When I upload around 400 MB with a browser to a cloud drive, or if I use the cloud drive app, or I upload a video to YouTube, the wifi goes offline and I can’t connect anymore. No wifi connections are found and I have to restart to be able to connect with the internet again.
I also have Windows 10 on the system and there I don’t have this issue, so it’s not a hardware problem. Also I could upload on this computer/Manjaro for many months without problems. It just happened recently. With Timeshift I just jumped back 2 week, but sadly, it didn’t help.
System: Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.14.3 Distro: Manjaro Linux
Machine: Type: Desktop System: Intel product: KBL-R MRD v: 0.1 serial: <filter>
Mobo: Intel model: MIR1 v: RVP7 serial: <filter> UEFI [Legacy]: American Megatrends v: 5.12 date: 07/12/2018
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270 charge: 100% (should be ignored)
status: Discharging
CPU: Info: Quad Core model: Intel Core i7-8650U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 33615
Speed: 800 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 801 6: 800 7: 800 8: 801
Graphics: Device-1: Intel UHD Graphics 620 driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.9 driver: intel resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.2 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Device-2: C-Media USB Advanced Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:2
Sound Server: ALSA v: k5.9.8-2-MANJARO
Network: Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: f040 bus ID: 01:00.0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: e000 bus ID: 02:00.0
Drives: Local Storage: total: 942.70 GiB used: 779.16 GiB (82.7%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-9WS142 size: 465.76 GiB
ID-2: /dev/sdb vendor: SanDisk model: SD8SN8U512G1027 size: 476.94 GiB
Partition: ID-1: / size: 19.10 GiB used: 14.56 GiB (76.2%) fs: ext4 dev: /dev/sdb6
ID-2: /home size: 400.62 GiB used: 308.00 GiB (76.9%) fs: ext4 dev: /dev/sdb7
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 59.5 C mobo: N/A
Info: Processes: 305 Uptime: 4m Memory: 15.43 GiB used: 2.59 GiB (16.8%) Init: systemd Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: 1579 Shell: Bash v: 5.0.18 inxi: 3.1.08
wlp1s0 IEEE 802.11 ESSID:"Nice Nest 302"
Mode:Managed Frequency:2.432 GHz Access Point: 14:4D:67:B4:D7:1C
Bit Rate=150 Mb/s Tx-Power=22 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=64/70 Signal level=-46 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:68 Missed beacon:0
[admin@manjaro-2019-11 ~]$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 00:e0:4c:e1:09:3a brd ff:ff:ff:ff:ff:ff
3: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether c0:b6:f9:9c:8a:fb brd ff:ff:ff:ff:ff:ff
inet 192.168.5.4/24 brd 192.168.5.255 scope global dynamic noprefixroute wlp1s0
valid_lft 28362sec preferred_lft 28362sec
[admin@manjaro-2019-11 ~]$ nmcli -f GENERAL,WIFI-PROPERTIES dev show wlp1s0
GENERAL.DEVICE: wlp1s0
GENERAL.TYPE: wifi
GENERAL.NM-TYPE: NMDeviceWifi
GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/3
GENERAL.VENDOR: Intel Corporation
GENERAL.PRODUCT: Wireless 3165 (Dual Band Wireless AC 3165)
GENERAL.DRIVER: iwlwifi
GENERAL.DRIVER-VERSION: 5.9.8-2-MANJARO
GENERAL.FIRMWARE-VERSION: 29.198743027.0 7265D-29.ucode
GENERAL.HWADDR: C0:B6:F9:9C:8A:FB
GENERAL.MTU: 1500
GENERAL.STATE: 100 (connected)
GENERAL.REASON: 0 (No reason given)
GENERAL.IP4-CONNECTIVITY: 4 (full)
GENERAL.IP6-CONNECTIVITY: 1 (none)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.0/0000:01:00.0/net/wlp1s0
GENERAL.PATH: pci-0000:01:00.0
GENERAL.IP-IFACE: wlp1s0
GENERAL.IS-SOFTWARE: no
GENERAL.NM-MANAGED: yes
GENERAL.AUTOCONNECT: yes
GENERAL.FIRMWARE-MISSING: no
GENERAL.NM-PLUGIN-MISSING: no
GENERAL.PHYS-PORT-ID: --
GENERAL.CONNECTION: Nice Nest 302
GENERAL.CON-UUID: 3f62ec88-5ab1-4166-904a-534dea3653ef
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/1
GENERAL.METERED: no (guessed)
WIFI-PROPERTIES.WEP: yes
WIFI-PROPERTIES.WPA: yes
WIFI-PROPERTIES.WPA2: yes
WIFI-PROPERTIES.TKIP: yes
WIFI-PROPERTIES.CCMP: yes
WIFI-PROPERTIES.AP: yes
WIFI-PROPERTIES.ADHOC: yes
WIFI-PROPERTIES.2GHZ: yes
WIFI-PROPERTIES.5GHZ: yes
WIFI-PROPERTIES.MESH: no
WIFI-PROPERTIES.IBSS-RSN: yes
[admin@manjaro-2019-11 ~]$ iwconfig wlp1s0
Link Quality=65/70 Signal level=-45 dBm
Tx excessive retries:0 Invalid misc:77 Missed beacon:0
