenp-vostro avahi-daemon[620]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::c5ce:f5b:3bd:49ac.
янв 13 00:22:44 elenp-vostro avahi-daemon[620]: Withdrawing address record for fe80::c5ce:f5b:3bd:49ac on wlan0.
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7565] device (wlan0): set-hw-addr: set MAC address to 8A:F8:98:B3:DD:1F (scanning)
янв 13 00:22:44 elenp-vostro avahi-daemon[620]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::c5ce:f5b:3bd:49ac.
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <warn> [1768252964.7717] device (wlan0): Activation: failed for connection 'len17a'
янв 13 00:22:44 elenp-vostro avahi-daemon[620]: New relevant interface wlan0.IPv6 for mDNS.
янв 13 00:22:44 elenp-vostro avahi-daemon[620]: Registering new address record for fe80::c5ce:f5b:3bd:49ac on wlan0.*.
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7729] device (wlan0): supplicant interface state: scanning -> interface_disabled
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7730] device (p2p-dev-wlan0): supplicant management interface state: scanning -> interface_disabled
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7741] device (wlan0): state change: failed -> disconnected (reason 'none', managed-type: 'full')
янв 13 00:22:44 elenp-vostro systemd[1]: Starting Network Manager Script Dispatcher Service...
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7859] dhcp4 (wlan0): canceled DHCP transaction
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7860] dhcp4 (wlan0): state changed no lease
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7935] device (wlan0): supplicant interface state: interface_disabled -> scanning
янв 13 00:22:44 elenp-vostro NetworkManager[619]: <info> [1768252964.7936] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> scanning
янв 13 00:22:44 elenp-vostro systemd[1]: Started Network Manager Script Dispatcher Service.
янв 13 00:22:45 elenp-vostro NetworkManager[619]: <info> [1768252965.8195] device (wlan0): supplicant interface state: scanning -> disconnected
янв 13 00:22:45 elenp-vostro NetworkManager[619]: <info> [1768252965.8195] device (p2p-dev-wlan0): supplicant management interface state: scanning -> disconnected
янв 13 00:22:46 elenp-vostro NetworkManager[619]: <info> [1768252966.8240] device (wlan0): supplicant interface state: disconnected -> inactive
янв 13 00:22:46 elenp-vostro NetworkManager[619]: <info> [1768252966.8241] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> inactive
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0374] policy: auto-activating connection 'len17a' (0291e336-58c8-4166-b7f5-97785afdbfcc)
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0382] device (wlan0): Activation: starting connection 'len17a' (0291e336-58c8-4166-b7f5-97785afdbfcc)
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0383] device (wlan0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0386] manager: NetworkManager state is now CONNECTING
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0707] device (wlan0): set-hw-addr: reset MAC address to A8:6B:AD:35:1D:67 (preserve)
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0835] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full')
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0838] device (wlan0): Activation: (wifi) access point 'len17a' has security, but secrets are required.
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0838] device (wlan0): state change: config -> need-auth (reason 'none', managed-type: 'full')
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0840] sup-iface[0ede56838ddeec58,1,wlan0]: wps: type pbc start...
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0846] device (wlan0): supplicant interface state: inactive -> interface_disabled
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0847] device (p2p-dev-wlan0): supplicant management interface state: inactive -> interface_disabled
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.0996] device (wlan0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1001] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full')
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1009] device (wlan0): Activation: (wifi) connection 'len17a' has security, and secrets exist. No new secrets needed.
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1010] Config: added 'ssid' value 'len17a'
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1010] Config: added 'scan_ssid' value '1'
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1010] Config: added 'bgscan' value 'simple:30:-70:86400'
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1010] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1010] Config: added 'auth_alg' value 'OPEN'
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1010] Config: added 'psk' value '<hidden>'
янв 13 00:22:48 elenp-vostro wpa_supplicant[655]: wlan0: WPS-CANCEL
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1065] device (wlan0): supplicant interface state: interface_disabled -> inactive
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1065] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
янв 13 00:22:48 elenp-vostro wpa_supplicant[655]: MBO: Disable MBO/OCE due to misbehaving AP not having enabled PMF
янв 13 00:22:48 elenp-vostro wpa_supplicant[655]: wlan0: SME: Trying to authenticate with 48:22:54:81:cb:03 (SSID='len17a' freq=2457 MHz)
янв 13 00:22:48 elenp-vostro kernel: wlan0: authenticate with 48:22:54:81:cb:03
янв 13 00:22:48 elenp-vostro kernel: wlan0: 80 MHz not supported, disabling VHT
янв 13 00:22:48 elenp-vostro kernel: wlan0: send auth to 48:22:54:81:cb:03 (try 1/3)
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1293] device (wlan0): supplicant interface state: inactive -> authenticating
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1293] device (p2p-dev-wlan0): supplicant management interface state: inactive -> authenticating
янв 13 00:22:48 elenp-vostro wpa_supplicant[655]: wlan0: Trying to associate with 48:22:54:81:cb:03 (SSID='len17a' freq=2457 MHz)
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1418] device (wlan0): supplicant interface state: authenticating -> associating
янв 13 00:22:48 elenp-vostro NetworkManager[619]: <info> [1768252968.1418] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
янв 13 00:22:48 elenp-vostro kernel: wlan0: authenticated
янв 13 00:22:48 elenp-vostro kernel: wlan0: associate with 48:22:54:81:cb:03 (try 1/3)
янв 13 00:22:49 elenp-vostro kernel: wlan0: associate with 48:22:54:81:cb:03 (try 2/3)
янв 13 00:22:49 elenp-vostro kernel: wlan0: associate with 48:22:54:81:cb:03 (try 3/3)
янв 13 00:22:49 elenp-vostro kernel: wlan0: association with 48:22:54:81:cb:03 timed out
янв 13 00:22:49 elenp-vostro wpa_supplicant[655]: wlan0: Added BSSID 48:22:54:81:cb:03 into ignore list, ignoring for 10 seconds
янв 13 00:22:49 elenp-vostro NetworkManager[619]: <info> [1768252969.7275] device (wlan0): supplicant interface state: associating -> disconnected
янв 13 00:22:49 elenp-vostro NetworkManager[619]: <info> [1768252969.7275] device (p2p-dev-wlan0): supplicant management interface state: associating -> disconnected
янв 13 00:22:50 elenp-vostro NetworkManager[619]: <info> [1768252970.7265] device (wlan0): supplicant interface state: disconnected -> scanning
янв 13 00:22:50 elenp-vostro NetworkManager[619]: <info> [1768252970.7266] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
янв 13 00:22:51 elenp-vostro wpa_supplicant[655]: wlan0: Removed BSSID 48:22:54:81:cb:03 from ignore list (clear)
янв 13 00:22:54 elenp-vostro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
янв 13 00:23:09 elenp-vostro wpa_supplicant[655]: MBO: Disable MBO/OCE due to misbehaving AP not having enabled PMF
янв 13 00:23:09 elenp-vostro wpa_supplicant[655]: wlan0: SME: Trying to authenticate with 48:22:54:81:cb:03 (SSID='len17a' freq=2457 MHz)
янв 13 00:23:09 elenp-vostro kernel: wlan0: authenticate with 48:22:54:81:cb:03
янв 13 00:23:09 elenp-vostro kernel: wlan0: 80 MHz not supported, disabling VHT
янв 13 00:23:09 elenp-vostro kernel: wlan0: send auth to 48:22:54:81:cb:03 (try 1/3)
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.7763] device (wlan0): supplicant interface state: scanning -> authenticating
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.7764] device (p2p-dev-wlan0): supplicant management interface state: scanning -> authenticating
янв 13 00:23:09 elenp-vostro wpa_supplicant[655]: wlan0: Trying to associate with 48:22:54:81:cb:03 (SSID='len17a' freq=2457 MHz)
янв 13 00:23:09 elenp-vostro kernel: wlan0: authenticated
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.7795] device (wlan0): supplicant interface state: authenticating -> associating
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.7795] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
янв 13 00:23:09 elenp-vostro kernel: wlan0: associate with 48:22:54:81:cb:03 (try 1/3)
янв 13 00:23:09 elenp-vostro wpa_supplicant[655]: wlan0: Associated with 48:22:54:81:cb:03
янв 13 00:23:09 elenp-vostro wpa_supplicant[655]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
янв 13 00:23:09 elenp-vostro kernel: wlan0: RX AssocResp from 48:22:54:81:cb:03 (capab=0x1431 status=0 aid=131)
янв 13 00:23:09 elenp-vostro kernel: wlan0: associated
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.7902] device (wlan0): supplicant interface state: associating -> associated
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.7903] device (p2p-dev-wlan0): supplicant management interface state: associating -> associated
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.8003] device (wlan0): supplicant interface state: associated -> 4way_handshake
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.8003] device (p2p-dev-wlan0): supplicant management interface state: associated -> 4way_handshake
янв 13 00:23:09 elenp-vostro wpa_supplicant[655]: wlan0: WPA: Key negotiation completed with 48:22:54:81:cb:03 [PTK=CCMP GTK=TKIP]
янв 13 00:23:09 elenp-vostro wpa_supplicant[655]: wlan0: CTRL-EVENT-CONNECTED - Connection to 48:22:54:81:cb:03 completed [id=0 id_str=]
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.8440] device (wlan0): supplicant interface state: 4way_handshake -> completed
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.8440] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "len17a"
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.8441] device (p2p-dev-wlan0): supplicant management interface state: 4way_handshake -> completed
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.8443] device (wlan0): state change: config -> ip-config (reason 'none', managed-type: 'full')
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.8457] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
янв 13 00:23:09 elenp-vostro avahi-daemon[620]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::c5ce:f5b:3bd:49ac.
янв 13 00:23:09 elenp-vostro avahi-daemon[620]: New relevant interface wlan0.IPv6 for mDNS.
янв 13 00:23:09 elenp-vostro avahi-daemon[620]: Registering new address record for fe80::c5ce:f5b:3bd:49ac on wlan0.*.
янв 13 00:23:09 elenp-vostro NetworkManager[619]: <info> [1768252989.8519] dhcp4 (wlan0): state changed new lease, address=192.168.0.161, acd pending
янв 13 00:23:10 elenp-vostro NetworkManager[619]: <info> [1768252990.0059] dhcp4 (wlan0): state changed new lease, address=192.168.0.161
янв 13 00:23:10 elenp-vostro avahi-daemon[620]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.161.
янв 13 00:23:10 elenp-vostro avahi-daemon[620]: New relevant interface wlan0.IPv4 for mDNS.
янв 13 00:23:10 elenp-vostro avahi-daemon[620]: Registering new address record for 192.168.0.161 on wlan0.IPv4.
янв 13 00:23:10 elenp-vostro NetworkManager[619]: <info> [1768252990.0071] policy: set 'len17a' (wlan0) as default for IPv4 routing and DNS
янв 13 00:23:10 elenp-vostro NetworkManager[619]: <info> [1768252990.0170] device (wlan0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
янв 13 00:23:10 elenp-vostro systemd[1]: Starting Network Manager Script Dispatcher Service...
янв 13 00:23:10 elenp-vostro systemd[1]: Started Network Manager Script Dispatcher Service.
янв 13 00:23:10 elenp-vostro NetworkManager[619]: <info> [1768252990.0644] device (wlan0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
янв 13 00:23:10 elenp-vostro NetworkManager[619]: <info> [1768252990.0646] device (wlan0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
янв 13 00:23:10 elenp-vostro NetworkManager[619]: <info> [1768252990.0652] manager: NetworkManager state is now CONNECTED_SITE
янв 13 00:23:10 elenp-vostro NetworkManager[619]: <info> [1768252990.0659] device (wlan0): Activation: successful, device activated.
янв 13 00:23:10 elenp-vostro wpa_supplicant[655]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-43 noise=-88 txrate=121500
янв 13 00:23:10 elenp-vostro kded6[1326]: Failed to notify "Created too many similar notifications in quick succession"
янв 13 00:23:10 elenp-vostro NetworkManager[619]: <info> [1768252990.2742] manager: NetworkManager state is now CONNECTED_GLOBAL
янв 13 00:23:20 elenp-vostro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Well, i tried 6.18, 6.12, 6.6, 5.15, none of them work. So i assume this is not a kernel bug.
Can’t remember Manjaro’s LiveCD kernel version, but Endevaour was on 6.17.8
Information only:
Kernel 6.17 has reached EOL – no matter which OS is used.
The latest Manjaro ISOs are equipped with kernel 6.18 (LTS).
Hint : When you download one of the official Manjaro ISOs, you’ll find that the kernel version forms part of the ISO filename.
it was manjaro-kde-26.0-260104-linux618.iso
I found your Qualcomm Atheros QCA9565 on the Linux Hardware Database – it shows that your device is supported by the ath9k module in kernels 3.17 through 6.18 (LTS).
What this infers is that that kernel 6.19.xx release candidate should probably be avoided (even though it may likely still support the device).
I’d suggest firstly reverting to kernel 6.18 (LTS) in any case, as using a release-candidate kernel will generally not enhance your troubleshooting efforts.
Once that’s done, the system will again be in a supported state, and others might be able to more easily identify any contributors to the issue.
Edit:- Please also edit your previous post and update your inxi output once you have re-installed kernel 6.18 (LTS).
There is a list of open issues
I noticed an update to linux-firmware-atheros just this morning on unstable branch.
$ ls /var/cache/pacman/pkg/linux-firmware-atheros*.zst
/var/cache/pacman/pkg/linux-firmware-atheros-20251111-1-any.pkg.tar.zst
/var/cache/pacman/pkg/linux-firmware-atheros-20251125-1-any.pkg.tar.zst
/var/cache/pacman/pkg/linux-firmware-atheros-20251125-2-any.pkg.tar.zst
/var/cache/pacman/pkg/linux-firmware-atheros-20260110-1-any.pkg.tar.zst
My thinkpad uses a QCNFA765 wifi card, never any issues, I just realised that my card uses ath11k driver
$ inxi -Nxxx
Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: ath11k_pci v: kernel pcie: speed: 8 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 17cb:1103 class-ID: 0280
You are welcome to verify how the kernel is built…
Manjaro Linux GitLab
Your log show a lot of IPv6 related activity.
Have you tried disabling IPv6 - it can be done in Network Manager on the IPv6 tab
