Kernel: 7.2.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.2-x86_64
root=UUID=9911c2cd-3714-4bc5-92cf-cd7d98e17a58 rw rootflags=subvol=@
quiet splash apparmor=1 security=apparmor udev.log_priority=3
intel_iommu=on
Desktop: GNOME v: 50.4 tk: GTK v: 3.24.52 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 50.3 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Dell product: XPS 13 9310 v: N/A
Mobo: Dell model: 0MRT12 v: A00 serial: <superuser required> part-nu: 0991
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 3.37.0
date: 05/25/2026
ID-1: BAT0 charge: 37.2 Wh (93.8%) condition: 39.7/51 Wh (77.9%)
health: good temp: 27.5 C volts: 7.72 min: 7.6 model: SMP DELL WN0N012
made: 2021-02-26 type: Li-poly serial: <filter> charging:
status: not charging control: start: 50% end: 90% type: custom
avail: adaptive,custom,fast,standard,trickle cycles: N/A
System RAM: total: 32 GiB available: 31.06 GiB used: 8.9 GiB (28.7%)
Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
max-module-size: 4 GiB note: est.
Device-1: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
speed: 4267 MT/s volts: curr: 0.6 width (bits): data: 16 total: 16
manufacturer: N/A part-no: N/A serial: N/A
Device-2: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
Device-3: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
Device-4: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
Device-5: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
Device-6: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
Device-7: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
Device-8: Motherboard type: LPDDR4 detail: synchronous size: 4 GiB
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xBE
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1147 min/max: 400/3000 scaling: driver: intel_pstate
governor: powersave cores: 1: 1147 2: 1147 3: 1147 4: 1147 5: 1147 6: 1147
7: 1147 8: 1147 bogomips: 47923
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: indirect_target_selection mitigation: Aligned branch/return thunks
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: vmscape status: Not affected
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: DP-5,DP-6 off: eDP-1 empty: DP-1, DP-2,
DP-3, DP-4, DP-7, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: DP-5 model: Lenovo G27qe-20 serial: <filter> built: 2022
res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.671 y: 0.325 green:
x: 0.294 y: 0.627 blue: x: 0.141 y: 0.051 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
640x480, 720x400
Monitor-2: DP-6 model: Lenovo G27qe-20 serial: <filter> built: 2022
640x480, 720x400
Monitor-3: eDP-1 model: Sharp 0x14fa built: 2020 res: 3840x2400 dpi: 339
gamma: 1.2 chroma: red: x: 0.663 y: 0.322 green: x: 0.286 y: 0.631 blue:
x: 0.149 y: 0.051 white: x: 0.314 y: 0.329 size: 288x180mm (11.34x7.09")
diag: 340mm (13.4") ratio: 16:10 modes: 3840x2400
drv: iris x11: drv: iris
API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.2-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 30.33 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Intel 500 Series Family On-Package High Definition Audio
vendor: Dell driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
API: ALSA v: k7.2.3-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
Device-1: Qualcomm QCA6390 Wireless Network Adapter vendor: Rivet Networks
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 72:00.0 chip-ID: 17cb:1101 class-ID: 0280
IF: wlp114s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.4:4
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s13f0u3u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-d1d778d50376 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth15ea097 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: veth3b0597b state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth62f5948 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth75afc59 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: veth7a5d0b7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: virbr0 state: down mac: <filter>
Info: services: apache2, NetworkManager, sshd, systemd-timesyncd,
wpa_supplicant
Local Storage: total: 953.87 GiB used: 292.61 GiB (30.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: KXG60ZNV1T02 NVMe
1024GB size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 10604107
temp: 36.9 C scheme: GPT
ID-1: / raw-size: 250 GiB size: 250 GiB (100.00%) used: 194.75 GiB (77.9%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 9911c2cd-3714-4bc5-92cf-cd7d98e17a58
ID-2: /boot/efi raw-size: 500 MiB size: 496 MiB (99.20%)
used: 111.1 MiB (22.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: F8A5-9CAB
ID-3: /mnt/daten raw-size: 244.33 GiB size: 244.33 GiB (100.00%)
used: 97.75 GiB (40.0%) fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
label: Daten uuid: 0d3b4dd6-e1ba-4c32-ac2f-f2faf061e945
ID-1: swap-1 type: partition size: 33.2 GiB used: 0 KiB (0.0%)
priority: -1 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: cc542564-aeb1-4ce7-a998-20a224039cdc
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 244.14 GiB fs: ntfs label: N/A
uuid: 0E4C91B64C919953
ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 1.2 GiB fs: ntfs
label: WINRETOOLS uuid: 76F671D3F6719459
ID-4: /dev/nvme0n1p7 maj-min: 259:7 size: 10.68 GiB fs: ntfs label: Image
uuid: D8B6AB9AB6AB77A0
ID-5: /dev/nvme0n1p8 maj-min: 259:8 size: 1.41 GiB fs: ntfs
label: DELLSUPPORT uuid: C460AD6060AD59C6
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 2-3:2 info: Realtek Dell dock ports: 4 rev: 3.1
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 0bda:0487
Hub-4: 2-3.3:3 info: Realtek Dell dock ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0413
Device-1: 2-3.4:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:533c class-ID: ff00
Hub-6: 3-4:3 info: Realtek Dell dock ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5487
Hub-7: 3-4.3:4 info: Realtek Dell dock ports: 6 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5413
Device-1: 3-4.3.2:6 info: CHERRY Corded Device type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046a:c098 class-ID: 0300
Device-2: 3-4.3.3:7 info: Logitech G303 Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c080 class-ID: 0300
serial: <filter>
Device-3: 3-4.3.5:8 info: Dell dock type: HID driver: hid-generic,usbhid
power: 100mA chip-ID: 413c:b06f class-ID: 0300 serial: <filter>
Device-4: 3-4.5:5 info: Dell Dock WD19S type: HID,billboard
chip-ID: 413c:b06e class-ID: 1100 serial: <filter>
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 42.0 C mobo: 41.0 C sodimm: 36.0 C
Fan Speeds (rpm): cpu: 0 fan-2: 0
Packages: 2065 pm: pacman pkgs: 2044 libs: 545
tools: gnome-software,pamac,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 21
1: https://mirror.23m.com/manjaro/stable/$repo/$arch
2: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
3: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
4: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
5: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
6: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
7: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
8: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 405
1: cpu: 29.2% command: phpstorm pid: 6584 mem: 3300.7 MiB (10.3%)
2: cpu: 14.2% command: firefox pid: 9517 mem: 899.7 MiB (2.8%)
3: cpu: 6.6% command: gnome-shell pid: 3166 mem: 307.9 MiB (0.9%)
4: cpu: 4.4% command: jetbrains-toolbox pid: 3350 mem: 395.7 MiB (1.2%)
5: cpu: 3.2% command: code pid: 12366 mem: 340.2 MiB (1.0%)
Memory top: 5 of 405
1: mem: 3300.7 MiB (10.3%) command: phpstorm pid: 6584 cpu: 29.2%
2: mem: 899.7 MiB (2.8%) command: firefox pid: 9517 cpu: 14.2%
3: mem: 427.8 MiB (1.3%) command: chromium pid: 6161 cpu: 2.0%
4: mem: 398.4 MiB (1.2%) command: mysqld pid: 1417 cpu: 0.6%
5: mem: 395.7 MiB (1.2%) command: jetbrains-toolbox pid: 3350 cpu: 4.4%
Processes: 405 Power: uptime: 18m states: freeze,mem,disk suspend: s2idle
image: 12.36 GiB services: gsd-power, power-profiles-daemon, upowerd
Init: systemd v: 261 default: graphical tool: systemctl
Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: fish v: 4.9.1
running-in: terminator inxi: 3.3.41
