I’m relatively new to Linux so this could be a very simple fix, lmk if you need more system information I’ll get it ASAP. I switched to Manjaro from Ubuntu, where WiFi would randomly drop, now on Manjaro the issue is a lot more consistent. The WiFi will fail to connect, but (usually) connect fine after hitting forget network and re-entering the password.
System info:
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=5b31327d-ffdf-4a5b-ac20-c6a7697b1443 rw quiet splash apparmor=1
Desktop: GNOME v: 46.2 tk: GTK v: 3.24.42 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF X470-PLUS GAMING v: Rev X.0x
UEFI: American Megatrends v: 5007 date: 06/17/2019
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2241 high: 3923 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3923
3: 1868 4: 2065 5: 2195 6: 1884 7: 1935 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2196 bogomips: 118222
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nouveau
v: kernel non-free: 545.xx+ status: current (as of 2024-06; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1 bus-ID: 09:00.0
chip-ID: 10de:1b83 class-ID: 0300 temp: 32.0 C
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: gnome-shell driver: gpu: nouveau display-ID: 0
Monitor-1: HDMI-A-1 model: Asus PB278 serial: <filter> built: 2013
res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NV134 device-ID: 10de:1b83
memory: 5.84 GiB unified: no display-ID: :0.0
Device-1: NVIDIA GP104 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 09:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: TP-Link 802.11ac NIC driver: rtw_8822bu type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 2357:0138
class-ID: 0000 serial: <filter>
IF: wlp1s0f0u2 state: up mac: <filter>
Local Storage: total: 1.02 TiB used: 20.44 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A02 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 20.44 GiB (2.2%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18
used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 36.2 C mobo: N/A gpu: nouveau temp: 32.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 934
Memory: total: 32 GiB available: 31.26 GiB used: 2.43 GiB (7.8%)
Processes: 380 Power: uptime: 24m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: gsd-power,
tool: systemctl
Packages: pm: pacman pkgs: 1165 libs: 327 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Compilers: N/A Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.35
I’ve done a bit of research but could only find slightly similar issues on Arch forums, which prompted me to make sure I only had one network manager. I don’t think that should be an issue with Manjaro, especially because this is a very new installation, but I can check again if needed.
Any help solving this would be greatly appreciated <3
